Author Topic: Joystick bottom mounting with deep threaded screws  (Read 2253 times)
(+_+)
  • Let me splain.
  • Last login:July 27, 2012, 09:00:32 pm
  • For I am ]{eyser Soze
« on: October 19, 2011, 06:23:15 pm »
Hi Everyone,
I was wondering if I'd be able to bottom mount joysticks in 3/4" plywood using larger deep threaded screws only?
I can't see them every coming out under normal usage.
Thanks for the input
Marc
This plan is so perfect, it's retarded. -- Peter Family Guy
eds1275
  • Last login:August 18, 2025, 05:02:15 pm
  • Rock and Roll!
Re: Joystick bottom mounting with deep threaded screws
« Reply #1 on: October 20, 2011, 02:06:09 pm »
As opposed to running through? Or the threaded inserts? I don't see why not although the expanding threaded inserts are the way I'd go personally if I didn't want bolts showing from the top.
