Author Topic: Groovymame and Playchoice 10 games  (Read 7473 times)
yakk11
  • Last login:April 23, 2025, 11:52:20 pm
« on: October 07, 2012, 09:33:53 pm »
I'm trying to get these running with my HD4670.  When I start Super Mario Bros. 3 or any other game i get a fatal error.  I have attached a log from smb3.
Any help?
Calamity
  • Moderator
  • Last login:Today at 03:55:32 pm
  • Quote me with care
Re: Groovymame and Playchoice 10 games
« Reply #1 on: October 08, 2012, 01:55:55 pm »
Hi yakk11,
Thanks for the log. However, it looks absolutely normal. Does the fatal error happen when exiting the game? Does it crash or something?
Steps to create a log:
yakk11
« Reply #2 on: October 23, 2012, 09:29:13 am »
I can load the games just fine using MAMEUI 64bit outside of hyperspin using the single screen setting in the playchoice BIOS. When i try to load one via hyperlaunch/hyperspin, i get a window that pops up saying "AutoHotkey.dll Mame error - Fatal Error. I am running groovymame .145, if that helps.
yakk11
« Reply #3 on: November 01, 2012, 07:07:40 pm »
Anything to add to this?
yakk11
« Reply #4 on: November 05, 2012, 10:26:12 am »
I just updated to .146u5 64bit build. Now the screen just goes black.
Calamity
  • Moderator
« Reply #5 on: November 05, 2012, 11:44:30 am »
Hi yackk11,
I *think* I managed to reproduce your issue here. It happens when you play a multiple screen game full screen (just 1 full frame per monitor) and has to do with the multithreading implementation in GroovyMAME that's only targeted for single screen setups.
It works for me if I use these params:
groovymame pc_sm3 -numscreens 2 -nomt
Let me know if this makes any sense (I'm not using HS here so I have no clue what the "AutoHotkey.dll Mame error - Fatal Error" is about).
yakk11
« Reply #6 on: November 07, 2012, 08:16:25 pm »
I tried that.  It worked.  I wonder why it can't load via hyperspin...
senorchris
  • Last login:March 14, 2016, 11:57:10 pm
« Reply #7 on: November 10, 2012, 04:42:26 pm »
Unzipping the attached .ini into your groovymame directory should enable Calamity's settings for all Playchoice 10 games, so the settings will be sucked up when you start them from Hyperspin.  I now get an actual screen, with music (instead of just the black screen I was getting before).  Unfortunately, when I coin it up - the screen goes black.  I wonder if it's because MAME is choosing to emulate the "select a game" screen rather than the actual game itself, if these cabinets had two screens to render.
yakk11
« Reply #8 on: November 20, 2012, 06:29:02 pm »
step in the right direction!
Calamity
  • Moderator
« Reply #9 on: November 20, 2012, 06:34:40 pm »
Apart of those settings, try either: -screen0 \\.\DISPLAY1       or     -screen1 \\.\DISPLAY1
One of those should make MAME focus the game screen on to the real monitor.
yakk11
« Reply #10 on: January 17, 2013, 09:21:38 pm »
Any progress on this?  Would love to start playing some Mike Tyson's Punch Out!!   :D
dgame
  • I am no Jedi
« Reply #11 on: January 18, 2013, 12:03:33 am »
You have to press the Play Choice 10's 'Enter' button After you coin up.
MAME defaults to the minus "-" key on the keyboard for the Play Choice 10's 'Enter' button.
If you let the timer run out the screen will go black again and you have to press the 'Enter' again after you coin up.
The timer is on the top screen which is invisible if you have focus set to the bottom screen on a single screen system.
Occasionally drop credits to keep the timer from running out.
The MAME Cheat file allows infinite time so you can play without worrying.
The screen going black after coin up is not a GroovyMAME specific issue it applies to MAME as well.
« Last Edit: January 18, 2013, 02:19:29 pm by dgame »
yakk11
« Reply #12 on: January 28, 2013, 11:43:38 am »
I will give this a shot tonight.  Thanks!
yakk11
« Reply #13 on: January 29, 2013, 07:03:49 pm »
This works!  Thanks!  Do you know if there is a way to auto load that cheat every time the rom is opened?
