Author Topic: One button to start them all....  (Read 10618 times)
CCM
« on: November 01, 2003, 10:01:30 pm »
I've seen plenty of posts on this subject and decided to use the smart strip from bits limited to power everything up when I turn on the pc.
That's where the problem comes in.  I was going to put a plain arcade button on the top of my cabinet by extending the wires from the pc power button.  When I took the case apart of the older Dell Dimension XPS T600r, there is a small ribbon cable (looks like a skinny IDE cable) that connects the power and reset buttons to the motherboard.  Is it possible to still extend the wires to the button or am I out of luck?
SpamMe
  • Last login:July 01, 2006, 03:19:58 am
  • .creature of bad habit.
    • Mame cabinet blog
Re:One button to start them all....
« Reply #1 on: November 01, 2003, 11:41:06 pm »
You're probably fine, just a matter of figuring out which wires are which :)
slicer_d
  • Last login:November 06, 2013, 12:51:11 am
  • Yay n' stuff
« Reply #2 on: November 02, 2003, 04:15:36 pm »
Yeah just figure out which wires go to the power button and then just extend those I would suggest using solder or something and not just twisting them together.
Also the type of button matters I think using an arcade button should work but you will have to hold the button down for about 3 second then let it go.  You cant just click it real fast otherwise it wont start up.
eightbit
  • My cab is never done...
« Reply #3 on: November 02, 2003, 05:12:14 pm »
I don't know about your dell. But I've done this a couple of times. I simply located the 2 wires for the power button, then pulled that plug off the motherboard and pushed my extended wires into the female side of the plug and then plugged it back into the motherboard. So soldering, no cutting wires, never had a problem doing it this way.
I disagree with you, with most pc's a simple click of the button should turn it on. The button in the case is no different than a arcade button.
TalkingOctopus
    • My Arcade
« Reply #4 on: November 02, 2003, 07:27:45 pm »
All recent PC's that I know of use buttons that operate the same way as an arcade one.   I rigged up my computer's power button to a horizantal microswitch pushbutton without a problem.
Really old PC, like my pentium 90 used an on/off state switch, but I think those vanished quickly.
eightbit
« Reply #5 on: November 02, 2003, 08:43:12 pm »
I wouldn't say vanished quickly they were around for longer than the newer style has been.
EggZilla
  • Last login:January 17, 2004, 04:44:20 pm
« Reply #6 on: November 02, 2003, 09:13:09 pm »
The typical, momentary pushbuttons will work just fine -- that's what I'm using. The only time you'll need a switch with a hard on/off switch is when you're using an old-fashioned AT case instead of an ATX, and if that's the situation, you're probably using an underpowered mobo and processor.
as far as the ribbon cable goes, that's probably something you can still do. It'll be tougher to figure out what goes where, but if you can find a diagram of the pin out somewhere online, you're home free.
One bit of advice: when you do hook in the exterior power button, I'd recommend splicing the original power button back in as well, and using quick connects to connect the longer wires to the exterior power button. That way, if you have to take the PC out to work on it at some time in the future, you won't have to remove the button from your cab and take it with you as well.
Good luck,
Eric
Like a bird on a wire,
  Like a drunk in a midnight choir,
   I have tried, in my way,
      To be free.
          - Leonard Cohen
TalkingOctopus
    • My Arcade
« Reply #7 on: November 02, 2003, 10:01:42 pm »
Well, it was not on my P-II 266... but you are right it is an assumption.
NiN^_^NiN
« Reply #8 on: November 03, 2003, 04:19:33 am »
well my 266 will work with a arcade buttons as a power button i've tryed it.
It works with all ATX mb AT used an on/off switch
This is how i understand it and im sure im right.  ::)
Hammerbot
  • Last login:September 04, 2005, 10:40:51 am
  • All work and no play...
« Reply #9 on: November 03, 2003, 08:37:35 am »
If you BIOS supports a keyboar press startup (like my ABIT motherboard does) then you can use any of the buttons on the control panel to start it up.
Then again the kids/cat/neighbors/wife could also start it up whenever...
eightbit
« Reply #10 on: November 03, 2003, 09:50:09 am »
The problem with using any key to start is how to shut it down. With the newer Motherboards and OS's to shut it down you just push the power button. That then initiates a orderly shutdown, window closes your running programs and shuts down windows then turns off the power.
ErikRuud
  • Last login:March 05, 2021, 10:20:27 am
« Reply #11 on: November 03, 2003, 12:08:50 pm »
I have a P233 pc that does have keyboard start from the space bar, but it does not work through the IPac.  I'm not sure why.
American Laser Games Wrapper
O2em Rom Utility
CCM
« Reply #12 on: November 03, 2003, 12:37:22 pm »
Thanks for all the replies!
Unfortunately the bios doesn't support startup on spacebar...
Here's what I'm thinking of doing, I'm going to pull the ribbon cable from the motherboard completely.  Then I'm going to figure out (not sure how yet) which pin on the motherboard is the power and which is the ground.  I am going to use two female connectors salvaged from an old computer and attach those to the motherboard pins for the power and ground and run the wires to my push button.
I realize that by doing this the power and reset buttons on the computer won't work, but all I have to do is plug in the ribbon cable again to get them to work.
Ok, now as far as figuring out which is power and ground on the motherboard, can I just use trial and error or could I screw up the motherboard by doing this? Say I connect the reset and led and push the button, will I blow something out or will the button simply not work?
tmasman
  • Last login:January 04, 2024, 03:50:44 pm
  • Hello...
    • My (no so up to date) Home
« Reply #13 on: November 03, 2003, 12:47:40 pm »
I'm assuming by "ribbon cable" you mean a small one (maybe 6 - 10 wires) going to the fron of the case...
If that's so, then simply take apart the fron of the case & see which wires (in the ribbon) are connected to the power button.  Then just trace that back to where it plugs into the MoBo & You're golden.
~ tmasman
I'm not a freak!...
Oh wait...
Yes I am...
daeven
  • Last login:July 15, 2022, 12:17:33 pm
  • Llama this!
« Reply #14 on: November 03, 2003, 01:55:54 pm »
MY Dell 400SC has a small circuit board at the power switch, which the ribbon cable is attached to.  I simply soldered wires to that circuit board where the power switch is attached and extended the wiring to an arcade button.
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
« Reply #15 on: November 03, 2003, 03:26:01 pm »
I assume you mean you're going to connect where the ribbon cable used to be?
What else is connected to the ribbon cable on the switch side? If it's more switches, then no problems, shorting the pins together (with a switch) should either have no effect or react as one of the buttons connected to it.
If there are LEDs connected to the board however, some of the wires probably carry currebt for the LEDs, shorting those could damage your mobo, even if you short them for a short time.
Did you look at the motherboard itself, are the pins labelled in any way? I'm not sure how DEL specific you motherboard is, so you may want to look for that info using Google. (start by searching on the motherboard name if there is one, otherwise search by computer model). that's the problem with those DEL special OEM boards, info is not readily available.
If not I'd use a ohmmeter or a hacked up flash light to figure out what wire ges where while they are unplugged from the mobo.
CCM
« Reply #16 on: November 03, 2003, 04:12:56 pm »
Yep... I'm going to connect my wires to where the ribbon cable used to be.  On the other end of the ribbon cable are 2 buttons (power and reset) and 2 led's, one for each button.  I don't remember seeing any labels on the motherboard at all.  I'll take another look when I get home from work.
soslo
  • Last login:March 10, 2012, 03:23:36 pm
  • The Governator
    • My website does not have a name yet
« Reply #17 on: November 03, 2003, 11:19:35 pm »
Wow...seems like you guys are making this (potentially) unnecessarily complex. My first cab was a single switch:
I put an inline switch to the 6 outlet power strip. Everything was plugged into that (monitor, computer, speakers, 2 lights).
In the BIOS of the computer, under the power properties, I set to computer to turn-on after power restore (something like that).
I left the monitor switched on, and everything else, and when I flipped the switch, power to the strip was then sent and everything turned on, even the computer. Since the power strip was actually losing power when the main switch was off, the computer thinks there has been a power failure or that it has been unplugged, and promptly turns itself on.
I hope that makes sense. If this doesn't apply to your computer (non-ATX), then please accept my apologies and resume your discussion  ;)
5 MAME cabs and counting...
Ever wonder what full side art looks like?
http://www.aaronmurray.com
eightbit
« Reply #18 on: November 04, 2003, 09:26:33 am »
This feature is not in all bios's. Its also not good to shut down windows by cutting the power. By using the pc power button you can get a orderly shutdown and with the smart strips you can control everything on and off with that one button.
soslo
  • The Governator
« Reply #19 on: November 04, 2003, 10:16:42 am »
Sorry, should have specified - I shut down windows before powering off the cab...most front ends have a feature like "Exit and Shut Down"
Just select that and a few seconds later you hit the switch.
eightbit
« Reply #20 on: November 04, 2003, 10:48:10 am »
But thats not the one button to do it all and your bios has to support the power on after power loss feature. Its like the spacebar to turn it on feature, its nice but a lot of people don't have those features.
