January 27, 2026, 10:16:06 am
I had this happen. I reinstalled MALA in another directory and then transplanted the newly generated gamelist to the old directory. Never figured out why it did it.
Are you sure your roms work for your version of MAME?
Would this thing help?http://forum.arcadecontrols.com/index.php?topic=101104.0at least you could go in and manually add those games using this tool.I've only ever created gamelists with external tools and kept mala out of it. the above and romlister can make lists that work in mala so you could end-around whatever this problem is.
