Author Topic: Problems with Soft15khz  (Read 1502 times)
honkey
  • Last login:December 16, 2015, 02:54:04 pm
« on: December 13, 2011, 02:58:15 pm »
My problem left before I build I connect the controls is that I downloaded Soft15khz and installed it along with the quickres, but I still can not display resolutions below 640x480. They are not showing up as options in quickres.
Can anyone help with this problem?
« Last Edit: December 13, 2011, 10:21:46 pm by honkey »
honkey
Re: Problems with Soft15khz and Clrmamepro
« Reply #1 on: December 13, 2011, 09:33:16 pm »
Still having problem with soft15khz... I pressed "install 15khz" and it appears that nothing has changed. When I open quickres, I can only go as low as 640x480 even after restarting the computer. I am using an ATI Radeon 4800 HD series graphics card. Can anyone provide any insight? Is it possible that the lower resolutions are not showing up because I am using an HDMI cable to connect to a TV?
« Last Edit: December 13, 2011, 09:40:03 pm by honkey »
honkey
« Reply #2 on: December 13, 2011, 10:11:08 pm »
Nope, the problem is not HDMI. I just borrowed a monitor and used the VGA and still a no go.
MTPPC
« Reply #3 on: December 17, 2011, 04:33:36 am »
What fersion of forceware driver are you using?
http://pinballmd.com/
