Author Topic: Removing buttons from a Tankstick  (Read 1726 times)
swindmiller
  • Last login:July 31, 2014, 08:23:51 pm
« on: July 13, 2012, 08:15:43 pm »
I am a newbie that built his first arcade and went with a Tankstick. I am getting an overlay graphic and want to remove all the buttons and joysticks when I apply the graphic. I have loosened all the buttons but want to know the best way to remove them. How does the sensor (or whatever it is) come off of the actual button? I just don't want to break anything and is this the way you remove the buttons.
Thanks,
Mat
  • Last login:April 18, 2013, 01:27:14 am
Re: Removing buttons from a Tankstick
« Reply #1 on: July 13, 2012, 08:29:36 pm »
First remove the switches from the bottom of the buttons.  Then unscrew the nuts from the bottom of the buttons.  It's a good idea to label the switches before you remove them so you know where to reconnect them later.
swindmiller
« Reply #2 on: July 13, 2012, 09:18:58 pm »
Thanks!! Do the switches just pull off? I am afraid of breaking them...is there a trick.
Thanks,
lilshawn
  • Last login:January 26, 2026, 07:56:08 pm
« Reply #3 on: July 14, 2012, 02:39:25 am »
  • Last login:Today at 12:04:48 pm
« Reply #4 on: July 15, 2012, 11:59:35 am »
Just an FYI while you have it apart.  If you ever wanted just one more button, the tankstick has an extra input for the middle mouse button that isn't used.  I added a dedicated exit button: http://forum.arcadecontrols.com/index.php?topic=100885.0
