Poll
What version of PGA do you currently own?
PGA GOLF
7 (4.2%)
CHAMPIONSHIP I
6 (3.6%)
CHAMPIONSHIP II
3 (1.8%)
CHAMPIONSHIP III
20 (12.1%)
CHALLENGE
32 (19.4%)
TEAM CHALLENGE
54 (32.7%)
TEAM CHALLENGE w/ ALL ACCESS
28 (17%)
I DON'T OWN A VERSION BUT WOULD LIKE TO!
15 (9.1%)
Total Members Voted: 165
Author Topic: PGA Tour Golf by Global VR & EA Sports Owners Thread  (Read 891308 times)
0 Members and 8 Guests are viewing this topic.
ed12
Re: PGA Tour Golf by Global VR & EA Sports Owners Thread
« Reply #2160 on: November 13, 2016, 09:21:16 pm »
i will be on most of the night
remeber u have to use a dvd and the 1 with that machine will be cd only (atleast) thats what they shipped with
ed
brad808
  • Last login:May 22, 2023, 08:18:15 pm
« Reply #2161 on: November 13, 2016, 09:24:41 pm »
Windows 7 is a no go. Crashes during setup wizard launch
Will check XP as well but hardware might be dinked.
Might try and pick up a Dell gx260 as that seems like a suitable replacement computer? I haven't been able to find a clear cut answer as to what computers would be compatible.
ed12
« Reply #2162 on: November 13, 2016, 09:33:16 pm »
ya i would lean that way also.
u could pull the cmos bat and wit a few mins then put it back in
just to see if it is cmos related
ed
brad808
« Reply #2163 on: November 13, 2016, 09:58:53 pm »
So just out of curiosity I tried the recovery disk in some completely unrelated hardware and got the same error message. I'm guessing maybe it has something to do with compatibility of what the OS is expecting vs what the replacement hardware is.
ed12
« Reply #2164 on: November 13, 2016, 10:04:03 pm »
i have never seen it show up that fast (golf wise)
might be time to cut the loss or just replace the thing with a running unit
ed
Spitfire
  • Last login:August 05, 2023, 07:55:31 am
« Reply #2165 on: November 13, 2016, 10:21:47 pm »
Yep agreed if cmos reset doesn't work the hardware seems rooted and best pick up a dell gx260 and install quite simple.
brad808
« Reply #2166 on: November 15, 2016, 10:50:45 pm »
OK update time. Got a Dell gx260. Got the recovery and install disks for team challenge. Going to try and use the Dongle emulator. Hitting this error now. I believe it's because i installed the software with a Cad Dongle. My question now becomes this. Am I able to change the region setting of the software after it has been installed via some config file? Does a dng file for the Canadian team challenge exist for the emulator?
ed12
« Reply #2167 on: November 15, 2016, 11:11:22 pm »
if u use > hasp <
u do not need to worrie about it
ed
brad808
« Reply #2168 on: November 15, 2016, 11:19:03 pm »
That is the error message I get while using hasp. I have tried US dng and AU dng files. Both give me incorrect country message.
brad808
« Reply #2169 on: November 16, 2016, 07:22:23 am »
I think later tonight I will try to start from scratch and leave my Dongle out of it completely. See if I can get the emulator to load up before installing the software and have the game install with just the emulated Dongle.
mictas
  • Last login:July 12, 2017, 12:49:41 pm
« Reply #2170 on: November 16, 2016, 02:33:06 pm »
hi I had a team challenge however the I.o card stopped working  and the hard drive had died too I don't want to loose this machine but have no recovery disc...I have tried swopping the pcb from working hard drive to the pga one but had no luck still ...does anyone have any ideas to save her thank you in advance for any help
« Last Edit: November 16, 2016, 02:35:42 pm by mictas »
ed12
« Reply #2171 on: November 16, 2016, 03:15:19 pm »
team challange
what build ?
and is it canadian or us or ur ?
ed
mictas
« Reply #2172 on: November 16, 2016, 03:52:19 pm »
hi now im going to sound stupid where would I look to find out it was bought in the UK have the machine in next room so can check
thank you
mictas
« Reply #2173 on: November 16, 2016, 04:04:30 pm »
on hasp dongle it reads
H4 M1  5.0
EMMMQ  205236
if that helps
ed12
« Reply #2174 on: November 16, 2016, 04:35:20 pm »
well we now know your build (5) which i have
dose the other side have anything on it  ?
like pga-team-chaaenge-ca ?
it is whats after the - i need to know
ed
mictas
« Reply #2175 on: November 16, 2016, 04:43:34 pm »
no nothing on the other side than a old strip of masking tape on it but no writing
ed12
« Reply #2176 on: November 16, 2016, 04:56:06 pm »
its a 50/50 but i will up-load them
give me a day to make sure my account is ok
and i will up-load the disks
ed
ed12
« Reply #2177 on: November 16, 2016, 05:14:57 pm »
ok rescuse/install 2/install 3 are done
i just need to find install main (1) then i will get them up there
ed
brad808
« Reply #2178 on: November 16, 2016, 06:00:11 pm »
I'm finally up and running. Reinstalled everything with no Dongle in and at worked. Instructions for emulator said I needed to have a legit Dongle in during install but in fact the opposite was true. It was screwing up the install and forcing a Canadian region. All seems well in that department now. Still need to get a video card for it in order to play but at least I'm in the menu systems now.
mictas
« Reply #2179 on: November 17, 2016, 07:31:00 am »
thank you thats brilliant
Spitfire
« Reply #2180 on: November 19, 2016, 03:49:09 am »
Hey Ed were you not supposed to be getting us all on your server and getting us all back online? How far away is it? Why are tou not responding to my PMs?
