Author Topic: Artwork holding me up  (Read 2233 times)
GregD
  • Last login:December 19, 2024, 04:27:31 pm
    • Arcade Nebula
« on: December 22, 2011, 03:28:24 pm »
I stink at Photoshop and Illustrator.  I am being held up on my control panel because of the art situation.  The thing that I cannot figure out is how to create the button and joystick halos.  Is there a tutorial anywhere.  When researching I saw that Mr. Knievil used to have one but that link is long dead.  I am looking for something similar to Knievils layout.  Two joysticks with six buttons and either a spinner or dedicated 4-way up top with a 3" trackball in the middle.  I am not looking for artwork itself.  I can handle that part.  I am just looking for some sort of template that I can edit with my own original artwork.  Would anyone be willing to share the halo layer of their artwork with me?
I am looking for something along the lines of:
http://forum.arcadecontrols.com/index.php?topic=91009.0
or
http://forum.arcadecontrols.com/index.php?topic=94891.0
or
http://forum.arcadecontrols.com/index.php?topic=86044.0
Sharing of artwork seems to be a touchy subject but I thought I would throw it out there.  Thanks in advance.
« Last Edit: December 23, 2011, 11:46:47 am by GregD »
GregD
    • Arcade Nebula
Re: Artwork holding me up
« Reply #1 on: December 27, 2011, 03:26:20 pm »
Crickets?  That's OK.  I will give it another go.
bdeshazer
  • Last login:September 19, 2012, 12:18:11 pm
« Reply #2 on: December 27, 2011, 03:38:30 pm »
Lots of people probably still busy wrapping up the holidays... what do you mean by "halo"? I can throw together a quick layered PSD file for you but I'm not exactly sure what you mean by that term...
« Reply #3 on: December 27, 2011, 11:37:29 pm »
Here's a quick and dirty how to.  If I had surviving layers I'd shoot them to you but they've all been flattened and merged to allow me to do composite outlining.
First, go to Slagcoin and pick a layout if you don't already have one.  I'll assume you're working in Photoshop since you mentioned it.
Import the outline you chose (if  you don't already have one) and ensure it's to scale for your resolution.  Everything he has is sized at 72dpi I think so if you're working in 300 you'll need to blow it up and use the rulers to ensure you're spot on.
Now, take the shape tool and select the circle.  Size yourself a circle that gives a ballpark halo for what you're wanting.  This will be a vector shape so all the color adjustment needs to be done from the drawing menu and not working with the object as you would a regular layer.  If you don't feel comfortable eyeballing things once you start moving them around you use the ruler guides to split the circle in quadrents and then put another tiny circle at the intersection, preferably in a contrasting color.
Link those two layers.  You now a have single circle with a good center.  Set it to about 25% fill and move it over the button overlay you imported.  Once it's over the first button resize the halo until you get what you want.  Then you can duplicate the layer and move the dup over the second button.  Lather rinse repeat.  Once you've covered everything the way you want it and centered it all bring the fill back up to 100%.  If all your circles intersect you can rasterize all those layers (I assume you're not working in vector) then merge them all into a single layer (I do this by button sets initially) then you can use the stroke option in layer properties to outline the set.  If the circles don't intersect you can then use the oval tool and make another vector shape behind all your buttons and move it around till it makes you smile.  Then rasterize and stroke.  From there it's a matter of color and opacity to get the effect you're looking for.
Send me your CP and I'll do a set that you can then copy and work with.  Nothing like learning on your own art.  PM me if you're interested.
« Last Edit: December 27, 2011, 11:41:32 pm by Le Chuck »
bdeshazer
« Reply #4 on: December 28, 2011, 10:58:39 am »
Under each of the layouts are links to download in various resolutions, up to 300dpi...
« Reply #5 on: December 28, 2011, 02:17:28 pm »
Word. Good catch.
GregD
    • Arcade Nebula
« Reply #6 on: December 28, 2011, 06:41:18 pm »
Thanks for the insight.  I really appreciate it.
