Author Topic: Soulcalibur Project (Namco cabinet reproduction)  (Read 30973 times)
Sir Kayne
  • Last login:April 01, 2018, 10:58:01 am
« on: September 26, 2011, 05:20:10 pm »
After many reflection of building a cabinet I finally decide to reproduce a real Namco Cabinet.
Originally made for Tekken and after adapt to Soulcalibur.
This Soulcalibur version is very hard to find (the foto that I post here is one of the rare picture I could find)
But I will do some change :
-27" 16/9 screen (because I don't find any other screen for the moment, but the cabinet will accept 4/3 too)
- Multi support systeme : Jamma/Jamm+/NeoGeo/DC/PS2/PC
- Completely disassemble feature (better for transport and move in a other room for example)
Ok, let's go !
First I modelize completely the woodworking under Turbocad :
That's give an idea of the cabinet and exactly what I need for material.
Here Inside:
You can notice the system of the inside table.
The monitor will be fix on this table and not fix on the side. I do that for the disassemble possibility and for more general strength:)
The project is good advance, but I will post you all the work until now (I begin the 26th November 2010, unfortunately I don't have too much time  :-\)
PS : Sorry for my english, I come from France, but I want share this experience from scratch project on this famous forum  ;)  Hope you will enjoy !
« Last Edit: November 26, 2015, 06:57:48 am by Sir Kayne »
Sir Kayne
Re: Soulcalibur Project (Namco cabinet reproduction)
« Reply #1 on: September 27, 2011, 05:56:21 am »
Ok, first the material
19mm and 10mm Medium plate, 16mm Aglo Wood and a strong 22mm Plywood for the bottom
And some "real" wood
Let's start !
Stage 1 : Inside Part
The CAD blueprint
Preparing the wood
Should assemble something like that
It's pretty hard to be 100% by woodworking
Drilling
And first test...
Look good !
Test with the 4 legs
The stability is really poor
I had some extra wood
Test again, Look better  ;D
Time to glue !
That a complicate part and you must be at two minimum to fix it good !
Thanks to my neighbor  ;D
After the dry (24 hours later)
As you can see, it's not perfect, but hopefully the wood can be move a little
I ifx the leg on the Ply botton
With bracket
and dowelled join for be sure
more to come !
« Last Edit: November 26, 2015, 07:05:34 am by Sir Kayne »
jmike
« Reply #2 on: September 27, 2011, 07:48:14 am »
 :applaud: :applaud:
    This thing is going to look awesome. Love the step-by-step and even the blueprints. Just make sure the base is secure, I would have doubled up on your side pieces or even used 2x4's. The frame is very important, it has to be able to hold everything up. Good luck and keep posting more pics
matsadona
« Reply #3 on: September 27, 2011, 09:26:47 am »
Why don't I see any pictures?  ???
Sir Kayne
« Reply #4 on: September 27, 2011, 09:58:59 am »
Strange...I want not upload "again" the pictures (store on a French server), but if nobody can see it, I will post them on arcadecontrol.
Yvan256
  • Last login:Today at 05:07:28 pm
    • Yvan256
« Reply #5 on: September 27, 2011, 10:14:08 am »
Ha! "Stage 1 : Inside Part"... merci pour le sourire ce matin (08:00 EST). C'est la première fois que je vois quelqu'un faire ça pour son historique de construction.  :)
I agree with jmike, make absolutely sure that your base is very strong, especially since you seem to have a huge CRT monitor on top of it. Then again, if you secure your side panels properly that will also add a lot of strength.
Sir Kayne
« Reply #6 on: September 27, 2011, 11:45:32 am »
Don't worry, the base is strong enough, I can climb on it   :lol
The structure is very stable, especially when all the part will be fix.
The huge Side will fix the inside structure (the two side are fix together by the rear plate of the cabinet).
I study the question...See the picture I post
The arrow indicate the force apply by the element
The Side stabilize Left and Side movement
The Coinbox will stabilize front movement (normally, they should not be such movement)
The Rear plate stabilize the two side (fix them together).
« Last Edit: September 27, 2011, 11:48:56 am by Sir Kayne »
TopJimmyCooks
« Reply #7 on: September 27, 2011, 11:53:51 am »
I agree that you're not going to have any durability problems with that size lumber for the frame.  Nice joinery.  Welcome.
Sir Kayne
« Reply #8 on: September 27, 2011, 06:49:28 pm »
Thanks !
Ok, time for...
Stage 2 : The Sides
First I look for a software to optimize the cut of the panels:
Opticoupe, Astra S-netting,...
Finaly, I Idea from the two software and optimize myself again
After I take pleasure to calculate the different measures.
Ok, sword up and  let's cut !
The ultimate weapon (with laser sight)  ;D
Medium make many dust, the vaccum cleaner is welcome
Of course, I cut the two side in one time
Cutting with the jigsaw 36mm medium is not easy, I cut the curve in several part
I finish the side with the belt sander and hand sanding
To finalize the two side, I use a copy tools with the wood router
Little test :
Look Ok !
Now I prepare the fixation for the rear panel
I ad a little wood 4x4mm on the inside base (at the bottom between the legs)
I fix it strongly with glue and screw
On the side I fix one too 2.5x2mm, to have something like that :
It's use to support a little the side (but what support really the side, are strong screw) and especially help by the assembling (the side 1.8mx1.1m are very heavy).
Maybe, you will ask you, how I will fix the Side ?
Keep the outside aspect without seeing any screw ?  ;)
Here the secret :
(sorry, the picture is in french)
I will use a strong screw with two nuts. The nuts 1 fix the screw on the side, the second nut 2 fix the side on the inside base.
I carve the inside base a little so the nut1 dive in. Only nut2 is use for assemble and disassemble.
Sorry, I don't know if my explication are good enough  :lol
jayska01
  • Last login:December 14, 2011, 05:38:46 pm
« Reply #9 on: September 27, 2011, 08:52:45 pm »
  >:D >:D >:D your going to have buy alot of beer for your friends to move this monster  >:D
« Last Edit: September 27, 2011, 08:57:14 pm by jayska01 »
http://forum.arcadecontrols.com/index.php?topic=114821.0
DONT NOT CLICK THIS WARNING DO NOT CLICK THIS!!!!!
  • Last login:Today at 12:05:07 pm
« Reply #10 on: September 28, 2011, 02:39:43 am »
This'll be heavy but awesome. :applaud:
Sir Kayne
« Reply #11 on: September 28, 2011, 04:02:25 am »
Of course, there will be strong rolls under ready to support over 200Kg.
I estimated the cabinet (with monitor) about 180Kg. (~400lb).
Sir Kayne
« Reply #12 on: September 28, 2011, 07:38:04 am »
Stage 3 : The back panels
Target is that :
The first difficulty was to cut the angle, I use a circular table saw.
After, a another challenge is to install the wood block at same high and position of the Side.
I make a test and note the position
I insert special wood nuts (sorry I don't know the name in english)
Fix on my panel
Assemble and fix the wood block with screw on the Side.
And so on for the other panels
My angle cut of the panel seem to be good  ;D
Now the bottom back panel
This part is a little different, because I will not disassemble it (normaly)
Use two wood fix on the bottons (screw and glue)
This part will be finish later.
Of course, for move the "monster", rolls are welcome !
Rear side
Front side with directional rolls (like the Naomi cabinet)
Each roll can support 70kg. in static and 40Kg. in movement, should be enough ! (if not I will had two more rolls).
Yvan256
    • Yvan256
« Reply #13 on: September 28, 2011, 02:11:36 pm »
Shouldn't at least two of those rollers have breaks/locks on them? Or are you planning on dancing around with the cabinet while playing?  ;)
Sir Kayne
« Reply #14 on: September 28, 2011, 03:24:05 pm »
Yes, maybe...
I think the weight of the cabinet will be enough. But I plan to put leg leveler later.
Sir Kayne
« Reply #15 on: September 28, 2011, 07:11:46 pm »
Something more for the side
The side are fix with 4 screws on the legs from the inside base
(on this picture you see the coinbox, this will be explain just after in stage 4  ;D)
I put 3 screw more at the bottom
That was not a good idea. I keep only one because it's easier to assemble and only necessary at the front finally.
Stage 4 : The front and coinbox part
Time to attack the front !
First a test without fixing
Not so easy, I must take care of the panel control for adjusting perfectly the coinbox
I prepare the front coindoor part
I think the a real coindoor is the key of a real arcade cabinet  8)
Ok, now the glue part
I check alway if all is straight
Test with the front panel
Now some technical part.
Here are the system for fix the panel
I don't want see any screw outside, but that must stay disassembled.
Look something like that
I continue with the coinbox, I will fix it with 4 strong metal screw on the bottom
I prepare before the T-molding insert.
At the bottom I prepare something special (not present of the original cabinet)
It's mean for an alu rail to protect the corner from some kick of angry players
Should look like that
Ok, the wood block for the panel are ready
Adapted perfectly
From inside, you can see the system
First it's was forsee to fix the panels with nuts, but the adjustment is so (too) just, that I don't need to fix more with nuts, I thinks.
Adjust such a construction is very hard when you don't have industrial cutting machine, that why I let cut the panel by the woodshop with the cutting robot  ;D
TopJimmyCooks
« Reply #16 on: September 29, 2011, 11:29:09 am »
Looking great - quality construction.   :cheers:
jmike
« Reply #17 on: September 29, 2011, 12:15:22 pm »
+1. Superb job. This thing is coming together really quick.
Sir Kayne
« Reply #18 on: September 29, 2011, 06:19:11 pm »
Thanks !
Actually the cabinet is more advance as you can see (I begin last year in November), that's why I have many photos to post here  ;D
But even it's not finish yet !
Special Stage : The coinbox cleaning
I get a coinbox from a friend really cheap, but need some cleaning operation
Ok, that a sega coinbox, but should be ok
Look good rust
I use a drill with a metal brush
After I try something weird. I use a spraygun with anti-rust painting
It give this hammer effect ! But it's not a good idea !
Cleaning the tools was horrible (take me 2 weeks) and it exist special finish spray color with hammer effect.
I check the coin entry, unfortunately there was broken plastic
Ok time to take my special ninja glue  ;D
I get that in Thailand for a really cheap price. This japan glue is excellent !
Ok, during this time, I will replace the coin picture (not really sexy)
I compose something better:
more sexy, more soulcalibur  ;)
Assembling the coindoor, with the repaired coin entry
Before :
After :
I repair the twisted metal and will add locks later (the cashbox will be paint too).
More to come ! 8)
Yvan256
    • Yvan256
« Reply #19 on: September 29, 2011, 09:59:07 pm »
That's a lot of progress! I'm wondering where you actually are in the building process, since you said it's more advanced than that. I really like those "forward" coin doors that stick out of the front panel.
As for that old coin door, I would never have the patience to do all that cleaning and re-painting.  :dizzy:
Sir Kayne
« Reply #20 on: September 30, 2011, 08:22:54 am »
Now a big part !
Stage 5 : Control Panel
This is a little special, because the control panel of this namco cabinet is unusual.
First I want do that:
But The real one look like that :
They use an agglo plate with groove, bend and fixed with some strong glue.
I test this solution, but it really hard to obtain that (test with agglo and medium).
So I think for another solution to obtain the curve
I will use thick MDF and sand it to round.
I will put a little woodblock behind to keep the corner strong enough.
Today I work outside, it's sunny and good for cutting  ;D
I cut first the botton of the control panel block.