What we've been discussing is a solution that should work for most people with most configurations.
soslo
  • The Governator
« Reply #21 on: November 04, 2003, 11:14:19 am »
[quote But thats not the one button to do it all
technically it is only one button...but I see your point. You don't want to have to select the shut down menu item in the front end...I see know.
Don't most (all?) ATX motherboards support this?
Thats cool - I am sure there is a better solution out there...but I'm also sure it will be more complex and include relays and such. I am definately not trying to stifle the creative process - just offer a (to me) easy alternative for those with the MB feature.
Please keep going - I'm sure I'll use the "one button to rule them all, and in the darkness power them" solution when it gets nailed down and layed out.  8)
eightbit
« Reply #22 on: November 04, 2003, 09:21:21 pm »
To be fair mamewah has the option to shut down windows when you exit the front end(other front ends might also have this feature). This requires that your front end support this feature and you have to have a button programmed to exit the front end. Then you have to have a motherboard that supports resume after power loss. Then you have to either be able to reach your power strip or have a power strip with a remote switch. If you have these features then your method is pretty good but it is not a single button press on and off.
The method I'm advocating that we have been discussing requires that you buy a autosensing power strip(only $20 at Sears). It doesn't require relays or hacking power strips. Then you have to extend the button from your pc to a remote button. The advantage to this method is that it will work with most all pc's and front ends plus its a true single button solution. Most people that have gotten this far with their cab can extend their power button.
The biggest advantage to my method is that any one can turn the cab on and off when I'm not their.
soslo
  • The Governator
« Reply #23 on: November 04, 2003, 10:44:21 pm »
Ahh, gotcha - that does seem like a much more elegant solution.
So basically, all I need to do is get this power strip and relocated my power button? If that is the case, I will retrofit both of the cabs I am working on right now!
eightbit
« Reply #24 on: November 04, 2003, 11:10:48 pm »
Test your os, when you push the power button while in your front end does it close your front end and then shut down windows in an orderly manner and power off the cpu. If that works then all you need is the power strip. If your pc power button is easily reached you don't even need to relocate the button but my personal preference is to put an arcade button on top of the cab for this.
barfybuffet
  • Last login:November 17, 2003, 10:37:08 am
« Reply #25 on: November 04, 2003, 11:32:28 pm »
http://www.taconuts.org/articles/2000/dec/21/page1.php
this article details how to cheaply make your own start button using nothing more than a momentary switch, some wire, and 2 jumpers.
i plan to do the same but i will probably rip the tail/connector off of a spare power switch and extend the wires to fit my needs.
in the future.... dont buy dell!
build your own. you wont have crappy proprietary all-in-one motherboard connectors and you will know exactly which pins are for your power.
soslo
  • The Governator
« Reply #26 on: November 05, 2003, 10:04:16 am »
eightbit - I tried just pressing the power button to shut everything down and it worked - amazing, I never tried that!
Which power supply d I need to get at sears?
eightbit
« Reply #27 on: November 06, 2003, 08:50:09 am »
The bit smart strips are a lot nicer. They have surge suppression built in and are designed for use with computers. There new model even has adjustable sensitivity. The Sears ones are designed for use with power tools, I don't know what the implications of that are. I never used a bit smart one. I was all ready to place my order when I located the Sears one. I made a quest to locate one of these when power strip relay hacks were popular. The only ones I could locate were no longer made. The bit smart one was brand new at the time. Another nice feature of the bit smart was is there is more than enough outlets for a typical cab. The Sears one doesn't have enough outlets. If you want the Sears one I stole the following from an old thread.
I got a PM the other day regarding some of the 1 button power up commercial solutions out there and noticed that eightbit's original post about the Sears one was incomplete because the pic is missing due to his host not being up ...
Anyways... I went out and snagged one:
It's part #924031  (you can look it up on Sears.com if you like -- they have a goofy session info encoded in their urls so copy pasting seems like a bad idea) It's a craftsman Automatic Power Switch - "auto switch".   I picked mine up at a dedicated sears hardware store (although have seen 'em in regular sears).  It's on a peg near the circular saw blades n' stuff  (not in electrical sections go figure)  it was $19.99 ... it plugs right into the outlet so you may or may not want to get a 6 foot extension cord  depending on how anal you are about only having 1 cord exit your cabinet.
*Shrug* I plugged it in... plugged my PC power supply cord into the "main" ... plugged my surge suppressor into the accessories... flipped the mode switch.  and then I hit the momentary contact switch that turns on my PC and Voila! It came to life...
soslo
  • The Governator
« Reply #28 on: November 06, 2003, 10:28:41 am »
I just ordered 4 of the Bit Smart Strips for $112 including shipping:
http://www.bitsltd.net/smartstrip/information.htm
Apparently they give a little dicount ($2 off each one) if you buy in bulk...
ts
  • Last login:April 08, 2016, 03:01:29 pm
« Reply #29 on: November 14, 2003, 09:46:58 pm »
DId you ever figure out what wires to extend to your external pushbutton.  I also have this ribbon configuration from the motherboard to the outer control panel board with 2 buttons and 2 leds.  Im still wondering how to "wire" into this to extend to an outer power button.  It looks like on the circuit board there are 4 soldered contact area.  Was wondering if I could solder my wires to these although, how to know which contact area is hot and which is ground I am not sure.  There are four "solder points" total but which two are hot and which two are ground, I do not know.
It appears to attach to the motherboard with a series of pins and I see no info on the board labelin the jumpers as poer, led,reset, led, etc.?
ANyone have any ideas on this.  Couldn't find much on Google....
papaschtroumpf
  • Have a Cow!
« Reply #30 on: November 14, 2003, 11:14:14 pm »
Here is what I would do:
use a continuity tester of some kind (cheap at home improvement stores, radio shack or simply use a hacked flashlights).
unplug the cable either from the motherboard or from the header, depending which side is easiest to work with. This way you won't damage the motherboard.
Now set your continuity tester to two of the four pins. if it shows some kind of continuity you're either accross the LED or on two common pins, either way that's not what you want, so pick another pair of pins.
If the continuity tester show no continuity, try to press the start button on the fron of your computer, if the tester shows continuity you have now identified the two pins that are connected to the button. release the button and continuity should go off again.
Hope this makes sense...
soslo
  • The Governator
« Reply #31 on: November 15, 2003, 12:16:19 pm »
I got the smartstrips...but they seem to activate the switch plugs at random...sometimes they wont turn off when I turn the main item (computer) off - sometimes it will. I've messed with the sensitivty dial...but no luck. Any ideas?
ts
« Reply #32 on: November 15, 2003, 04:44:40 pm »
well now I am not sure.
I was all set to order a smart strip and then I hear what soslo mentions. so my question is thiis...  Are the smartstrips for sale on their website the working versions now or are they the same first generation ones that had all the problems?
Anyone else ordered from them lately?
eightbit
« Reply #33 on: November 16, 2003, 11:03:50 am »
Did you order more than one strip? Do they all have this problem? Have you tried a different coomputer?
soslo
  • The Governator
« Reply #34 on: November 16, 2003, 11:36:57 am »
I ordered 4 strips. The power comes on and off at random. Last night the strip was off. This morning when I get up - viola, activated and the monitor is on while the computer is off. Its like that - off and on all day...but usually hours in between each cycle.
Well, that seems like a waste of $112. Looks like I'll got back to my old method with the $3 radio shack switch.
eightbit
« Reply #35 on: November 16, 2003, 06:52:52 pm »
They definately shouldn't do that, you should call the company. I've never heard of anyone that had problems with them not get them resolved.
The relay hack costs more than just a $3 relay to pull it off.
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #36 on: November 16, 2003, 07:09:24 pm »
soslo, I would suggest turning the sensitivity dial even further.  I had to turn mine like a full turn and some before it shut off the other devices properly.
soslo
  • The Governator
« Reply #37 on: November 16, 2003, 08:58:26 pm »
I've tried the sensitivity dial...it turns about 3/4 of a full turn in total...so like 3/8ths in either direction from the middle (default) setting.
I'll mess with it again...I'm just totally bummed out that it comes on randomly...it works great for a couple of hours, then it'll just decide to leave everything turned on.
ts
« Reply #38 on: November 18, 2003, 06:04:10 pm »
anyone else have any feedback.  I am tempted to go ahead an order one of the smartstrips and see what happens...
soslo
  • The Governator
« Reply #39 on: November 18, 2003, 06:07:43 pm »
I turned the strip sensitivity all the way down last night. Turned the computer on, then back off. Nothing else would shut down (power was still going to the switched outlets).
Go out this morning and everything is off.
[sigh]