The-O
  • Last login:January 16, 2024, 08:18:19 am
« Reply #2181 on: November 21, 2016, 10:09:35 am »
Hey guys, you don't need to use old obsolete mainboards or IDE drives or even old Graphics boards. Our current builds use Asus H61 mainboards (as they have parallel ports on-board), 32gig SSD drives and Nvidia 610 graphics cards, 2gigs ram and a plain Pentium G3020 dual core processor, but even i3 i5 or i7 will also work. Everyting works 100% with that hardware setup, and is blazing fast. You just need to make a few tweaks in the bios and run a patch on the registry to make XPe think that SP3 is installed. That's it.
Spitfire
« Reply #2182 on: November 22, 2016, 05:33:10 pm »
Can you please provide instructions on how this is done?
mictas
« Reply #2183 on: November 23, 2016, 09:50:11 am »
any luck on the pga team challenge install discs please
mictas
« Reply #2184 on: November 25, 2016, 04:47:32 pm »
think it's time to call it quits on my team challenge  :-( thank you to any one who offered help
ed12
« Reply #2185 on: November 25, 2016, 04:57:28 pm »
i am trying to up-load the full chd
all u will do is copy it a blank harddrive using chdman
just need to find a new up-load site
ed
Spitfire
« Reply #2186 on: November 25, 2016, 10:36:10 pm »
Hey mate sent you 2 pm's with no reply. Need your email to send you a links to my dropbox?
And Ed12 once again mate you fail to deliver anything you say!! Why no reply to getting us on your server as promised?? I pmed you a number of times and messaged you here?? You really are one big waste of time.  :angry:
mictas
« Reply #2187 on: November 26, 2016, 02:02:22 pm »
mictas_1@msn.com sorry I didn't know good job I checked this page was about to take a hammer to it :-)
ed12
« Reply #2188 on: November 26, 2016, 05:32:49 pm »
ok your rescue disk is here
>https://ufile.io/92718< live link
7 days
do not take your time because if u want the rest i will need to delete it
and re-up-load what u request
spitfire it went to my it ppl
when i get the okie dokie
i will post on it
mictas if u just want a full image of a running pga challenge ? (3)
i will need to move to a different up-load site
as i will be dammed i am paying to help ppl that way
hope u understand ?
if u want it in there orignal disks 1 at a time i am good with that
ed
brad808
« Reply #2189 on: November 26, 2016, 06:49:04 pm »
Mine still isn't working even after I got a new video card for it. Game silently crashes and restarts at the menu system just after the intro video. Sigh. What a total pain in the ass this thing has been.
ed12
« Reply #2190 on: November 26, 2016, 11:23:51 pm »
brad why did u not just snag me up on my offer ?
the $$ i want and the 2 old computers.
u will now need your dongle until i get more instock
ed
brad808
« Reply #2191 on: November 27, 2016, 12:08:26 am »
Ed how much do you want?
ed12
« Reply #2192 on: November 27, 2016, 12:19:32 am »
200.00 exchange
will deliver and hook up for u
ed
mictas
« Reply #2193 on: November 27, 2016, 02:33:56 pm »
this is great am down loading it now will give you heads up when donew ty again
mictas
« Reply #2194 on: November 27, 2016, 02:45:05 pm »
Quote from: mictas ģlink=topic=129168.msg1595435#msg1595435 date=1479912611
am here and have replied the email notification  went to my junk folder
ed12
« Reply #2195 on: November 27, 2016, 03:00:53 pm »
did u get the iso ?
if yes and u need more i will up-load them
if not your welcome
ed
gcwretrocade
  • Last login:November 27, 2016, 04:38:01 pm
« Reply #2196 on: November 27, 2016, 04:11:55 pm »
@ED12 we have a Ea Sports Golf Tour Team Challenge but the computer looks to be gone as we get no video signal after even replacing the video card. Will your new image work on a Dell Optiplex755?
mictas
« Reply #2197 on: November 27, 2016, 05:35:22 pm »
did u get the iso ?
if not your welcome
ed
hi i have got the rescue disc now thank you :-)
Spitfire
« Reply #2198 on: November 27, 2016, 05:51:55 pm »
did u get the iso ?
if not your welcome
ed
Pm sent mate
« Last Edit: November 29, 2016, 05:51:30 am by Spitfire »
ed12
« Reply #2199 on: November 28, 2016, 01:46:53 pm »
gcwretrocade
i just recieved your email today
no that board will cause winxp(e) to brak and ---smurfette---
ed
