Author Topic: Micro Tron arcade WIP  (Read 17395 times)
threedprof
  • Last login:April 21, 2016, 05:57:44 pm
Re: Micro Tron arcade WIP
« Reply #40 on: November 30, 2012, 05:08:16 pm »
More parts are beginning to trickle in.
Arcade projects
« Reply #41 on: November 30, 2012, 05:22:05 pm »
Badass!
threedprof
« Reply #42 on: November 30, 2012, 05:41:28 pm »
Badass indeed!  :afro:  Le Chuck, the Joystick should be coming in around monday.
forgot to post a pic of the lighting module
« Last Edit: November 30, 2012, 05:48:50 pm by threedprof »
Arcade projects
threedprof
« Reply #43 on: November 30, 2012, 06:37:59 pm »
3D coin door.  next in line to be sent off to the 3D printer
« Last Edit: December 01, 2012, 07:37:26 am by threedprof »
Arcade projects
Jigenjuke
« Reply #44 on: December 03, 2012, 10:02:09 pm »
Threedprof,
Awesome!  What did you pay for the tron shroud?  What is the coin door gonna run?
Love to hear about that.  Also looking forward to seeing this complete.
Jigenjuke
threedprof
« Reply #45 on: December 03, 2012, 10:49:51 pm »
Threedprof,
Jigenjuke
Thanks! The shroud came to $87 + shipping...getting another quote from a different 3D printer, currently.  The coin door was significantly cheaper at $14 + shipping.  comes with coin chutes and dummy coin mechs.  Mock quarters will be handmade that fit the coin chutes.  Again, I've sent all the parts to a local print shop and we'll see if I can get them cheaper
Arcade projects
threedprof
« Reply #46 on: December 04, 2012, 03:33:43 pm »
joystick came it and it was a perfect fit!!! Math is good.  Pics for your pleasure.  I have a second one on hand right now, if anyone would like to buy it.  The coin door kit is on the way, also
Arcade projects
threedprof
« Reply #47 on: December 04, 2012, 03:34:46 pm »
some of the artwork applied
Arcade projects
CoryBee
  • Bopity Boopy
« Reply #48 on: December 04, 2012, 04:22:44 pm »
That tron stick is so fudging awesome!  :applaud:
threedprof
« Reply #49 on: December 05, 2012, 12:52:28 pm »
Thanks very much!  It's always a joy to see a virtual object come to life in the physical world.  I'd love to get them reprinted in a blue transparent resin.  For whatever reason it's ridiculously expensive to do so.  Could be something I did incorrectly in the export process so I'll try again soon.  In the meantime, if someone has any thoughts on how I should fasten all the panels together I'm all ear.  I've tried little wooden blocks glued in but they can't take much stress.  I'm thinking tiny plastic corner braces of some kind.  A trip to Home Depot is in order.
Arcade projects
CoryBee
  • Bopity Boopy
« Reply #50 on: December 05, 2012, 05:49:36 pm »
I never though about combining 3-d printing and the arcade hobby. This is genius! I have a friend who has a really nice one he built and definitely going to be going over there to play with the thing. Opens a ton more of options when building miniature machines.
threedprof
« Reply #51 on: December 05, 2012, 06:30:22 pm »
It sure does! I was kicking aroun ideas and searching all over the place for micro parts when it hit me to just model and print them! Turned out to be the better option than hand fabricating.
Arcade projects
Bender
« Reply #52 on: December 08, 2012, 10:57:54 pm »
I used CA glue (crazy glue) on the Donkey Kong Micro and it's held up extremely well, in fact when I went back to change something I had to saw it apart because the glue was stronger than the MDF
threedprof: on an overall note this project looks amazing! It's so cool to see the 3D stuff printed, that shroud looks better than the one on my full size original!
« Last Edit: December 08, 2012, 10:59:27 pm by Bender »
threedprof
« Reply #53 on: December 09, 2012, 01:15:46 am »
It's coming along well. I've created a bunch of 90 deg. acrylic mounts and will be able to assemble/disassemble at will.  I thought about making it permanently assembled but worried about accessing the internals and destroying the cabinet.  The solution has to provide a strong sturdy joint.  I'll try 'em out and report back, of course.
« Last Edit: December 09, 2012, 09:27:42 am by threedprof »
Arcade projects
threedprof
« Reply #54 on: December 13, 2012, 06:12:43 pm »
I received the Coin door kits today! While inspecting the contents, I discovered there are missing parts *sad panda* I've written shapeways to find out if i can get replacements. then I discovered another issue...didn't leave enough clearance so the frame and door stuck together. Had to cut them apart so now it looks hacked!! I've redesigned the model so the parts have more clearance and also the tiny bits are connected so they'll be easier to find!
These are good guinea pig parts to run a fitment test and try out the dye/sanding process.
For now, here's the pics
Arcade projects
threedprof
« Reply #55 on: December 14, 2012, 08:15:56 am »
I've opened up a shop on Shapeways.com which has all the 3D printed parts I've posted here.  Feel free to browse around :)
http://www.shapeways.com/shops/ThreeDprof
Arcade projects
threedprof
« Reply #56 on: December 14, 2012, 07:06:56 pm »
Got around to dying the shroud and coin door.  Not much of an update, i know.  Still waffling around with how to get everything buttoned up.
Arcade projects
threedprof
« Reply #57 on: January 17, 2013, 03:37:54 am »
pics of the new coin door with coin mechs and slots
Arcade projects
Slippyblade
« Reply #58 on: January 28, 2013, 11:39:21 pm »
Just found this thread.  My god this rocks!  Tron was one of my favorite games in the day and it's awesome to see the love and attention going into this.  Hate to say it though, this mini has already cost you more than my full size MAME did.  Of course, yours LOOKS way better than my ugly beast.
Yvan256
    • Yvan256
« Reply #59 on: January 29, 2013, 03:01:51 am »
Didn't notice this build before... It really deserves the "micro" name, an amazing build so far and a good example of integrating 3D printing into a design!  :cheers:
Mungo9000
  • Last login:August 25, 2016, 09:18:21 am
« Reply #60 on: January 30, 2013, 01:05:52 pm »
Amazeballs!  :applaud:
I have two completed mini's and another one on the drawing board but the build quality on this is putting mine to shame.
Time to up my standards methinks.
Jigenjuke
« Reply #61 on: March 10, 2014, 09:04:16 pm »
Progress Bump?  This deserves to be completed.  Get to it  ;D
Jigenjuke
