Author Topic: Joystick, button pack advice  (Read 2414 times)
mrtim30
  • Last login:September 03, 2022, 09:12:38 am
« on: June 17, 2012, 02:31:10 pm »
Hi all,
        Im starting my build in the next few weeks and saw this on ebay. Is this an ok deal and are the products of an ok standard. I dont have the money for 2 ultrasticks and buttons etc at the moment so I was thinking of grabbing something like this.
_http://www.ebay.co.uk/itm/ARCADE-JOYSTICKS-BUTTONS-KIT-IPAC2-WIRING-/370508411372?pt=UK_Video_Games_Coin_Operated_MJ&hash=item564405b1ec#ht_5240wt_1313
mrtim30
  • Last login:Today at 01:45:12 pm
Re: Joystick, button pack advice
« Reply #1 on: June 17, 2012, 03:38:29 pm »
The idea of them including 32 pre-crimped wires and the daisy-chain ground sounds pretty good.
Looks like they include Zippyy joysticks which many people use as an inexpensive LS-32 alternative.
The two things that combine to make me nervous about this "deal" are:
1. They are very specific on the I-Pac and talk about that at great length.
2. Joystick, button and switch manufacturers/specs are unspecified beyond "Similar to Happ standard buttons", "Buttons fit a 28mm mounting hole", and "4cm long shaft - 2, 4 & 8 way adjustable".
Have you checked to see if you can get a similar or better deal from Andy at Ultimarc, Gremlin Solutions, Randy at GGG or Bryan at Paradise?
It may not be as convenient, but investing a little time to find components that you will be satisfied with may be better, and less expensive, in the long run.
capsule
  • Last login:June 22, 2013, 12:05:13 pm
    • caps:arcade
« Reply #2 on: June 17, 2012, 03:42:42 pm »
If you want it cheap, just buy the joysticks and buttons. Make the wiring yourself and hack some gamepads. The most expensive part of this lot is the i-pac 2. If you're located in Europe, I recommend http://www.gremlinsolutions.co.uk, prices are OK and the shipping is (very) fast!
  • Last login:Today at 10:22:04 am
« Reply #3 on: June 17, 2012, 04:04:58 pm »
Gremlin Solutions is the same as the eBay seller in post 1. Looking closely at the joystick washers, those sticks look like Seimitsu LS-32's.
Edit: looks like these http://www.gremlinsolutions.co.uk/products/ssjoystick1.htm
« Last Edit: June 17, 2012, 04:09:56 pm by emphatic »
capsule
    • caps:arcade
« Reply #4 on: June 17, 2012, 04:51:07 pm »
Ah, true, well spotted, I didn't notice their customer support phone numbers were the same ;-)
« Reply #5 on: June 17, 2012, 05:45:03 pm »
Good catch on the phone #.   :applaud:
I agree with your edit link.  99.9% sure that's a Zippyy.  They come with those same red/black switches.
Looks like the buttons use these switches: http://www.gremlinsolutions.co.uk/products/yennoxmicro.htm
Bad News: The only down side that I see is that Gremlin Solutions doesn't list button manufacturer or switch specs on their site.   ???
Good news:  Buttons are cheap and easy to replace if you don't like them.
P.S. You might want to consider using some of these to upgrade those Zippyys.
mrtim30
« Reply #6 on: June 19, 2012, 04:14:43 pm »
Thanks guys. Ive decided not to cheap out. Im going to buy an ultrastik and 8 buttons from Andy and then next month get another one. Starting my build on Tuesday so must get my order in before he goes on holiday
