Author Topic: Encoms DOT Cabaret  (Read 26139 times)
xray2
  • Last login:November 03, 2012, 09:08:23 pm
Re: Encoms DOT Cabaret
« Reply #40 on: April 17, 2012, 12:29:34 am »
Next problem was the mounting bracket from the Kosmik Krooser raised the encoder pcb up on the DOT spinner and the encoder disc was impacting the side of the optointerruptor.  Hope you don't mind but I drilled a couple of holes in the vertical mount for the pcb and then again to secure the encoder board closer to the encoder disc.
A quick check of the 8 bit data output shows I can now successfully both increment and decrement the counter using the wheel.  I need to clean up code for the USB interface but should be able to finish up and ship this back over the weekend.
rikitiki
  • Last login:January 03, 2020, 01:17:35 pm
    • Custom Arcade Game Printing
« Reply #41 on: April 17, 2012, 03:56:44 pm »
I would REALLY love to get the cabinet plans/dimensions from you. I can't seem to find one of these cabinets for measuring.
This project is amazing by the way. I love the old/school custom stuff. Your Tron Video Pinball custom cabinet was equally redonkulous. This thing is going to be unreal. I wish I could silkscreen my own artwork for a project!
Keep up the great work!! :)
Thanks I will have these plans drawn up and avaiable.
not every route cut but all the basic dimensions and scaled templete.
Ill be attaching art files and cabinet files to each related post for download soon.
Saving the Planet one Game at a time.
www.ThisOldGame.com
rikitiki
« Reply #42 on: April 17, 2012, 03:59:45 pm »
Wow thats super cool Xray!
just to recap
DOT used a different opti borad than Tron (previously posted) and found that they used the same opti board in KOZMIK KROOZER
a panel popped up on the bay and got it to both scan the cpo art and use the opti board for this project.
Its also possible that this opti board will be reprod as well
« Last Edit: April 17, 2012, 04:01:28 pm by rikitiki »
www.ThisOldGame.com
« Reply #43 on: April 17, 2012, 04:33:26 pm »
Lots of great things happening in this thread. I'm eagerly watching.  :applaud:
  • Last login:December 22, 2025, 01:46:51 am
« Reply #44 on: April 17, 2012, 11:32:07 pm »
You do great work, I'm pretty damn impressed by your flair for artwork too.
xray2
« Reply #45 on: April 17, 2012, 11:57:48 pm »
Rich,
I've more or less finished the USB interface hardware but not sure how sensitive the DOT spinner should be.  I fired up Discs of Tron in MAME with the default input configuration and measured the rotation of the DOT spinner as the cursor traveled between the two vertical lines shown in the picture below.
It takes about 1/6 of a turn to move from the left side of the back wall to the right side.  I.e., the knob rotates from the noon position to the 2 on a clock face.  Does that sound about right?
I can't recall if I should be rapidly spinning the knob like in tempest or if it should behave as a more accurate positioning device with lots of spinning to move just a little on screen.
LMK!
« Last Edit: April 17, 2012, 11:59:35 pm by xray2 »
rikitiki
« Reply #46 on: May 30, 2012, 11:54:11 am »
Quick update:
Controls have all been worked out. these were matched to have the controls act
exactly like the original.
A little side wierdness fact:
on the original DOT. When rotating the spinner clockwise, one 360 rotation = +128 on the counter. However, rotating counter clockwise = -144 on the counter which indicates a 360 rotation counter clockwise is registered by DOT as a 1 + 1/8 turn.
Also looking into having these small Pcbs reproduced with Leds with possible color options
and Potetiometer to adjust brightness
These were orginally used to light the Joystick Inserts in Gorf.
Cabinet is currently being assemble and will have more pics to post soon.
www.ThisOldGame.com
« Reply #47 on: May 30, 2012, 12:27:07 pm »
I'd pick one up for my Gorf...
rikitiki
« Reply #48 on: June 23, 2012, 02:44:39 pm »
should be assmebling some protoypes soon.
moded the original with LED lighting and working on designing a "deluxe" version for Tron Mods
Also looking into possibly including the orginal Gorf Harness and or a new one for the "deluxe" version.
Something Ill also be looking into is a fix for the shadowing defect you get from the orginal switch
« Last Edit: June 23, 2012, 04:33:16 pm by rikitiki »
www.ThisOldGame.com
rikitiki
« Reply #49 on: June 23, 2012, 02:54:05 pm »
Cabinet Update
So one of the things thats been plaging me is the sideart for the Space Paranoids side.
