Author Topic: Cute Lowboy arcade  (Read 19192 times)
Dr.Strangelove
  • Last login:January 07, 2013, 01:06:54 pm
Cute Lowboy arcade
« on: June 07, 2012, 07:44:09 am »
Hey everybody! I wanted to share the arcade I'm making, it's my second ever. I designed it to be similar to most lowboys, except much smaller to fit in my small rec room. It's about 48'' high, 23'' deep and 20'' wide. All visable seams are mitered, just so I wouldn't have to deal with painting side grain on MDF and the long process of getting it smooth. While it does look nice, I don't think I'll do it again, it's quite a frustrating endeavor! Next to do is level the gables again and cut the slot for t-molding. Unfortunately the gables got water damaged and swelled up and were very mushy. Using a trick somebody told me, I sanded it down and then solidified it with superglue. I had my doubts but it worked like a charm! Unfortunately I was a little bit overzealous with a sander while taking it down and it ramps down towards the bottom, usually I wouldn't concern myself with this. Sadly since it's about 1/32-1/16 and near the front edge I think it may be noticeable once t-molding is on since the plastic will stick proud
Front view
Side View
Close up of the bezel and play area.
GregD
  • Last login:December 19, 2024, 04:27:31 pm
    • Arcade Nebula
Re: Cute Lowboy arcade
« Reply #1 on: June 07, 2012, 08:33:38 am »
I like it.  Clean lines.  Nice lighting in your shop by the way.
Vidiot
  • John 3:16
« Reply #2 on: June 07, 2012, 12:24:39 pm »
Very nice!  :applaud: I really like the look of the lowboys. I'm looking forward to seeing more. Any idea what artwork you'll be using?
« Reply #3 on: June 07, 2012, 03:32:34 pm »
I'm a big fan of that design.  Looks like it's coming together very cleanly.   :applaud:
Dr.Strangelove
« Reply #4 on: June 18, 2012, 10:52:40 pm »
A small update! Things are going pretty smoothly on this. I bondo'd the step down on the one edge until it was nice and flat again. It was quite a bit of feathering, since it goes from nothing all the way to almost a 1/16th over 8 inches! I also routed a small little channel offset from the perimeter of the cabinet. I did it with a template and straight cut bit in a router with a templating sleeeve. It was a bit scary sometimes, since I knew I would have to slow down a lot at a few tight corners. There's not a lot left to do build wise now. I just need to finish the control panel acrylic, put a shelf in, and a few vent holes and fill some nail holes!
Actually, it's not my shop, but a volunteer ran woodworking co-op. So I do have access to a few nice tools. Although, fancy tools don't always mean good work!
I had planed to make this cabinet for around when SkullGirls was released. Keeping with their theme, I was going to go with something very art deco.
quintinbiker
  • Last login:September 27, 2012, 12:47:18 am
  • Go big or go home
« Reply #5 on: June 19, 2012, 01:07:06 am »
Looks very good i like it
Life is your game
How you win determines your score
How you loose determines your credits
But to play the game you have to have real credits.
That's why I'm
GAME OVER
LIVE TO RIDE
RIDE TO LIVE
Biker born, Biker Bread, When I Die I'm Biker Dead
  • Last login:Today at 09:30:53 am
« Reply #6 on: June 19, 2012, 01:48:12 am »
NIVO
« Reply #7 on: June 19, 2012, 07:35:03 am »
outstanding work so far. ill be expecting all the woodwork paletted and sent over.  ;D
Woodshop Flunky
« Reply #8 on: June 19, 2012, 10:57:55 am »
Very clean!  Love the size and that extra detail on the sides is awesome!
Going to have to follow this one!  :cheers:
BTW... I'm jelous of your shop's floor space! :)
Vidiot
  • John 3:16
« Reply #9 on: June 19, 2012, 11:04:53 am »
The more I look at this the more I want to build one. The finish on your woodworking looks so clean. It almost looks like plastic. You're doing a fantastic job.  :cheers:
RyoriNoTetsujin
  • Last login:March 23, 2024, 03:55:45 pm
« Reply #10 on: June 19, 2012, 11:25:46 am »
Really clean. Nice, nice work. That's going to be a lot of fun when it's done!
Soon as I (finally) put the finishing touches on my hybrid cab, I think a buddy and I are cobbling a PC together and building a lowboy for his beach house down in Asbury Park. I'm definitely following your progress!  :cheers:
« Reply #11 on: June 19, 2012, 03:20:56 pm »
Me likey.  :applaud:
ataruzzolo
  • Last login:September 22, 2024, 06:38:58 am
« Reply #12 on: June 19, 2012, 04:12:40 pm »
Superb!
