Author Topic: New I-PAC, J-PAC Enhancements  (Read 2635 times)
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« on: November 10, 2012, 02:56:59 pm »
All I-PAC,  J-PAC and Mini-PAC boards now being sent have several enhancements.
For the first time they support sleep/wake, so PC power control is possible from the control panel. Also support mouse buttons on any connection.
The full list of changes is:
•   Any input can be selected as a left or right mouse button in addition to keyboard keys (including shift combinations invoked by holding Start1)
•   Any input can be selected as power off, sleep or wake (including shift combinations)
•   Any input can be selected as volume down or up  (including shift combinations). Holding the button causes volume to gradually increase/decrease
•   WinIPAC programming no longer requires a driver when used in USB mode so install in Windows 7 is cleaner.
•   Improved reliability of download in PS/2 mode.
•   Pause key now supported (useful for visual pinball)
A new version of WinIPAC is required for these enhanced boards. This is already downloadable from www.ultimarc.com/download.html
The new version is backward-compatible with older boards (without power and mouse functions) and no settings are required to be changed when using old or new boards with it.
The hardware is unchanged but unfortunately the addition of the extra USB endpoints for power control and mouse mean the firmware cannot be field-upgraded unfortunately because the base "permanent" USB code changes.
andy@ultimarc.com
cmoses
« Reply #1 on: November 10, 2012, 06:12:32 pm »
Does the new software work with an older board to control volume?  I have a mini-pac that I'd a few years old and would like to be able to use the volume feature.
AndyWarne
    • Ultimarc
Re: New I-PAC, J-PAC Enhancements
« Reply #2 on: November 11, 2012, 11:35:55 am »
Depending on the age of the board we might be able to upgrade it but would mean sending it here.
Andy
arzoo
  • Robots WILL kill you.
    • LEDBlinky
« Reply #3 on: November 12, 2012, 08:18:41 am »
Robots will kill you.
Arcade Addiction
Paladin
  • Mmmm llamaburgers!
« Reply #4 on: November 12, 2012, 10:10:44 am »
Kudos to you sir, for continuing to spend time and money on R&D for an already fantastic piece of hardware!
Aurich
  • Last login:September 12, 2021, 01:34:32 am
« Reply #5 on: November 12, 2012, 02:33:42 pm »
Perfect timing, I need to order a new I-PAC.  :angel:
Beast96GT
  • Last login:December 31, 2012, 03:55:12 pm
« Reply #6 on: November 12, 2012, 03:05:22 pm »
Ack!  I just got my I-Pac4 in from you a couple of weeks ago, is it possible to trade it back so I can get the mouse functionality?  Thanks.
J. Chris
AndyWarne
    • Ultimarc
« Reply #7 on: November 12, 2012, 05:38:13 pm »
J. Chris
Yes we can do this for just the cost of return postage. Drop me an email:  andy@ultimarc.com
robe_uk
  • Last login:December 26, 2013, 03:21:48 pm
« Reply #8 on: November 13, 2012, 04:49:28 pm »
 :hissy: pity I bought a mini pac just a few weeks ago from gremlin solutions, didnt realise you where also based in UK ::)
rob
ps: am in no way bashing gremlin solutions, great service.
