Author Topic: Put Mortal Kombat 1 into Street Fighter Cab  (Read 1492 times)
matrix00
  • Last login:March 25, 2012, 02:41:58 pm
« on: January 01, 2012, 03:00:24 pm »
I have a Street Fighter 2 CE cab, that I want to put Mortal Kombat 1 in. I don't want to splice wires and screw things up, because I still play Street Fighter 2 in it and just want to be able to swap them out.
Is there any easy way to wire the Mortal Kombat 1 PCB up to my current Street Fighter two set up?
Thanks for any and all help.
BobA
  • What Me Worry?
Re: Put Mortal Kombat 1 into Street Fighter Cab
« Reply #1 on: January 01, 2012, 03:18:19 pm »
I think the CPS 1 is basically a jamma connector so all you would have to do is adapt the MK1 kick harness to the SF kick harness.
« Reply #2 on: January 02, 2012, 09:17:25 am »
if you plug MK into the SF cab the punch buttons will be high punch, block, and high kick. You would have to make it so the SF harness plugs into the MK kick harness, or do something like this:
http://www.jamma-nation-x.com/jammax/multikickharness.html
matrix00
« Reply #3 on: January 02, 2012, 02:16:38 pm »
Thanks for the help
ctozzi
  • Last login:November 24, 2022, 01:05:42 pm
« Reply #4 on: January 02, 2012, 06:23:46 pm »
Current Cab's
Dedicated Killer Instinct 1
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
matrix00
« Reply #5 on: January 03, 2012, 10:02:26 am »
I will get that, they are of stuck though right now. Thanks for the link.
