Author Topic: Kortek K1-2-V0 monitor no pic  (Read 3591 times)
kardenm
  • Last login:June 13, 2019, 09:14:35 am
« on: October 02, 2012, 02:36:58 pm »
Need some help.
I have a Kortek K1-2-V0 which collapsed to a horiz white line then to no picture at all (blank screen).
High voltage IS present (aprox 20,000 KV).  I replaced Q402 (the HOT) but no change.
Yoke resistance is 2 ohms and 50 ohms per spec.
Can someone tell me the most likely cause of this problem or what I should check next?
In theory, there is no difference between theory and practice, but in practice.....there is!!
ed12
Re: Kortek K1-2-V0 monitor no pic
« Reply #1 on: October 02, 2012, 11:55:31 pm »
hi
chk your b+'s
make sure u have 12-20vdc to your
vert ouput ic
start there
ed
kardenm
« Reply #2 on: October 08, 2012, 03:11:41 pm »
Thanks ed12.  I'll check it out.
kardenm
« Reply #3 on: October 09, 2012, 01:47:13 pm »
RE: ed12.
B+ comming out of the power supply is 118vdc.
Not sure where to check voltage to the "vert output ic". ??
lilshawn
  • Last login:Yesterday at 08:10:20 pm
« Reply #4 on: October 09, 2012, 02:51:13 pm »
vertical output IC should be somewhere attached to a heatsink. most are flat and have about 10 pins on them.
http://www.electronicrepairguide.com/monitor-horizontal-lines.html
kardenm
« Reply #5 on: October 11, 2012, 04:00:47 pm »
Thanks lilshawn.  Good information!
This board has a combined vert/horiz ic (ic 401, HA11235) soldered directly to the board (no socket).  I do have a spare and can swap it out.  Do you think I need to try that?
Voltages on the vert side are:  pin1=3.2, pin2=1.1, pin3=3.2, pin4=3.8, pin5=7.2, pin6=11.7, pin7=5.2, pin8=5.3.
lilshawn
« Reply #6 on: October 11, 2012, 08:17:59 pm »
That is a sync processor. it separates the sync and supplies horizontal and vertical pulses to the appropriate systems.
http://pdf1.alldatasheet.com/datasheet-pdf/view/63433/HITACHI/HA11235.html
it could be used to directly drive the vertical... I'd check backwards from the yoke for any burned components or bum capacitors. check resistors for burns or evidence of being hot. if all looks good, go ahead and replace the 11235 and see if it's go.
if it doesn't immediately fire up after changing the 11235 then kill it and start looking some more... you have a chance of killing the 11235 .
ed12
« Reply #7 on: October 11, 2012, 08:58:18 pm »
hi
not to step on toe's here
but ha11235 is a pre drive ic
there should be 2 vert out transistor's as per this pdf
and a small driver transistor
the nick need's to chk cap's and pay attenion to a .1mf at 16v tataliumin it must be that spec
also yes work backward's from the yoke
reason we say this is so u do not burn a line in your tube
do your chk's fast
ed
kardenm
« Reply #8 on: October 12, 2012, 10:11:37 am »
Thank you both lilshawn and ed12 !  Really appreciate the suggestions and the links.
I'll do some more checking.
ed12. What is a "nick"  :)
ed12
« Reply #9 on: October 12, 2012, 12:06:40 pm »
hi
kardenm is your nick=name
ed
lilshawn
« Reply #10 on: October 12, 2012, 02:30:14 pm »
does "OP" make more sense to you?  ;D
kardenm
« Reply #11 on: October 16, 2012, 12:35:33 pm »
Ha Ha.  I know what OP means!!
