Poll
What version of PGA do you currently own?
PGA GOLF
7 (4.3%)
CHAMPIONSHIP I
6 (3.7%)
CHAMPIONSHIP II
3 (1.8%)
CHAMPIONSHIP III
20 (12.2%)
CHALLENGE
31 (18.9%)
TEAM CHALLENGE
54 (32.9%)
TEAM CHALLENGE w/ ALL ACCESS
28 (17.1%)
I DON'T OWN A VERSION BUT WOULD LIKE TO!
15 (9.1%)
Total Members Voted: 164
Author Topic: PGA Tour Golf by Global VR & EA Sports Owners Thread  (Read 548165 times)
Slimonce
  • Last login:July 15, 2022, 06:02:55 pm
Re: PGA Tour Golf by Global VR & EA Sports Owners Thread
« Reply #40 on: March 08, 2013, 05:14:51 pm »
Thx!  Any chance it is a date and time issue?  If so can't find in control panel to check.
stpcore
  • Last login:February 09, 2019, 05:48:56 pm
« Reply #41 on: March 08, 2013, 05:17:47 pm »
Date and time should be adjusted by hitting the DEL key when the computer is trying to boot in order to get into bios.  Pics coming in a second...
Offering commercial grade vinyl decal printing for cabinet side art, control panel overlays, monitor bezels, marquees, etc.
stpcore
« Reply #42 on: March 08, 2013, 05:21:52 pm »
First, let me apologize for the condition of this PGA tower.  It looks like it was pulled from the Titanic.  It's FILTHY to say the least and I haven't had time to take it apart and clean it yet but it should serve for the purpose here.
So the first pic shows the basic cable connection.  The bottom portion of the cable is connected to the i/o board which is where your controls are plugged into.
This second pic shows the inside of the tower and shows the wire coming from the power supply plugging into the i/o board as well.
Slimonce
« Reply #43 on: March 08, 2013, 05:25:17 pm »
K. Let me pull the tower and check. Decent chance they didn't do this. Back soon and thank you so much.
stpcore
« Reply #44 on: March 08, 2013, 05:27:55 pm »
Hey man, no problem at all.  Hopefully we can get this thing to work for you.
Slimonce
« Reply #45 on: March 08, 2013, 05:33:42 pm »
Here's what I have. I have one cord into this but I have two usbs up top where you have one.
stpcore
« Reply #46 on: March 08, 2013, 05:47:59 pm »
I have two USB inputs on the top of mine.
Do you see that wire from your power supply to your i/o card and how it's connected to one of the side ports?  Mine is powered with a smaller connector on the back of the i/o card.  I wonder if that's causing your issue?  Pull that larger molex connector out and place the smaller one from the PSU to the back and see if that may work?
Slimonce
« Reply #47 on: March 08, 2013, 05:54:23 pm »
The one on the back is larger. Doesn't look the same.
stpcore
« Reply #48 on: March 08, 2013, 06:04:14 pm »
Hmmmm, do you have anything you can plug into that port?
Slimonce
« Reply #49 on: March 08, 2013, 06:09:33 pm »
No. The light on the back comes on when I have it on. Green light next to big port.
stpcore
« Reply #50 on: March 08, 2013, 06:12:10 pm »
I'm wondering if it's just a bad board?  Maybe someone else can offer up an idea on this one?
Slimonce
« Reply #51 on: March 08, 2013, 06:35:57 pm »
Brand new mobo sure hope not. First error on booting says file usbui.dll is needed on CDROM. Then asks where to copy files from. If you hit cancel it will take u to the screen I described. For some reason I can't post pics of the screen from iPad.
stpcore
« Reply #52 on: March 08, 2013, 06:38:27 pm »
Not a bad mother board but a bad I/o board. You have the USB ports enabled in the bios menu, right?
  • Last login:Yesterday at 10:37:55 pm
« Reply #53 on: March 08, 2013, 06:44:38 pm »
check your bios and make sure your usb hasn't been disabled.
now would be a good time to check your battery.
Slimonce
« Reply #54 on: March 08, 2013, 06:50:27 pm »
Tell me where to find that please. Hit delete and see
stpcore
« Reply #55 on: March 08, 2013, 06:53:31 pm »
Make sure your bios match this...
You can do this by repeatedly hitting the DEL key while the computer is attempting to boot. Once in the bios screen make sure that these values are matching your machine. Make sure your settings match the ones below.
