Author Topic: Building basics?  (Read 29511 times)
yaksplat
    • Random Projects
Re: Building basics?
« Reply #80 on: May 21, 2012, 06:51:07 am »
Check out amazon.com for the bits
http://yaksplat.wordpress.com
walterg74
  • Last login:March 16, 2025, 06:40:19 pm
yaksplat
    • Random Projects
« Reply #82 on: May 21, 2012, 08:16:54 am »
yeah, that's the 1/16" cutter that I've used on three cabinets.
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #83 on: May 21, 2012, 09:56:04 am »
Amazon should have your countersink bits too!
walterg74
« Reply #84 on: May 21, 2012, 11:34:13 am »
Right on... :)
I'll either buy the one, or this set right here to have more options:
http://www.amazon.com/DEWALT-DW2535-Piece-Countersink-Assortment/dp/B0000225OU/ref=sr_1_4?ie=UTF8&qid=1337611531&sr=8-4
walterg74
« Reply #85 on: May 23, 2012, 12:25:52 am »
Countersink bit set and slot cuter bits are on the way :)
I'll have to wait til july 1st to get them, but still many things to work on until then with what I already have. If the frikkin rain ever stops that is...  :angry:
walterg74
« Reply #86 on: May 23, 2012, 10:07:44 pm »
So as I keep reading while I wait for the weekend (and the rain to go away...), here's a question for the woodworking gurus...
I see that the basics of getting the sides is to draw out one piece, cut it out, use it as a template to draw the second side and then cut -it- out, and then clamp them together and make them equal.
Now in this last step of getting them to be equal, is sanding them the normal way, or is routing with a flush bit better??
Woodshop Flunky
« Reply #87 on: May 23, 2012, 10:19:28 pm »
Unless you're going to be taking lessons from Mr. Miyagi... use a flush bit. :)  It will give better result for a fraction of the effort.
walterg74
« Reply #88 on: May 23, 2012, 10:26:26 pm »
Well, kinda hard.. you know, with him dying and all...
Ok, so does that mean I have to take intoaccound the wood I'll "shave off" and make the side a tiny bit larger all around, or is the flush bit a really really thin blade that shaves the tiniest fraction off the wood..?
walker_tr9
  • Last login:May 27, 2024, 11:34:28 am
  • Infinity is not a number!
« Reply #89 on: May 23, 2012, 10:38:29 pm »
I have an unrelated question, but it fits in this thread.  Do I need to use a drill press to do the control panel?  I really don't want to buy one just for that one task.
Woodshop Flunky
« Reply #90 on: May 23, 2012, 11:03:14 pm »
What I've done with similar jobs is to trace the second part using the first.  The width of the pencil tip alone will make the second part a tiny bit larger all around.  When I then rough cut the second part with my jigsaw, I just make sure to leave the pencil line.  You should have plenty of room now to use the router as you described earlier.
walterg74
« Reply #91 on: May 23, 2012, 11:07:12 pm »
Hmm ok that sounds reasonable... I guess I can try it out with a couple of scraps first to see if I can get the hang of it...
Are you familiar with Koenigs cabs? Specifically the "VertiCade", which doesn't have t-molding but rather the wood of the sides is "rounded".. is that done woth the round bit on both sides, or some other way?
Woodshop Flunky
« Reply #92 on: May 23, 2012, 11:21:15 pm »
I'm also curious how those edges were achieved.  I've done that sort of thing before using a round-over bit, but it's tricky... when routing the second side, the bearing doesn't have anything to ride against.
DNA Dan
  • Guys.. we're not talking gold bars here
  • Last login:September 02, 2017, 11:39:00 am
« Reply #93 on: May 24, 2012, 01:30:23 am »
I believe this is done using a template for the bearing or without a bearing altogether.  http://www.amazon.com/Freud-99-019-1-Inch-Convex-Router/dp/B00004T7LY/ref=sr_1_1?ie=UTF8&qid=1337837360&sr=8-1
The cut is made across the whole edge in one pass.
walterg74
« Reply #94 on: May 24, 2012, 02:50:33 pm »
Awesome! I was looking for something precisely like that!
So this says it's 1", how do you work it when the wood is thinner, like the usual 3/4" or 5/8" ppl use, or in my case the 15 mm ones?  ???
Edit: also, I see that particular one would be no good for me since the shank is 1/2", and the router I have takes 1/4", 6mm and 8mm bits.
Still I found this one like it:
http://www.amazon.com/Vermont-American-23158-32-Inch-Carbide/dp/B000PU0MFI/ref=pd_bxgy_hi_text_b
Edit II: so what would happen if I tried to use a roundover bit twice? would I achieve the same result, or would it on the contrary look like crap?
« Last Edit: May 24, 2012, 03:12:16 pm by walterg74 »
darthpaul
  • Last login:Yesterday at 11:33:31 am
  • Join, It's your duty
« Reply #95 on: May 24, 2012, 07:46:15 pm »
No you don't, a hand drill, some spade bits and a 3 1/2" hole saw for a trackball and you are good.
Sith Pedestal
Automated Cabinet
Nintendo Pi
PiCubed
walterg74
« Reply #96 on: May 25, 2012, 06:09:58 pm »
Well, started mini step at a time... Drawing the plans onto my first MDF piece... Did all the lines and small curves, and now only one last curve to go: trying to find a practical way to have a stencil/template for a R675,1 mm curve   :o
Guess I'll be moving to project announcements soon (but still leave basics questions on this thread).
walterg74
« Reply #97 on: May 28, 2012, 12:10:45 am »
Lo and behold... This thread was not for nothing!
I have indeed started my first project, and the thread can be found here:
http://forum.arcadecontrols.com/index.php?topic=120485.0
I'll still keep asking stupid questions here though :)
Thanks!!!  :applaud:
