Author Topic: Single button quick save / quick load in MAME  (Read 16151 times)
kenno
  • Last login:October 28, 2012, 03:38:53 am
« on: October 10, 2012, 01:58:13 am »
Hello,
I have been looking around a few forums trying to figure out how to get quick save / quick load working in MAME.
I can save / load using the default buttons but they prompt for which slot to save to / load from.
Is there something I'm missing in the configuration or something that can be modified within MAME to be able to do a quick save / load?
Thanks,
Ryan
Venomouse
  • Last login:September 12, 2013, 09:54:40 pm
Re: Single button quick save / quick load in MAME
« Reply #1 on: November 07, 2012, 05:58:44 am »
I have my system setup with two keys mapped (1 button for save) always saves to slot 1) and one button to automatically load from slot one.
Press tab for settings >
Input General >
user Interface >
Set the Save state and Load state buttons here.
hope that helps Though I've probably missed what you meant :)
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
« Reply #2 on: December 02, 2012, 04:16:07 am »
you still need to press button 1 on the keyboard to save/load :(
how do you compile mame to set one quickload save and load?
  • Last login:January 29, 2026, 12:04:48 pm
« Reply #3 on: December 02, 2012, 09:15:16 am »
I usually link to Mr. Do's compiling guide, but the site that hosts it is down temporarily.
You can try Headkaze's MAME compiler:
http://www.headsoft.com.au/index.php?category=mame&page=mc64
The changes will need to be made to the source code by hand before compiling.
equlizer
« Reply #4 on: December 03, 2012, 08:03:58 pm »
Thank you for the help but.....I dont know code so i have no idea what to add and where to add it too when re-compiling :(  I also want Z axis added as well.
byancey
  • Last login:October 07, 2023, 03:11:17 pm
« Reply #5 on: January 10, 2015, 09:52:10 pm »
I realize this is an old thread, but I just ran into this issue myself on MAME v0.154.  There's still no support in MAME for a quick-load/quick-save function that is suitable to map to a single button on a control panel.   Since I build MAME from source, I went ahead and added support for this myself.  This effectively adds 3 load buttons and 3 save buttons that map to slots 1, 2, and 3 (same as hitting F7 followed by 1, 2, or 3 to load or SHIFT-F7 followed by 1, 2, 3 to save).  They are assigned to keys 1, 2, 3 and SHIFT-1, SHIFT-2, SHIFT-3 by default, but can be changed from the mame key mappings (TAB button menu).
I've attached a patch file with the changes.  The patch file is based on v0.154 of mame.  Thought this might be useful for others who have the ability to re-build MAME themselves.  Even if you can't apply the patch directly, the changes are fairly easy to understand if you are familiar with C/C++.
« Last Edit: January 10, 2015, 10:00:03 pm by byancey »
vaderag
  • Last login:May 07, 2025, 11:33:07 am
  • Building my own cab :)
« Reply #6 on: November 02, 2022, 07:10:08 am »
Okay, really REALLY old thread but I'm going around in circles here...
I DEFINITELY had MAME saving with one button F5 and loading with F6 without any input for a number previously.
I don't recall compiling a new version of mame for this, yet I've just re-started building my cab and I can't find out how to do this... I don't think I used an AHK script either as I didn't ever see the popup
I've found a few threads on this (below) but no clear answer...
http://forum.arcadecontrols.com/index.php?topic=123140.0
http://forum.arcadecontrols.com/index.php?topic=114190.0
http://forum.arcadecontrols.com/index.php/topic,33233.0.html
Can anyone advise how to do this in the latest version of Mame?