....main screen...
on power boot >>delete key<<
this will take u to the bios screen
std setting's as follow's
current date must be current
current time must be current
ide primary >> wdc wd200bb >20meg< this is the hard drive def for your unit..could veri
ide slave >> none
ide secondary >> master >cdrom<
ide secondary >> slave none
drive a 3.5"
drive b none
video >> ega/vga
halt on >> no error's
base mem >>640k
extened mem >> 52364
total >> 524288
....advanced....
bios flash protect >> disabled
virus warring >> disabled
cpu l1 & l2 cache >> enabled
quick power on self test >> fast
first boot device >> cdrom
second boot device >> hdd-0
third boot device >> floppy :we can turn this off:
boot other device >> disabled
swap floppy drive >> disabled
boot up floppy seek >> enabled :we can turn this off:
boot up numblock status >> on
that is the first 2 settings page
we skip the third and go to the 4th
......integerated peripherals......
on-chip primary pci ide >> enabled
ide primary master pio >> auto
ide primary slave pio >> auto
ide primary master udma >> auto
ide primary slave udma >> auto
on-chip secondary pci ide >> enabled
ide secondary master pio >> auto
ide secondary slave pio >> auto
ide secondary master udma >> auto
ide secondary slave udma >> auto
usb controller >> enabled <<< important >> USB will not work if disabled
usb keyboard support >> disabled
ac97 audio >> auto
ac97 modem >> auto
init display first >> agp : this is 1 of the setting's we change when using a dif video card
onboard ac97 codec >> enabled
onboard lan control >> enabled :we need this for turenne
onboard lan boot rom >> disabled :we enable it to use the lan
ide hdd block mode >> enabled : this is beacuase u may have a cable select mode,and or master/slave setting on your hd setup
that is part 4 of the bios setup
Once your values are complete try restarting the computer and see if it gets you anywhere. At that point even if it's not booting at least you are starting your diagnosis with the correct settings.
« Last Edit: March 08, 2013, 06:55:33 pm by stpcore »
Slimonce
« Reply #56 on: March 08, 2013, 07:11:17 pm »
Made Ur changes  still get the CDROM issue. Hit cancel and boot exe get this. Odd thing is this is a champ III yet screen looks like regular champ.
« Reply #57 on: March 08, 2013, 07:21:11 pm »
you may need to re-install. looks like your usb drivers went kaput, or the board did.
reloading software is free, i'd try that first.
Slimonce
« Reply #58 on: March 08, 2013, 07:27:26 pm »
Will do. Waiting for discs to show up in mail. Pray that's the ticket!  Thanks to you and stp for all the help today.
stpcore
« Reply #59 on: March 08, 2013, 07:27:51 pm »
My Championship III screens look like it is a regular Championship version as well. It's normal.
stpcore
« Reply #60 on: March 08, 2013, 07:58:11 pm »
I can certainly make an iso of the Rescue and 2 Installation CDs and upload them for you tomorrow at some point as I have those for Championship III.  I'm not certain what country code your dongle is for and if there would be a compatibility issue with US disks?
Slimonce
« Reply #61 on: March 08, 2013, 08:00:56 pm »
It's US. Game is from ill. I'm in ia!  Thanks!!!
stpcore
« Reply #62 on: March 08, 2013, 08:02:04 pm »
Why did I think you were from out of the country? LOL! Sorry.
ed12
« Reply #63 on: March 08, 2013, 09:34:14 pm »
hi
ppl and i am not stepping on toes here as it is not my thread
but did we all miss a few point's ?
it boot's and come's back it cannot see the >i/o< card
my q would have been.
is it plugged in right?
ie the jumper from the card to the top of the tower where the usb port's are?
or are u using the usb >2< card ?
if so did u try to plug it right into the tower ?,from the i/o card to the upper usb port ?
have u tired another usb cable?
reason for this question is the i/o card will go sideway's as they are legacey
second dose it have a point on the i/o card where u can plug in a power supply point ?
like the 1's u use on a ide hard drive ?
4 pin's yellow black black red ?
as some of the older gen card's need +12 and 5+ fed to them
did not mean to hijack
just thought i would toss in 2%
ed
Slimonce
« Reply #64 on: March 08, 2013, 10:55:55 pm »
Ed, not sure i follow. From what I've learned this is the I/o card I've always had and before mobo switch it was fine. It is hooked up exactly the same prior the swap. New issues, not sure of importance are: tower only turns on by powering it, not off of master on/off. Once going it goes fine through boot then goes black. W windows key I can get the error listed above about the usbui.dll missing from CDROM. Cancel that and then it goes to the shot above about usbios. Stuck here.
ed12
« Reply #65 on: March 08, 2013, 11:28:32 pm »
god holy hi-jack
sorry stpcore..
did u set the power option's to
AFTER POWER OFF TO TURN ON AUTO ?
in the bios.
 it could be under POWER OPTIONS/SETTINGS/COUSTOM
 if so did u set the mobo the way stpcore asked u to ?
with out touching any buttons
it should come right on
and game should load
if it fail's on the  >i/o< test it simpley mean's it is not reading the i/o card
ed
Slimonce
« Reply #66 on: March 08, 2013, 11:39:05 pm »
All I see is a PWR Lost Resume State. It's set to keep off n
stpcore
« Reply #67 on: March 08, 2013, 11:41:37 pm »
Turn that on so it powers up when you flip the switch on your cabinet.
Slimonce
« Reply #68 on: March 08, 2013, 11:54:37 pm »
K. Loads off master power and way faster. Still same issues. Should I default to safe settings off the bios screen to see what happens?
stpcore
« Reply #69 on: March 08, 2013, 11:57:57 pm »
I think your bios are fine. I have a feeling its the actual I/o board as the USB ports are enabled and everything in bios is configured correctly if you followed the prior post. If you want to do a complete fresh install with the iso images I can have those ready for you tomorrow for Championship III? That would be the last thing I can personally think to do.
Slimonce
« Reply #70 on: March 09, 2013, 12:05:32 am »
One thing I just remembered the guy at DIT said he defragged the hd and cleaned it up. I know Ed said don't touch it on the other thread. Could that be the issue?
yukonblaze
  • Last login:February 16, 2023, 11:32:48 am
« Reply #71 on: March 09, 2013, 02:38:31 am »
Remeber getting same error as i/o plugged into wrong usb port.
Also when changing golfers to tiger ect. If you use the lefty players, tiger ect will also be lefty.
Jason
Spitfire
  • Last login:August 05, 2023, 07:55:31 am
« Reply #72 on: March 09, 2013, 06:54:31 am »
Hi Simon,
You need to make sure you set ur bios exactly as STP has posted as it seems u haven't done so as u didn't have the resume state to power on.
Once this is done n still same error I agree with Ed that you may need to take out io board n reseat board as just may not be in correctly or far enough. Also try a different USB slot as suggested. If all this fails as ready mention it has to be corrupt files or bad board!
Good luck
Slimonce
« Reply #73 on: March 09, 2013, 09:33:53 am »
Ever have a duh moment?  Take a look at my pic at 5:54 yesterday. I don't think the I/o cars is seated in anything. Which slot should it b in?  Doesn't seem to align w either very well. Think we found the issue tho!!!!
stpcore
« Reply #74 on: March 09, 2013, 09:59:02 am »
I think it's seated if you look closely but it's hard to tell by the angle of your pic.  You will see pins coming out of the back that look like they should plug into a port but they do not.  Check out my pic...same thing.
Slimonce
« Reply #75 on: March 09, 2013, 10:24:02 am »
K. From what I think I know. The only thing connected to this is the wires that I assume to be the power. This card does not have anything going into the mobo. It's just kind of floating w that one cord you can see connected to it. Where it looks like it should seat into mobo there are no "connectors". They are on the back as you suggest. Is the only that should connect to this the cable that is already there?  Just thinking if that's only power something else needs to connect to recognize it. Prolly pipe dream!
stpcore
« Reply #76 on: March 09, 2013, 10:31:40 am »
I think your i/o is different than mine because mine does sit in the mother board.  Maybe this pic will show you with more detail from a different angle.  If it's just floating plugged into the power supply then you found your problem for sure.
Slimonce
« Reply #77 on: March 09, 2013, 11:13:47 am »
Here's what I'm looking at. There's nothing to seat where it should seat by comparing to yours.
ed12
« Reply #78 on: March 09, 2013, 11:33:46 am »
hi
ya thats a gen 2 i/o card
do the fast fav's
i know i asked u last night to make sure the power plug was plugged in
ie the white 1 at the end of the board..
un-plug it
hook in the usb as i explained
and see if the green light come's  that is on the board faceing the same way as the usb and the game harness hook's in,it is there at the top of the card
u DO NOT NEED THE GAME HARNESS HOOKED FOR THIS TEST
what u are doing is finding out a few thing's
if the green light dose not come on
then your usb is NOT enabled
if it DOSE come on then your usb is ENABLED
that is fast and dirty chk for them card's
it dose not even have to be in the machine :for that test:.
now if the green light is on but it keep's coming back i/o is not be seen
then u need to look for a new card.
u ppl have to rember the i/o card has it's own mirco and eeprom
ed
stpcore
« Reply #79 on: March 09, 2013, 11:37:18 am »
I peeked into one of my Championship III towers and it is NOT seated into the motherboard either so it must not make a difference with the gen2 i/o.  Never noticed that before.
« Last Edit: March 09, 2013, 11:44:15 am by stpcore »
