Author Topic: Painting bat-tops and dustwashers?  (Read 2008 times)
Seith
« on: November 01, 2011, 12:16:13 pm »
What kind of paint is best to use on bat-tops and dustwashers?  I am looking to use the following paint to coat my bat-tops and dustwashers in:
http://www.alsacorp.com/products/eclipse/eclipse_prodinfo.htm
The paint can be combined with a candy coat to have the color change from black to whatever the candy coat color is.  Also, what is the best method for applying the paint to the bat-tops and dustwashers?
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: Painting bat-tops and dustwashers?
« Reply #1 on: November 01, 2011, 02:52:01 pm »
We've sprayed sticks and dustwashers before using Plasti-kote spray. Creates a flexible coating so does not flake, using the associated sealant. Not sure if it's available elsewhere, but it's commonly found in the UK.
Seith
« Reply #2 on: November 01, 2011, 03:21:20 pm »
So if I coat with the spray, it should be fine to paint?
Turnarcades
    • Turnarcades
« Reply #3 on: November 01, 2011, 08:05:28 pm »
Plasti-kote is a type of spray paint, so is available in a range of colours, and the flexibilty is built into the paint. I suppose car paints like it sounds you intended to use should work OK if sealed properly with a lacquer, though may still be susceptible to chipping or flaking.
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
« Reply #4 on: November 01, 2011, 11:18:50 pm »
There is also plasti-dip if you want to dip it :)  I saw this thread and tried it on one of my happ sticks and so far so good.  Who knows how long it will last though.
Seith
« Reply #5 on: November 05, 2011, 06:03:18 am »
Hm, something to think about.  Alright, thanks for the help!