Test on the cabinet (place just over the coinbox)
It's not 100% adjust, even I take really care  :-[
Ok, I will use this fine 1mm sheet of wood to make it perfect.
Now come the side part of the panel block
Here the block for the future round corner
I begin to assemble with metal bracket
But that not a good idea.
By screwing the bracket, the medium move and let light between side and bottom...I put the bracket away
Only glue should enough
Not easy to span, I use here a strap
Ok after the night a little test
Ok adjustment are need !
I put the top panel, the right side is not terrible
Left look a little better
Ok, sanding operation
Great victory  :D
Now I need the metal backet for fix the Control panel block to the cabinet
First cutting the metal
I don"t like cutting metal, is really hard to work straight without a industrial cutting machine.
Time to bend 45°
Result...
Drill the hole and test
After I have the good position, I "cut" the square hole with a little file
I put the carriage bolt and nut
I had 35mm wood block in the control panel for have more stronger side
You can notice the 45° angle on the end, it's mean for have more place when I lock the nuts  8)
I begin to curve the side
I decide to stop, when it look good for me
The difficult is to do the same curve each side...concentration  :P
View under the control panel
I finish with the hole in the middle of the bottom (like the real one).
It's mean for cable and especially for the possibility to fix the clamp (see later)
I will finish with the panel itself.
Cut and rounded like the panel block
I let 1mm between the side panel block and the edge of the panel to look really like the real one.
I'm proud of this part, it's was not easy with poor hand tools  ;D
« Last Edit: September 30, 2011, 10:58:40 am by Sir Kayne »
« Reply #21 on: September 30, 2011, 10:03:59 am »
You do great work with wood, sir.
jayska01
« Reply #22 on: September 30, 2011, 10:14:52 am »
its all about the details well done :)
RonnieC312
  • Last login:May 08, 2014, 09:27:57 am
« Reply #23 on: September 30, 2011, 10:30:59 am »
Looking great.
NFL BLitz 2K GOLD / NBA Showtime GOLD 3.0, Mortal Kombat 1, Mortal Kombat 3, Neo Geo (4 slot), Lethal Enforcers, GT 99, Time Killers, Midway Classic PS2 stand-up, DreamCast HOD, 32 ' MAME machine, NBA Hangtime, Zombie Revenge, Touch Master
Sir Kayne
« Reply #24 on: October 03, 2011, 07:21:31 am »
Thanks for support  ;D
Time to fix the panel
I get some latch (not really strong, but will be enough)
I take a block of medium, drill and but an carriage bolt
On the other side, I fix my latch
(the 2 additionnal screw come later)
After I glue the block on the side
But before I do a test in situation, for have the good position (not easy)
Ok, look good I can fix it
It's Ok  ;)
I fix all
Aerial view !
Inside
Next the buttons and sticks hole
The position and disposition is like the real one.
You can notice a metal plate over the wood panel
The real one
I must cut a large metal plate straight, it's a nightmare, but I will show you next time, how I do !
DCsegaDH
« Reply #25 on: October 03, 2011, 11:47:24 am »
Nice work, I really like this build ;D
BurgerKingDiamond
« Reply #26 on: October 04, 2011, 12:50:52 pm »
You are doing a really great job.  :applaud: :applaud: :applaud:
Your English is good, but with just enough errors to be an entertaining read.
Please make more progress quickly. I want to see how this turns out.
-Welcome to the Fantasy Zone.
Sir Kayne
« Reply #27 on: October 05, 2011, 07:34:59 am »
Thanks (even my English is not so good  :laugh:)
Today, cutting the metal plate for the panel
That a hard part, cutting metal is not easy, especially with hand tools like a simple saw...
Hopefully, my father lend me a jigsaw with a special metal blade (until 3mm)
It's better, but impossible to be 100% straight...
I cut little part and adjust each time with the file
Very long...(take me 2 weeks), but finally I get that :
Better as I hope  ;D
I wait  3 weeks more for get this precious, but very cheap, drill
Little test
It's really easy to drill the 1.5mm metal plate !
