Author Topic: Mala will not add Donkey Kong, Mario Bros, others(?) to Game List  (Read 3988 times)
cavepainter
  • Last login:March 04, 2017, 08:40:19 pm
No matter what options I set in the Game Collection options, it will not add Donkey Kong to the game list. Mario Brothers is also not adding. I'm sure there are others it won't add, but haven't attempted to inventory every game it isn't adding.
Any ideas? Highly frustrating.  :badmood:
cavepainter
Re: Mala will not add Donkey Kong, Mario Bros, others(?) to Game List
« Reply #1 on: April 26, 2012, 10:40:10 pm »
Add Ghosts & Goblins. Argh.
MTPPC
« Reply #2 on: April 26, 2012, 11:57:53 pm »
I had this happen. I reinstalled MALA in another directory and then transplanted the newly generated gamelist to the old directory. Never figured out why it did it.
http://pinballmd.com/
cavepainter
« Reply #3 on: April 27, 2012, 07:46:07 pm »
Just tried this, and it didn't work. Thanks, though.
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
« Reply #4 on: April 29, 2012, 05:12:15 pm »
Would this thing help?
http://forum.arcadecontrols.com/index.php?topic=101104.0
at least you could go in and manually add those games using this tool.
I've only ever created gamelists with external tools and kept mala out of it.  the above and romlister can make lists that work in mala so you could end-around whatever this problem is.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #5 on: May 01, 2012, 05:10:09 pm »
Are you sure your roms work for your version of MAME?
-Banned-
cavepainter
« Reply #6 on: May 01, 2012, 09:42:53 pm »
Yep. I'm running the newest version of mame and I've successfully tested the ROMs that aren't adding.
cavepainter
« Reply #7 on: May 01, 2012, 09:44:34 pm »
Thanks, I'll definitely try this.
cavepainter
« Reply #8 on: May 01, 2012, 10:01:48 pm »
MYSTERY SOLVED, I BELIEVE.
When Mala was generating the mame.xml file for the first time I prematurely closed the command line window that opened and that wrecked my mame.xml.
Good to know!