Problem is in using the "newer" Space Paranoids poster art is it dosnt feel "vintage"
like Marty McFly its outatime with all its shapding and PSD-esq effects.
 the color palette also wasnt quite right and was just a little to "Fan-made"/copy of the newer SP cabs Disney did.
Really looking for something that says
"Wow! I didnt know they made a DOT mini "
and so it needs to have good matching art for Space Paranoids.
The pics dont do it justice, its printed on a light reflective vinyl, so it illumiates when the light hits it.
Like Police cars at night. and have both sides printed and ready for install.
« Last Edit: June 23, 2012, 04:28:01 pm by rikitiki »
www.ThisOldGame.com
rikitiki
« Reply #50 on: June 23, 2012, 02:58:02 pm »
The flip side 8)
www.ThisOldGame.com
Sjaak
« Reply #51 on: June 23, 2012, 04:04:59 pm »
I really like those graphics. I did a space paranoids cocktail a while ago
xray2
« Reply #52 on: June 24, 2012, 02:50:18 am »
Here's your DOT spinner + controller + cables ready to ship out on Monday.  The controller shows up as a 3 button USB mouse.  I played a couple games of DOT in MAME and it worked flawlessly.
_
« Last Edit: July 05, 2012, 12:38:52 am by xray2 »
Woodshop Flunky
« Reply #53 on: June 25, 2012, 09:46:11 am »
WOW!  I can't wait to see this one finished!  Looking great!   :applaud:
Nimbus
  • Last login:December 21, 2019, 08:08:57 pm
« Reply #54 on: June 26, 2012, 12:05:36 am »
I can't believe that this isn't getting more attention. Your artwork and attention to detail is absolutely redonkulous. I hope that you make those cabinet plans/dims available too.
Keep up the great work!!!  :applaud:
  • Last login:Yesterday at 06:42:46 pm
« Reply #55 on: June 26, 2012, 02:19:00 am »
Awesome!  :applaud:
xray2
« Reply #56 on: July 05, 2012, 12:37:07 am »
DOT controller from the windows 7 device manager
_
shrunkenmaster
« Reply #57 on: December 01, 2012, 04:21:26 pm »
Bump!
rikitiki
« Reply #58 on: December 30, 2012, 01:46:51 pm »
Yeah with the Summer shows and Holidaze finally behind me its time to wrap this project up.
No need to bore with all the details the wood was cut, routed, clamped/glue together, and painted
On one note once I had a nice good paint I did a light hand sand for a nice smooth surface for the vinyl.
Usally Ill just use a WHITE oilbased primer when restoring a cab like I shown in my art install tutorials
« Last Edit: December 30, 2012, 02:07:21 pm by rikitiki »
www.ThisOldGame.com
rikitiki
« Reply #59 on: December 30, 2012, 01:52:54 pm »
Speaking of which
http://forum.arcadecontrols.com/index.php/topic,120041.0.html
no need to go over all that again
kickplate vinyl installed using the Black Happ Pica vinyl here nice thick and durable stuff for the front
along with a kickplate decal using the art from the Enviromental bottom light cover.
One thing to note here I used a table saw with a plastic cuttting blade along with something called CutEase
a great wax like product for cutting plastics to keep the edges from chipping and melting.
« Last Edit: December 30, 2012, 02:05:56 pm by rikitiki »
www.ThisOldGame.com
rikitiki
« Reply #60 on: December 30, 2012, 02:10:02 pm »
www.ThisOldGame.com
Beanbag
  • Last login:September 02, 2013, 08:50:03 pm
« Reply #61 on: December 30, 2012, 07:33:34 pm »
It looks awesome.  :applaud:
Looking forward to you posting the caberet cabinet plans. They don't seem to be easy to find.
Mini Donkey Kong build.
« Reply #62 on: December 30, 2012, 07:38:54 pm »
Sexy! :cheers:
rockyrocket
« Reply #63 on: January 01, 2013, 06:19:18 am »
IG-88
« Reply #64 on: January 03, 2013, 08:41:44 pm »
Ya, what he said  ;)
-HarumaN
Woodshop Flunky
« Reply #65 on: January 04, 2013, 04:25:23 pm »
This is looking so sexy.
If I was going to cheat on my arcade cabinet... it would be with this one.  :cheers:
