Author Topic: Looking to remove "Quit" option in Mala  (Read 3268 times)
Jonny G
  • Last login:March 04, 2024, 05:59:46 pm
« on: December 15, 2011, 04:16:48 pm »
Hi all.
The title says it all really, I'm wondering if its possible to edit the exit options from the menu pane ("2" by default in Mala) so that only "Shutdown" and "Restart" are available. Basically so that it is impossible to be left in limbo as I've hidden XP and set Mala as my shell.
Thanks for any help.
Jon
Re: Looking to remove "Quit" option in Mala
« Reply #1 on: December 30, 2011, 08:51:34 pm »
I dont see anyway to change that menu,
you can setup up a shutdown menu in the mala layout editor.
When you hit ESC the menu you create (or you can use the default), will allow user to cancel (ESC), or quit mala,
by closing mala, shutdown, or hibernate by pressing 1. These options are set up in mala/options/gui
Here is a pic of what I use on one of my setups:
PaTrYcK
  • Last login:May 02, 2020, 05:22:19 am
« Reply #2 on: January 23, 2012, 07:38:12 am »
Hi, i not find the way for modify the image of hibernate exit, is possibile do it?
PaTrYcK
« Reply #3 on: February 09, 2012, 08:29:12 am »
Anyone know the way to modify the windows "quit" or "Hibernate"?
Loadman you made it,  how did you do?
