Author Topic: Alternative to T-moulding??  (Read 3975 times)
PIZZ
  • Last login:January 14, 2013, 10:24:17 am
« on: February 04, 2012, 12:53:21 am »
Are there any good ways to finish off the edge of a 1/2" hardwood ply cabinet without having to do the standard routing and T-moulding?
Re: Alternative to T-moulding??
« Reply #1 on: February 04, 2012, 09:31:21 am »
Round it off with a router.
EvilNuff
« Reply #2 on: February 04, 2012, 12:16:10 pm »
You could do a thin hardwood banding.  Take about 1/8" of thin hardwood the same type as your plywood and use that to edge the ply?
darthpaul
  • Last login:Yesterday at 06:10:58 pm
  • Join, It's your duty
« Reply #3 on: February 05, 2012, 07:29:49 am »
I think the real reason most people use t-molding is for that authentic look. They sell edging that applies with a hot iron.
Sith Pedestal
Automated Cabinet
Nintendo Pi
PiCubed
Woodshop Flunky
« Reply #4 on: February 05, 2012, 02:30:18 pm »
I have simply spread drywall putty on the edges and then sand when dry.  I then repeat the step a bunch of times to get a smooth edge.  This method is a lot of work, but you will end up with smooth edges.  I've also just primed the edges and sanded them over and over until I have a smooth edge.
darthpaul
« Reply #5 on: February 05, 2012, 02:43:50 pm »
I have used that method with MDF but not plywood.
Sith Pedestal
Automated Cabinet
Nintendo Pi
PiCubed
Mr. Dude
  • Last login:March 03, 2019, 05:12:50 am
  • Hi...
« Reply #6 on: February 16, 2012, 01:46:52 pm »
If you don't have any drastic curves you can trim it off with half round or quarter round. I did this on my Vewlix clone cabinet and am really pleased with the way it turned out.
EightBySix
« Reply #7 on: February 17, 2012, 08:37:34 am »
Are you painting it? If you want to keep the wood look, you can apply iron on glue backed veneer. You can get lots of types to match the outer ply of your board.
