Author Topic: Mounting H.D. Happs Flight Stick  (Read 1450 times)
joe35car
  • Last login:July 17, 2025, 11:43:10 pm
« on: February 25, 2012, 02:15:00 pm »
Is there anyway to mount this so the metal plate in not on top of the CP? Would like to find a way to mount this underneath for a clean look like the trackball.
http://na.suzohapp.com/joysticks/50997000.htm
Drnick
  • Plodding Through Life
Re: Mounting H.D. Happs Flight Stick
« Reply #1 on: February 25, 2012, 05:17:57 pm »
Simplest answer I can think of without having one to hand. Rout a couple of mm from the top of your CP so it sits flush.  Although if you are looking to add it to an existing CP which already has art installed then I have no clue.
Louis Tully
« Reply #2 on: February 25, 2012, 06:28:26 pm »
« Last Edit: February 12, 2015, 05:26:35 am by Louis Tully »
whynotpizza
  • Last login:March 23, 2025, 10:01:28 am
« Reply #3 on: February 27, 2012, 07:01:07 am »
I did a mod on the Happ/U360 and mounted from below.
Checkout this post...
  http://forum.arcadecontrols.com/index.php?topic=86734.msg910938#msg910938
Took some time to get it right, but the end result was well worth it!
Good luck,
  David
