Author Topic: CD-100C won't play a CD  (Read 1952 times)
flipnout1
  • Last login:July 11, 2012, 10:27:56 am
« on: June 30, 2012, 03:24:07 pm »
OK I fixed my original problems of not picking up a CD and now it does that fine.  However it won't play one.  I have known good CCC and Mech/Decoders in the box now thanks to Bruce Wentworth.
I put some new CD's in and went to initilize them and the box went through them all but doesn't recognize any.  Once it finished and I tried to play a Cd it said not allowed.  The CD was only on the player for about 5 seconds for each one.  At this point I'm assuming the CD Player is bad.  Anyway to check it out?  It is a CDM3 Player.  Where can I get a reasonably priced replacement?
Larry
ed12
Re: CD-100C won't play a CD
« Reply #1 on: June 30, 2012, 05:25:21 pm »
hi
if all else fail's i have a few used cdm3
the cdm3 from nsm are old  are old philip's unit's
john's juke >www.flipper's.com<
has stock,it may be nos or he may tell u to do the same i am going to
go find a cdm4,it will hook right in
if u turn the cm3 player over and look at the pc board
u will note ALOT of heat damage,that is because the spindle ic pack's it in
and take's the laser with it
the unit is pushing 20year's now
the cdm4 is pushing 15year's
also starburst in toronto canada may have a few left ?
most op's upgraded to cdm5
ed
lilshawn
  • Last login:Yesterday at 12:11:01 pm
« Reply #2 on: July 06, 2012, 07:08:51 pm »
if by reasonably priced you mean if you can find a laser unit for one for under $300 then no.
Iv'e sold several of these. Most people buy them to replace broken cd units.
http://forum.arcadecontrols.com/index.php?topic=110942.0
