Author Topic: NSM Wall Mounted stopped working  (Read 14281 times)
kev236
  • Last login:May 23, 2012, 03:51:44 am
« on: May 13, 2012, 09:17:53 am »
Hi
I'm having problems with my NSM Country Classic 50 Disc Jukebox, everything was working perfectly until today, it had been on for about 20 minutes i selected a few tracks to play the first one played then i noticed there were no credits remaining so i opened it up and pressed the credit button a few times, closed the door then selected a few tracks the first of which was on CD 32, i walked away but noticed after a few minutes it wasnt playing, i went back and selected CD 32 again and it said on the display "Sorry title selection failed, title currently locked out" if i try to play any other CD it loads it up but then returns it and says "No valid disc found!" all the discs are genuine discs and have all played with no problems before. Only other info i can give is that this is the first time i have let the credits run out i usually top them up when they get under 10 but didnt notice this time.
Any help much appreciated
Kev
ed12
Re: NSM Wall Mounted stopped working
« Reply #1 on: May 13, 2012, 01:11:15 pm »
hi
kev236
a few thing's here will cause that problem
use the throuble-shotting guide
place the machine in service mode >key-on<
and chk the way the cd-platfourm is working
ie load a disk unload a disk,play xx disk etc
if it passes this test
then have a look see at your dallas battery back-up ram chip
this will fail after xx time,get back to me and i will walk with u
as i have all nsm stuff
ed
k3vyn
  • Last login:June 27, 2012, 04:38:42 pm
« Reply #2 on: May 13, 2012, 01:42:21 pm »
i have a msn juke2000 wall unit
had a similar problem, played one track on a cd....and not another..skipped through the tracks selected really anoying.
i thought it was maybe copied discs ect. i tried originals along with burned discs..sometimes said no disc.
juke picked um out..and dropped them back very quickly..that was the credit disapearing..
came up with some error codes..
one error was the lazer thingy..can`t remember what it named it as..
i searched around to buy one..jukebox parts ect..
i was going to bin the juke, but then my son said to manually clean the lazer eye as it would not play the brought cd lazer cleaner.
i took the thingy apart..cleaned the eye ..lense thingy with the fluid you get in the cd cleaning kits with a cotton bud.
and to say it worked well..
been running now for some months great with no probs.
sorry to name it as thingy..but without looking thats what it is..
ed12
« Reply #3 on: May 13, 2012, 01:53:40 pm »
hi
thats the optic laser
and yes alot of time's cleaning them will do the trick
the >cdm< laser platfourm was a pain in the butt to say the least
the real trick is to go easy with the cleaning,philp's dropped the ball on cdm2/3/4 by cdm5 nsm went to seeburg and all was fine
if this dose not fix the nick's problem ?
then we will be doing trouble shooting
ed
kev236
« Reply #4 on: May 13, 2012, 02:51:35 pm »
Thanks for the replies, I'll get some lens cleaner tomorrow and give it a try, if that does cure it how do i unlock the disc number that is currently locked?
ed12
« Reply #5 on: May 13, 2012, 04:29:55 pm »
hi
do u have the service key ?
if so u do it that way
get back to me
ed
kev236
« Reply #6 on: May 14, 2012, 04:45:41 am »
Hi Ed
Sorry you'll have to bear with me, i'm a complete novice when it comes to these machines, the only key that came with it was the one for opening the front, where could i get a service key and also is there anywhere i can get a service manual for it? where does the service key go? just incase it is in but not turned on.
ed12
« Reply #7 on: May 14, 2012, 02:25:10 pm »
hi
it's ok we can go slow
in the box should b a spot for a key to go
it will be the service key
could even be on the back of the machine
i do believe it is normally open and the switch colse's the circuit
thus putting it in service
please post the exact model # or atleast the exact name beside's nsm
i will dig out my manual's
ed
kev236
« Reply #8 on: May 14, 2012, 03:00:09 pm »
NSM Country Classic i think its a year 2000 model, when switch on the following shows on the display i presume some of this will be the model number. ES6  1.07e MBC III 0109 (068)
ed12
« Reply #9 on: May 14, 2012, 03:25:09 pm »
hi
colse
1=type Country Classic
1=s/w verison   1.07e
1=cd-platfourm ES6
the name is what i needed
sound's like a cdm6 platfourm
the way to tell is to look at the cd changer
ie where the laser is
is it a small platfourm or a large 1
if u can take a pic and up-load it can better tell u
the service key should be on the side or inside by the centeral
which is beside the amp
ed
kev236
« Reply #10 on: May 14, 2012, 03:48:21 pm »
heres a couple of photos if they help, still cant find where the service key should go
ed12
« Reply #11 on: May 14, 2012, 04:29:42 pm »
ok thats a cdm6
would u take a side view of the centeral please.?
it look's like u are missing the service key
i need a shot of the panel hanging up-right in photo 2
as i do not c the plug i need
ed
ed12
« Reply #12 on: May 14, 2012, 04:34:11 pm »
hi
ok this your's correct ?
>The Digitally Re-incarnated conversion series
With the industry change over from CD to digital jukebox technology well established Sound Leisure can now offer a comprehensive range of CD to Digital conversions allowing your CD jukeboxes to benefit from the proven advantages of Sound Leisure’s market leading digital technology.
Our conversions feature all the great facilities available on a standard Sound Leisure digital Audio Jukebox, including our easy to use customer touch-screen interface and engineers menus, 10 independent BGM timers, plus all the latest chart hits and pre-releases updated via CD ROM.
All in all the Sound Leisure conversions are the best way to transform existing CD systems to the latest digital jukebox technology.
This conversion is for the NSM Juke2000 and Country Classic - available in either red/green or purple/blue glasses to compliment either machine to be converted.
FEATURES:
•19"/15” TFT display, with/out ‘Screenseal’ technology*
•Simple to use touch-screen interface for customers/engineers.
•The very latest chart and pre-release titles to attract maximum plays
•Updated via CD Rom.
•A to Z search facility, artist and track display.
•10 independent BGM timers set by genre, year and BPM.
•Variable price of play/happy hour timers.
•On-screen advertising potential.
•Available as a remote selector*.
•Comprehensive data management system via floppy disk .
For amplification details and dimensions please contact Sound Leisure sales
*Dependant on type of machine to be converted
ed
ed12
« Reply #13 on: May 14, 2012, 08:26:03 pm »
hi
i just went  through some ppw
on that plate standing up
that carries the speaker jack's and the audio jack's
it appear's there is a key hole there correct ?
if so that is your service key point
ed
kev236
« Reply #14 on: May 15, 2012, 04:16:15 am »
I managed to get it into service mode, it is a button at the top beside the tube light that needs to be pulled out to put it into service mode, when i try to perform a cd changer test it loads up no problem but still says no disc. It passed all the other tests CPU, Memory etc. Am i right in thinking its the laser at fault?
ed12
« Reply #15 on: May 15, 2012, 12:52:18 pm »
hi
yup u got it
try cleaning it,if not ring me up and i will see
if i have any-rebuild kit's left
ed
ed12
« Reply #16 on: May 16, 2012, 03:16:45 pm »
hi
here is fast test
follow the rules when doing it >read<
>I find you can use a standard digital camera (I used a Nikon Coolpix for this test) and you are able to see on the camera view screen if the laser is lighting up. DO NOT ATTEMPT TO LOOK DIRECTLY AT THE LASER LENS AS IT MAY DAMAGE YOUR EYE(S)! Make a selection (no CD to be played) and then aim the camera over the lens just off angle slightly and you should see a white light in the middle of the lens flashing slowly on/off/on a few times while it hunts for the (non-existent) CD. No light? Check power to player, etc.<
ed
k3vyn
« Reply #17 on: May 17, 2012, 01:54:20 am »
Hi kev..
good to see your getting sorted..
Manuals can be found at the boneyard website...
it used to be FREE pdf downloads but now year`s subscription, maybe they have what you need.
i did download every manual they had a year past, that wasnt being greedy but just heinsight i guess for any future juke box i may have purchased.
i did look to them for you and i have all of what they had at that time on MSN and not got the one you mention, but i do reckon a lot work the same with same guts if ya like, if any other manual i have is of use to you then email over. you r welcome to all i have as they were FREE.
regards kevin
ed12
« Reply #18 on: May 17, 2012, 12:15:19 pm »
hi
k3vyn
very kind offer
can u chk and see if any of your manual's refer to cdm6 ?
if so thats what the nick will need cdm5 is baslicy the same
just some minor diff's
ed
k3vyn
« Reply #19 on: May 17, 2012, 02:06:57 pm »
Hello Ed..
unsure which one your after..
all MSN i have are:
ES 2 120 PRESTIGE
ES V
SAPHIRE
CONSUL 120
EMERALD ICE
ES VI
GEMFIRE
ES IV
Maybe private pm me ..you may like all i have on one cd..you can inject where needed..
things that were free should still be free as far as i am concerned.
i have no worrys on sending you all i have.
there r many more on that cd..though anyone can go to boneyard.com and register for their services of pdf manuals.
hope i aint doing wrong by offering this to you via the site.
ed12
« Reply #20 on: May 17, 2012, 02:34:19 pm »
hi
really your not breaking any rule's
the nick could use your esd >5<
they olny differ slightley
the platfourm and some code
ed
k3vyn
« Reply #21 on: May 18, 2012, 01:43:01 am »
Thanks Ed..
i take it you mean ES V....just a novice here mate too.
Kev if you require this on cd. i will copy it...private message me with yer details, i have no worrys sending by post.
leave that with ya kev.
kev236
« Reply #22 on: May 23, 2012, 03:51:44 am »
Thanks for all the help guys, got in touch with the guy i had bought the jukebox from he was very helpful, i just removed the laser posted it to him and he sent me another one FOC, stuck it in and all now working, again many thanks for all the advice.
