Author Topic: Mounting sanwa JLF in Dynamo HS5  (Read 1209 times)
MAME TIME
  • Last login:March 23, 2019, 10:23:19 pm
« on: September 12, 2012, 11:48:52 pm »
Just finishing up on my cab and i picked up some JLF's, i wanted to under mount them in such a way that that you cant see the bolt on top of the panel, any suggestions? thx in advance
Too Much Game, check out my ish!!!
Geometry Arcade
Neo Geo 360
MK2 standup
SF2 champ edition X2
mgb
  • North East, US
Re: Mounting sanwa JLF in Dynamo HS5
« Reply #1 on: September 13, 2012, 12:01:30 am »
The dynamo hs-5 control panel should have threaded mounts, the problem is that they are for a standard joystick mounting plate and the jlf has a smaller plate.
So you would have to try and adapt that plate to a standard size.
I thought there were adapter plates available but I can't find them now.
Maybe you can grind off the existing studs and have a welding shop put on new threaded studs.
