Author Topic: Top fire button joystick  (Read 2037 times)
snowbird
  • Last login:September 30, 2003, 11:40:11 pm
« on: September 29, 2003, 03:50:55 pm »
I am interested in buying a top fire button joystick for MAME?
There seems to be very few choices for this kind of joystick.  The two that I know of are Happs and Suzo.
I really like the Suzo, but I can not find a reliable source for it in the US.  Wico shows it in their catalog but never has it in stock!  Any suggestion on how can I get the Suzo top fire button joystick in the US?
zero-one
  • Last login:December 17, 2003, 10:30:04 pm
  • Still learning...
Re:Top fire button joystick
« Reply #1 on: October 02, 2003, 07:49:41 pm »
Maybe ask RandyT at http://www.groovygamegear.com. He sells the normal version (without top fire button) maybe he's also planning to sell the top fire ones too.
paigeoliver
  • Awesome face!
« Reply #2 on: October 02, 2003, 11:20:52 pm »
Also check ebay for an Atari 2600 controller called the "Wico Command Control".
It is a HIGH QUALITY Wico leaf switch joystick with a top fire button. Mine has a red bat handle on it. They only require minor modifications to install in your panel (drill four mounting holes in the case).
They usually sell for really cheap, and have a better feel than any other top fire I have used.
snowbird
« Reply #3 on: October 03, 2003, 10:14:28 am »
Thanks for the tip.  I will check them out.
I suppose that they are 8-way sticks with discreet wiring out for each switch (4 + 2 fire buttons) ?
Malachai
  • Last login:April 05, 2014, 11:07:00 pm
« Reply #4 on: October 03, 2003, 03:26:35 pm »
Here's a source for thoes, $18.50 shipped.  :)  http://www.vintagetechnology.com/item_pages/games_acc_00002_wico_command_control.htm
JLR2000
  • Last login:December 28, 2025, 10:50:05 pm
  • There is NO Sanctuary...
    • WWW
« Reply #5 on: October 04, 2003, 10:20:57 pm »
Can anyone give specifics on the modifications needed to to connect to encoder?  This was made for Atari 2600/C64 so I imagine it doesnt' have microswitches that are accessible.
Thanks in advance....
paigeoliver
  • Awesome face!
« Reply #6 on: October 05, 2003, 08:15:12 am »
Ok, sure.
The joystick itself is a single button stick, don't let the two buttons throw you, they both activate the same switch.
If you take off the bottom plate you will find 5 normal leaf switches. You just pull the original wires off, and then wire it from scratch as if it were a brand new stick from Happs.
As long as you still have the bottom off you can drill your mounting holes too. Just 4 holes that go through the casing without hitting any of the leaf switches.
