Author Topic: Good tutorial on a shelf for a CRT  (Read 1600 times)
sdweim85
  • Last login:September 16, 2014, 09:30:03 am
« on: November 30, 2012, 12:02:59 pm »
Anyone have a link or know a good way to properly make a shelf for a CRT TV in a arcade cabinet.  Or does it just really come down to measure measure measure before you put it in.  That's gotta be the worst thing ever, if you finish the shelf and its off by a little bit.  But then again you can make your bezel higher or lower depending on if your off a bit.
  • Last login:May 21, 2024, 04:55:07 pm
Re: Good tutorial on a shelf for a CRT
« Reply #1 on: November 30, 2012, 01:45:19 pm »
If you're too low you can always add a board.  If you're too high then you have issues.
