Author Topic: Floriske.nl's "evo XR cade" xbox bartop (DONE, FINISHED, FINITO!)  (Read 120865 times)
Boxxle
  • Last login:July 17, 2020, 12:12:18 pm
Re: Floriske.nl's "evo XR cade" xbox bartop (DONE, FINISHED, FINITO!)
« Reply #200 on: February 10, 2014, 06:19:22 pm »
Just a quick question.  How did you power your component > vga adapter? Drawing from the xbox psu?
« Last Edit: February 10, 2014, 08:03:10 pm by Boxxle »
floriske.nl
« Reply #201 on: February 11, 2014, 02:11:14 am »
Indeed.I added a simple molex splitter between the hdd power connector.
Took off one connectors so I could run the wires through the fan cover.
dexter87
  • Last login:June 05, 2014, 07:31:50 am
    • Come Informatica
« Reply #202 on: February 12, 2014, 09:05:23 am »
First of all compliments for your project ! I follow this for my bartop (pc bartop) and if i can i want ask you a thing: where can i find the small buttons (power,exit,eject) ?
I  searched on many shop + ebay but can not find them :embarassed:
JDFan
« Reply #203 on: February 12, 2014, 09:47:54 am »
Ebay has these listed : ( http://www.ebay.com/itm/5pcs-3A-125V-1A-250V-Momentary-SPST-N-O-BLACK-Round-Cap-Push-Button-Switch-2929-/291043694872?pt=US_Surveillance_Cables_Adapters_Connectors&hash=item43c38e5918 ) $8 shipped for 5 switches.
dexter87
    • Come Informatica
« Reply #204 on: February 12, 2014, 10:31:54 am »
Had not seen them, thanks 1000  :notworthy:
Only another thing: if I'm not mistaken happ buttons require holes from 28mm right?
« Last Edit: February 12, 2014, 10:49:30 am by dexter87 »
floriske.nl
« Reply #205 on: February 12, 2014, 10:48:39 am »
Those are the buttons indeed.
I used 29mm holes for the happ buttons, but 28 is advised.
JDFan
« Reply #206 on: February 12, 2014, 10:54:27 am »
Happ button holes are 1 1\8 inch or 1.125inches which is equivalent to 28.575mm - so 28mm sounds about right (better slightly smaller @28mm than slightly too big @29mm )
dexter87
    • Come Informatica
« Reply #207 on: February 12, 2014, 10:59:04 am »
Thanks  ;)
Thanks, and compliments again, for me your bartop is perfect for 2 player, love the CP  :applaud:
carlosboccadoro
  • Last login:November 12, 2024, 01:22:00 am
« Reply #208 on: March 25, 2014, 03:00:41 pm »
Hello Floriske.
Magnificent work.  :cheers:
Worthy of praise, very delicate and precise.
You'd be so kind as to show a shorter video of its operation, especially control panel and lights.
Thank you very much.
Carlos.
damageinc86
  • Last login:November 29, 2025, 03:24:58 am
« Reply #209 on: June 17, 2015, 03:20:13 am »
I found this thread while doing a google search and I absolutely love this cab! Amazing work!  Was curious if you have the CP and Marquee artwork in a photoshop file or some tips to getting that layout printed?
