Author Topic: .7z support in MaLa?  (Read 3381 times)
shstormont
  • Newbie
  • Last login:November 14, 2012, 06:41:56 pm
« on: November 14, 2012, 06:31:28 pm »
Does MaLa support roms wit a .7z extension?  I recently converted my collection from .zip to .7z and Atomic FE stopped working, so I tried to setup MaLa but it freezes on the "Collecting games screen".  Freezes isn't the correct work, as the MaLa process continues to run and the memory that it uses continues to rise.
Re: .7z support in MaLa?
« Reply #1 on: November 14, 2012, 07:41:02 pm »
I don't believe it supports 7z
If you run through the entire roms list XML, mala can take a good bit of time to process that.
I usually use RomLister instead to build a much filtered list, removing dupes, clones, adult, etc first
CpCaveman
  • Last login:January 06, 2018, 11:43:05 am
  • Contains 0% horsemeat , may contain BULL though :)
« Reply #2 on: November 20, 2012, 09:44:58 pm »
yup a lot of my roms are .7z `s they work ok first cabinet i`ve tried making but haven`t had a problem after i had to download a .7z unzipping file to try out templates
Hit something hard enough it should work, if it dont the result can always be called art :)
