Author Topic: Need help to wire power button  (Read 2384 times)
sprtm
  • Last login:May 20, 2014, 07:17:22 am
« on: December 12, 2011, 04:31:33 pm »
I'm about to replace the PC in my cab. With the current PC I had no problem to cut the two power button wires and connect them to a regular microswitch. However, with this new PC there are FOUR wires (+ LED wires) coming from the motherboard. Does anyone know how I should cut and wire these to a microswitch? I've searched the forums and found similair questions, but no answer.
The PC is a Lenovo Thinkcentre 9646.
Anyone?  :)
Re: Need help to wire power button
« Reply #1 on: December 12, 2011, 04:38:55 pm »
My guess would be one set is Power, and the other set is Reset. Cut them both, touch the ends of the wires together (each set, trying one set first, then the other), and see what set powers the computer on.
sprtm
« Reply #2 on: December 13, 2011, 12:30:00 pm »
I can see that both sets are marked with "PWR ON" on the motherboard if it matters? But thanks's for the tip it sounds reasonable, I will try that!
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #3 on: December 13, 2011, 12:54:10 pm »
All IBM/Lenovo power buttons have double power button leads.  THey are redundant. Just cut both of them and wire up one set to a microswitch and you will be fine
Cynicaster
« Reply #4 on: December 13, 2011, 04:42:22 pm »
I ran into this same non-issue recently.  I bought an $80 used IBM off the internet for my cabinet, and found that it had two sets of leads connected to the power switch.  I just hooked up one set to my cabinet power button, and since it worked, I didn't ask any further questions.  :)
sprtm
« Reply #5 on: December 14, 2011, 05:39:49 am »
Thanks fot your replies, worked like a charm! :D