Razzer
  • Last login:June 26, 2020, 07:29:50 am
« Reply #13 on: June 21, 2012, 04:16:55 am »
Hi,
It looks really great. I really like the design.
Do you by any chance have some detailed measurements/sketches of this cabinet that you could post? (mainly the side panels)
This would be helpful in recreating the design.
Razzer
Dr.Strangelove
« Reply #14 on: December 14, 2012, 12:42:01 pm »
Whoa! Long time no update!
Well what to say, I progressed really far from last time I posted. All the doors were hung and operate nicely with latches and push opens. I elected to put a large radius on the MDF, rather than t-molding due to cost concerns and that the tight radius may not take the t-molding so well too. Finally painted the thing too, I wanted something with a darker shade, but I like the colour and how it gives it a faded paint or vinyl  look. The white detail really makes it pop too! So far everything is about 90% done. I still need to place one speaker in, do some touch ups, and finally make a marquee. The system inside is a Sega Naomi I purchased at a garage sale of all things. To my surprise, it worked, despite the built up dust on it and even some rock salt. It just needed a little cleaning, the notorious cap replaced and new case-fans too.
SpaceHedgehog
  • Almost done ...
« Reply #15 on: December 14, 2012, 03:27:11 pm »
If I had enough room, I'd make one just like that. Beautiful shape. Very nice indeed.
Click a pic for a video tour
Louis Tully
« Reply #16 on: December 14, 2012, 03:46:48 pm »
« Last Edit: February 12, 2015, 03:09:01 pm by Louis Tully »
« Reply #17 on: December 14, 2012, 03:54:19 pm »
Sweet! :cheers:
popsicle
  • Last login:July 14, 2025, 04:12:35 pm
« Reply #18 on: December 14, 2012, 05:26:13 pm »
Very, very nice indeed!   :applaud:
Eldritch1969
« Reply #19 on: December 15, 2012, 03:29:23 am »
Very nice build, however I have always wondered whether the monitor angle is suited for it if you play seated and not standing up
chopps
  • Last login:December 03, 2024, 09:29:20 pm
« Reply #20 on: December 15, 2012, 11:42:21 am »
very nice!!  :notworthy:   love these lowboys!
Dr.Strangelove
« Reply #21 on: December 16, 2012, 02:31:18 am »
Thanks for the praise everybody, it's been a long project but I'm glad about the end result. I really learned a lot about ergonomics and plastic work too. Although, I always like to learn, and if anybody has suggestions, please say so! Even if there are some parts I don't like about it, I'm  going to take what I learned for another  "cute cab", for more arcade games I have, mainly the older ones that don't use the JVS standard, and need a converter to work with an LCD or CRT. It's not very puritan, but I'm only just starting a collection, and can only afford to make my own cabs
Speaking about ergonomics though,
To answer, it can work with sit down stools, but the viewing angle makes the colours a little dark thanks to it being a LCD. I'm sure if you used my design adapted for a CRT, it would be near perfect for sit down and stand ups.
Finally, a little bit of an inside shot, I'm only just learning wire management, so it may not be the neatest of all things out there. It does how ever show the neat internals of an arcade
Eldritch1969
« Reply #22 on: December 16, 2012, 05:43:41 am »
Yeah, I suppose it would be ok for a CRT. Anyway, your build is really gorgeous!  :applaud: :applaud:
Acids
  • Last login:Today at 08:59:06 am
  • Bring It.. Smart arse!
« Reply #23 on: December 18, 2012, 05:40:10 am »
Wow looks sharp   :notworthy: :cheers:
do you have plans with dimensions you would like to share???
surface tension
  • Last login:July 01, 2018, 08:45:48 am
  • feel the tension...
    • surface tension tables
« Reply #24 on: December 18, 2012, 05:52:20 am »
Really nice looking cab! The side detailing works very well.
At that orientation, you're probably viewing the LCD's worst angle, which would explain the murky colours. A 178 x 178 viewing angle would sort that out.
Dawgz Rule
  • Last login:August 22, 2024, 07:18:55 pm
  • The more people I meet, the more I like my dogs
« Reply #25 on: December 18, 2012, 06:38:56 am »
Love the detail and the clean, clean, look.  This is sharp.  Finish looks great too.
spystyle
« Reply #26 on: June 12, 2014, 06:42:36 pm »
Love it :)
Gatsu
« Reply #27 on: June 13, 2014, 01:08:56 am »
 :woot
Dude that is sweet. The cab is nicely done, AND a Naomi system. I'm so JEALOUS!
