Author Topic: Woodworking and the air you breathe  (Read 6472 times)
kahlid74
  • Gaming for a better future!
    • GamersAnon
« on: February 11, 2012, 12:09:47 pm »
I decided to build a DIY air filtration unit for my workshop.  Long story short we bought a house and I setup shop in a 20x20x10 enclosed area of the basement.  After cutting/routing/sanding I would see a fine sheen of dust on everything in the workshop.  Additionally the whole family was coughing a lot.  SO I thought it was time I took care of the fine dust particles in the air in my workshop and my house.
There a bunch of articles talking about the hazards of air in woodworking environments but the biggest problem are fine dust particles.  These little guys clog up the pores in our lungs and are incredibly hard for our bodies to scrub away.  Air filtration systems work by scrubbing the air of these particles.  You typically want to scrub the entire space you’re in in about 4-6 minutes.
When I looked on Amazon the cheapest air filtration systems were 300~ and they just didn’t feel right.  I started searching online and found plenty of DIY systems but no one had any real good designs.  Then I found the PDF I’ve attached to this article.  I went to home depot and bought a 4x8 sanded plywood sheet for 40 bucks and about 15 feet of oak hardwood for about 6 bucks on sale.  I then followed the author’s advice and looked for filters.  I couldn’t find any 12x24 but I found an abundance of 16x25 so I changed the measurements to fit the new filter size.
I made the cuts and used the router and applied wood glue and found that I was a bit short on the 16” slot so I changed the design.  Where his has a sliding door mine is latched for the filters.  I then permanently fixed the bottom on for the squirrel cage air blower.  I used 1/4 inch window strips and silicon to make the box air tight.  I did not decide to put any filters at the end of the box like the author did.  Squirrel cage blowers get super-hot and the last thing you want to do is trap dust in the area where the blower is.  The heat could cause a spark.  So the design pulls air through the filters and then the squirrel cage blower pushes it out.
You can get a cheap squirrel cage blower from HVAC places that are getting rid of them.  I got a 465CFM one from Amazon for 90 bucks and was fine with it.
Costs:
Wood – 46
Filters – 25 (one regular and one very fine for the small dust particles)
Blower – 90 (http://www.amazon.com/Active-Air-Blower-System-465/dp/B004K65JZG/ref=sr_1_29?ie=UTF8&qid=1328978484&sr=8-29)
Timer - 10
Total: 171
You can get super cheap with a 20-40 air blower that an HVAC place is going to throw out.  call around and you can find one.
Here is the box hanging in our basement
Side view with the attached wood for filter holding
Front view filters
Close up of the latch I used to hold the filters in.
Timer - 1 hour
Air out so the back end of the unit
Air blower inside the enclosure
Close up of cleats
The piece of wood that holds the filters in place with the window sealer foam on it.
The paper is being pulled to the filters so you know it's working.
Blowing air out
Re: Woodworking and the air you breathe
« Reply #1 on: February 11, 2012, 02:06:30 pm »
Great project ;D  I will definitely look into one of these for dust abatement in my garage.  Thanks!
BobA
  • What Me Worry?
« Reply #2 on: February 11, 2012, 03:36:59 pm »
Nice project. MDF dust is a real pain in the rear.   Do you plan on putting an exit filter on your unit as well?
kahlid74
    • GamersAnon
« Reply #3 on: February 11, 2012, 06:24:44 pm »
I do not presently.  I have two primary worries with an exit filter.  The first deals with the build up of dust and the second is that the air flow exiting the blower is condensed into a 6X4 inch rectangle.  So only a portion of the filter would be primarily used and the filter really couldn't be super micron small because of the larger volume of air exiting.
GregD
  • Last login:December 12, 2025, 08:37:36 am
    • Arcade Nebula
« Reply #4 on: February 13, 2012, 12:51:25 pm »
My first air cleaner was homemade.  Then I got a great deal on JDS branded cleaner.  Works great.  I have my shop hooked up to a central dust collection system but dust absolutely gets in the air.  I hate using MDF but sometimes it is best for the job.  It makes a mess and is the most hazardous for you.  I always use a cheap respirator when working with it.
yaksplat
    • Random Projects
« Reply #5 on: February 13, 2012, 03:20:52 pm »
i have the jet air filter that is sold on amazon.  I'm not sure why the price shot up as much as it did.  It's $370 now.  When i bought it in 2004, it was 170.  Makes no sense.  It really is just a box witha  squirrel cage like you built.  It does have three speeds and a timer with a remote, but still, not worth 370.
I still have to set up my dust collection system with pipes and gates....  I have the main dust collector, but right now it's just a glorified vacuum with a large diameter hose.
http://yaksplat.wordpress.com
PIZZ
  • Last login:January 14, 2013, 10:24:17 am
« Reply #6 on: February 13, 2012, 04:15:01 pm »
Cool im going to try this out. I built one of thee ghetto ones last summer to filter out my basement
actually worked well
kahlid74
    • GamersAnon
« Reply #7 on: February 14, 2012, 09:26:12 am »
Yeah my next progression is going to be one of the cyclone vacuum systems with multiple hoses for specific stations but all in good time!
  • Last login:Yesterday at 01:12:23 pm
« Reply #8 on: February 14, 2012, 01:22:41 pm »
So you think that's air you're breathing now?
Donkey_Kong
    • CNC Machines
« Reply #9 on: February 14, 2012, 10:03:17 pm »
 :lol
kahlid74
    • GamersAnon
« Reply #10 on: February 15, 2012, 08:35:54 am »
Nitrogen, Oxygen, Argon, Carbon Dioxide . .  Yeap, it's air!
