Author Topic: Fake coin door  (Read 6421 times)
GregD
  • Last login:December 19, 2024, 04:27:31 pm
    • Arcade Nebula
Fake coin door
« on: May 02, 2012, 04:25:23 pm »
Wondering if anyone has ever made a fake coin door out of MDF or something like that.  I was thinking of giving it a shot using the Novagem coin drop replacement buttons.  Can't find any threads about it.  Thanks
  • Last login:July 23, 2025, 07:04:20 pm
Re: Fake coin door
« Reply #1 on: May 02, 2012, 04:31:17 pm »
Whatever you do, don't get that godawful decal.
 :stupid
CheffoJeffo
  • Cheffo's right! ---saint
  • Last login:July 14, 2025, 12:11:49 pm
  • Worthless button pusher!
Re: Fake coin door
« Reply #2 on: May 02, 2012, 04:32:28 pm »
 :laugh2:
I was going to post a link to the decal in question!
But, at the same time, a used coin door is cheaper/easier than trying to fake one ...
Working: Not Enough
Projects: Too Many
Progress: None
  • Last login:Today at 10:55:32 am
Re: Fake coin door
« Reply #3 on: May 02, 2012, 04:33:38 pm »
I threw together something like that for "The Ping of Pong" build where I built a cab out of a ping pong table found in the neighbors trash and spare parts I had laying around.  (cause that's the kind of stuff I do when normal people are watching tv)
The coin button is an 8-liner button with a homemade insert printed out on an injket printer.
The coin return is a square 8-liner button with the lense painted black and glued in backwards.
The plate they're mounted in is just a scrap piece of abs textured plastic I had.
It probably would have looked better had I just used a piece of metal or thin wood for the plate.
Louis Tully
Re: Fake coin door
« Reply #4 on: May 02, 2012, 04:42:42 pm »
« Last Edit: February 12, 2015, 05:44:08 am by Louis Tully »
  • Last login:June 25, 2025, 03:09:16 pm
Re: Fake coin door
« Reply #5 on: May 02, 2012, 04:43:10 pm »
I remember Crashwg CNC'ed some mini coin doors out of MDF for a project by Jigenjuke:
http://forum.arcadecontrols.com/index.php?topic=106894.msg1197500#msg1197500
lilshawn
  • Last login:Yesterday at 11:49:19 am
Re: Fake coin door
« Reply #6 on: May 02, 2012, 06:36:06 pm »
 :stupid
I thought this thread would have been FOR that decal. Whew! that was a close one.  :cheers:
GregD
    • Arcade Nebula
Re: Fake coin door
« Reply #7 on: May 02, 2012, 06:58:12 pm »
No decal.   I am thinking a half inch pice of mdf routed out to give it some depth with novagems and some sort of fake coin returns.   Painted with that hammered metal spray paint.
Unstupid
Re: Fake coin door
« Reply #8 on: May 02, 2012, 08:51:44 pm »
For what it would cost to do something like that you could buy a real door...  Mikesarcade has a full 2 slot door with mech and everything for $65.  I think Happs even sells fake metal doors for like $25...
Re: Fake coin door
« Reply #9 on: May 02, 2012, 10:10:03 pm »
Twisted Quarter does the small stripped down doors for $37
(no coin mechs, returns are riveted closed)
http://www.twistedquarter.com/index.php?main_page=product_info&cPath=171_173&products_id=245
matsadona
Re: Fake coin door
« Reply #10 on: May 03, 2012, 06:19:47 am »
Isn't this forum about building things just because you can?  ;D
JayB
  • Last login:January 25, 2013, 06:11:59 pm
Re: Fake coin door
« Reply #11 on: May 03, 2012, 08:01:17 am »
Put a kids toilet seat on instead  ;D
Mysterioii
  • Last login:August 31, 2018, 11:44:34 am
Re: Fake coin door
« Reply #12 on: May 03, 2012, 08:09:14 am »
Not seeing it on their site?  I see mechs but not full doors.... out of stock maybe...
Unstupid
Re: Fake coin door
« Reply #13 on: May 03, 2012, 06:08:19 pm »
Sorry... It was from twistedquarter.com and it was $69.99.  But they have others cheaper...  ;)
Re: Fake coin door
« Reply #14 on: May 03, 2012, 06:56:46 pm »
If you're working 1:1 scale you could use 1/8th inch project board and route the raised outline of say an Atari over under then round all edges and glue that down to a template.  The coin drops and returns could be carved very easily in the same manner.  If you're working smaller then there are a lot of options, Bender uses styrene and I favor aluminum for mines.