Let's fight !
In the wood
In the metal
I get that (I begin to paint during the waiting of the tools)
The joystick are, like the original, Suzo-happs system 500 sticks
After, I get the screw 8-32 carriage bolt (who only exist in USA in this size)
So I can fix correctly my joystick and metal plate
Unfortunately, it's was impossible to find carriage bolt over 3/4" length. It's okay for the joysticks, but to short for the panel and the wood  :(
Maybe I will find some later...
(if someone know an shop who send to Europe ?!)
« Reply #28 on: October 05, 2011, 01:18:35 pm »
Nice, I love the SUZO 500's!  :cheers: Don't you have a router so your can route out a clear space under each stick so your carriage bolts only have to clear the metal plate + stick?
Starcade (conveniently located in France) has carriage bolts: http://www.starcab.net/product_info.php?cPath=204_135&products_id=477 Unfortunately, only the shorter type seems to be in stock.
Sir Kayne
« Reply #29 on: October 05, 2011, 03:43:53 pm »
Oh I forget to take a picture under the panel at this panel.
I rout out a space for the stick and there directly fix on the metal plate.
Here are a photo little more advance (paint and T-molding)
The problem with the too short screw are only for fix the metal plate on the wood panel. I know starcab, but they don't have the long model of bolt (and they are a little expensive, I get it cheaper in USA even with shipping  ;D)
« Reply #30 on: October 05, 2011, 04:00:24 pm »
I would skip the screws from metal to wood and just add a mounting plate from below instead. Unless you feel that the carriage bolts look good/authentic on top, you can hide them by mounting them from below instead.
Sir Kayne
« Reply #31 on: October 05, 2011, 06:10:11 pm »
Yeah, that a good system, maybe I will use for next cab  ;)
For this one, I want do replicate exactly the same system as the Namco cab. That why I let the bolts on the top, like the real one  8)
Sir Kayne
« Reply #32 on: October 05, 2011, 06:47:34 pm »
Stage 6 : The Instruction and Loudspeaker panel
This part was long too
First CAD draw
It's always like the real one.
This time I get ill, and cannot work too much...I lost one week  :angry:
"Sir Kayne was seriously wounded, but the soul still burns." ;D
Ok, let's go
Cutting the panel (10mm Medium)
Inside
outside
(you can already see the special support for the screen, I will explain later how I built it)
I need a wood block for support the glass
I use the router for do it clean.
I fix it with bracket, I don't like this system but I must keep the disassemble possibility
Adjusting is not easy, but I done !
Now the very long part...
Here are the original
You can notice the many hole for the loudspeakers
Let's do the same
Horrible to be straight :P
440 holes later...
Time to fix the loudspeakers
I will put a second 10mm plate behind the first one, so I can hide the screw
Preparing the second panel
Test by installing the loudspeaker
Look OK ! 8)
On the first panel, I do some carve in the wood for the head of the screw
It will look like that
Glue and clamp !
Here a more advance photo (with painting)
I begin to try a plastic sheet for the future instruction holder
PS : sorry my photos are not in chronological way, sometime I work on my side, after on the panel, and again on side, etc... That why you can  notice more advance of some photos as I describe.
Yvan256
    • Yvan256
« Reply #33 on: October 05, 2011, 07:49:52 pm »
880 holes on a grid pattern... And I thought I was capable of patience.  :dizzy:
« Reply #34 on: October 05, 2011, 10:48:54 pm »
Nice work, in particular the things I like about this is your approach to joinery, your detailed thread covering your design and woodworking and the really solid build of this cab.  Are you going to fill any joinery gaps and smooth edges?  I'll be following along with your progress.
Sir Kayne
« Reply #35 on: October 09, 2011, 07:32:57 pm »
Yes the cab is solid, it's important, because it's really heavy (I estimated 150Kg for the moment).
I will fill the screw hole with "wood paste" and sand to have a smooth surface for painting.
Let's show
Stage 7 : The monitor
The monitor I have, is about 35Kg., so I must imagine something really strong to support it.
I imagine a frame with wood and support in metal
This system allow to give different angle of view.
The monitor have 4 ring fixation like that:
Time to cut, with the Japanese sword !
This saw is call "Japanese saw", it really really good. You cut faster and more precises as a normal any saw. Even the quality of cut is better than the best electric saw !!! Must have !  :notworthy:
Here you see as test block, to find the good shape to fit around the screen
After I copy the shape with the router on the final wood block for the frame.
After I drill for 10mm bolt (should be enough)
I fix the complete frame with bolt again. I want something really strong and prevent from wood splitting with normal wood screw
(and can be disassemble, If need).
Test
Ok, time to prepare the base for the frame
I use 19mm medium
Prepare the bracket
You can  notice the corner are round, to have a better rotation
I assemble the frame and fix the bracket
The screw look too long, it's just a test. I will put shorter later.
I put L-form metal rail and metal profile to complete the system.
It's begin to be night...hard to stop when you "wip"  ;D
Inside the cab
The base will be screw on the inside table for fix everything strongly.
The advantage is that the monitor is not fixed on the side (like many arcade cab), but on a inside table.
Next day, I attack the bezel
I use a 10mm medium plate
Shape nicely with the router
In situation :
I put a frame inside on the side and the top panel, it's mean for the future glass window.
But the bezel is not really push on this frame.
So I image a system from inside with a bracket
View on the top panel
From inside
Outside
Look better  ;)
Ok, next time some complete photos from the assembled cab, stay tune  ;D
TheChairmanH2K
  • Last login:October 08, 2013, 12:53:17 pm
« Reply #36 on: October 10, 2011, 06:44:36 pm »
the quality of your craftsmanship is outstanding   :applaud:
Sir Kayne
« Reply #37 on: October 11, 2011, 07:14:37 am »
Thanks  ;)
Ok, today an assembled view !
(without the roll)
Everything fit perfectly, but I should let more space it's difficult to assemble and disassemble.
(I will later correct a little the different part)
On this fotos, the bezel cut, the control and loudspeaker panel is not drill already (it was before fotos)
Extra stage : Side decoration
The original cabinet has such strange side decoration. It make look the cab bigger, but especially heavier  :laugh:
I want do a reproduction, so I decide to ad that too !
First, I need a 19mm plates
I put the two together and fix
cutting
cutting again and sanding
I put my sides decoration with the big sides from the cabinet
4 layers sandwich !
I want sand all together, but that was not a good idea
Finaly , I use the router and work with only 2 side (my router tool is not long enough for 4 layers of 19mm)
Time to fix
Look like the real one !
For finish some extra photo from inside
I will put shelf inside the cab (2 or 3), so I can easly install different system (jamma, mvs system, pc, etc...)
BurgerKingDiamond
« Reply #38 on: October 11, 2011, 11:32:28 am »
wow! you made it even heavier. I think that if your house ever collapsed in an Earthquake or something that thing would still be standing.
Sir Kayne
« Reply #39 on: October 14, 2011, 06:32:37 am »
Yes, I live in a region with Earthquake risk  ;D
Ok, now the very hard part for me....The painting !
Stage 8 : The painting
Time to fill the hole (wood filler)
Ok here are the product:
Primer for everything (advice for the medium) (German product)
I use black acryl paint for wood, but this product is not resistant (not a good idea)(French product)
It's written "one layer color". That's probably french humour  ;D
Acryl paint with primer include (German product again)
Really good and strong paint for acryl.
It's many surface to paint, so I use the spay gun (first time for me  :laugh:)
My first test on the front panel (of course I test before on a wood block)
One of the panel go wrong ???  ???
The spaygun was not good clean probably
Ok, I continue with the coinbox
Not perfect, but I will add another layer
I assemble for give an idea of the final result
More to come...
