Author Topic: Happs trackball: Why the green grounding wires?  (Read 1049 times)
Mugzilla
  • Last login:May 23, 2020, 03:25:47 pm
  • Negative Ghost Rider,...
« on: October 16, 2003, 11:27:51 pm »
I installed my highlip happs trackball. The green ground wires that connect to the outside of the case in 2 places are NOT connected.
In fact, since I had to uninstall the trackball to change the ball, I took the ground wires off completely,... and it still works. Are they there for a reason? Part of some super secret circuit? Static electricity grounding?
grafixmonkey
  • Last login:October 16, 2010, 08:16:50 pm
  • must... tear self... away from... Tron...
    • My graphics/arcade/circuits site!
Re:Happs trackball: Why the green grounding wires?
« Reply #1 on: October 16, 2003, 11:35:10 pm »
I was wondering the same thing.  Maybe I'll call Happ about it.  Mine isn't connected either, and it's working.
-- See my grafix, circuits and cab on my
-- new arcadey page:  http://www.bkgrafix.net
Edgedamage
  • Last login:October 06, 2018, 12:21:23 am
« Reply #2 on: October 17, 2003, 12:25:24 am »
I had asked a couple of tech's about that green wire and they said it is just a safe way to get rid of any static build-up. Safer to channel static to ground than having it zap the opto boards.
Curls in the squat rack !?!?!
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #3 on: October 17, 2003, 01:02:39 am »
And if I recall Happ is the only one with grounding wires.
Syntax
  • Last login:November 23, 2003, 07:57:37 pm
« Reply #4 on: October 17, 2003, 01:12:38 am »
In most cases grounding is not needed. Its just a safety feature. I wouldn't worry about it not being connected.
« Last Edit: October 17, 2003, 01:13:03 am by Syntax »
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #5 on: October 18, 2003, 01:12:05 am »
FWIW, my 3" Betson also has a grounding wire.  My wico 3" and 2 1/4" don't.  [shrug] I haven't hooked the grounding wires, but I don't have a carpet floor and 100 people using the TB, building up that much static.
Robin
Knowledge is Power
grafixmonkey
« Reply #6 on: October 18, 2003, 01:26:11 am »
Maybe the grounding wire is just in case somebody comes up and rolls the trackball using rabbit fur gloves in the middle of winter.
