Author Topic: My completely homemade arcade machine  (Read 62100 times)
arximidis
  • Last login:March 20, 2020, 03:52:48 am
Re: My completely homemade arcade machine
« Reply #160 on: March 02, 2013, 11:46:36 am »
That wasn't really intended to be an insult. I have honestly never seen someone design their own hardware and software from scratch with a first project. You might be the first person to have ever done that.
I wasn't insulted. After all you didn't say anything to insult me (Generally I am not insulted easily :) )
I only said, I don't understand and I disangree with this kind of thinking
It is not my first project... I work with electronics all the time... However, It was the first time I build something out of wood
Moreover, I have something than most of you guys don't. I am not much of a gamer, so I didn't mind to wait more, to complete the cab. Most of you, are gamers and you want to start playing with your cab as soon as possible.
Me, in the other hand, is very possible to give the cab away, when I complete it (complete  = to the degree I will be satisfied by the result)
A lot of this forum is dedicated to reinventing the wheel because it is not yet perfectly round. Thanks for giving us more options to fashion our own wheels.
Take a chill pill, you done good man!  :applaud:
My wheel is not perfectly round eather. Maybe it's even worse than others.
This thread it's not about reinventions or whatever. It's just an implementation.
The cool thing is that I will publish everything... I do have problem in designing the plans for the cab, but I'll try to create same sketches
A great job!
 :applaud: :applaud: :applaud:
arximidis
« Reply #161 on: March 05, 2013, 05:18:07 am »
arximidis
« Reply #162 on: March 15, 2013, 05:09:59 pm »
The time for the schematics has arrived :)
As you may know, I started building the cab without having any design plans. That is way I didn't upload anything
After completing the cab, I thought it will be difficult to draw them. So all this time I was avoiding it. Thanks to google sketchup program, I manage to draw them very quickly. And it is the first time I use the program
I have already complete the designing. Only the internal parts, the holes and the doors are remaining
I will use different files so to directly load them to the program (in order to help you out).
Each file will have extra information
In the followning pictures you can see my work so far. These are the actual dimesions, even in thickness. The boards are the ones I actually used. The mdf sides are in correct shape with a very small error, less than 3mm (mostly on the curves). The possition of the boards are absolute, except in some cases where I have a less than 3mm error
The design palns are pretty close to the actual cab. I wish I had them when I started the project
This google sketchUP program is fantastic. Extremelly easy to go from 2D to 3D.
« Last Edit: March 15, 2013, 05:38:56 pm by arximidis »
arximidis
« Reply #163 on: March 17, 2013, 01:00:22 pm »
Desing plans. The internal
There are few things to draw left and it will be ready  :)   (ready to upload  ;) )
arximidis
« Reply #164 on: March 18, 2013, 08:06:28 am »
Two things are missing now. The holes of the controls and something to the coin acceptor. The latter is more difficult not because is hard to draw, but because I must unscrew the coin accepton from the machine to take the mesurements (this drawings are exact replica of my cab)
The backet
The pathway
« Last Edit: March 18, 2013, 08:11:13 am by arximidis »
arximidis
« Reply #165 on: March 19, 2013, 11:33:54 am »
Design plans
I have uploaded the basic schematics of the cab in google's sketchup (version 8)
Later I will upload pictures showing the dimensions (like blueprints)
http://users.ntua.gr/dpiperid/MyWebPage/Contructions/others/mame/schematics/designcabEN.htm
Damian
  • Last login:July 23, 2013, 06:16:13 pm
« Reply #166 on: March 20, 2013, 01:54:07 pm »
What became of your gun controller? Are you still pursuing your mysterious (and intriguing) new design?
Nice work on all of this stuff. I think it's cool that you made your own hardware interface.
Damian
arximidis
« Reply #167 on: March 21, 2013, 04:48:00 am »
Damian
Thanks Damian
Well, the problem was that I left some things behind, so I have set my priorities on the to-do list
I am thinking first to upload all the design plans for the cab
Then to complete and upload the schematics for the interface (upload also the necessary firmware and step by step instructions). I already have the first update for the interface, as an extension (=controlling the machine with your android phone. Play pacman by simply giving a slope to your phone, right, left, forwards and backwards --> my English sucks :( . I don't now how to write it better. This is also one of the reasons I am uploading to English forums. To improve them. ;) So feel free to correct me :))
When I complete all that, then I will work on the gun controller
About the gun controller:
I already bought the necessary hardware (meaning that I will build it eventually). My design is based on ultrasound and a gyro (and accelerometer) and infrared (I need the speed of light for sync reasons).
I am measuring the distance with ultrasound sensors (made some tests already) and the angles with the gyro (accelerometer). Well it's not so easy and I don't know if it will work better than other solutions, but it's a challenge for me. :) After all I am not much of a gamer and I don't think I will ever play with the cab. I prefer building stuff :)
One cool thing looks like to be, it will not need recalibration
« Last Edit: March 21, 2013, 12:49:18 pm by arximidis »
arximidis
« Reply #168 on: July 23, 2013, 12:37:46 pm »
« Last Edit: January 09, 2014, 02:09:28 pm by arximidis »
arximidis
« Reply #169 on: July 23, 2013, 03:17:17 pm »
« Last Edit: January 09, 2014, 02:09:09 pm by arximidis »
arximidis
« Reply #170 on: July 24, 2013, 02:37:00 pm »
« Last Edit: January 09, 2014, 02:08:50 pm by arximidis »
arximidis
« Reply #171 on: July 30, 2013, 09:50:28 am »
All connections diagram
arximidis
« Reply #172 on: January 09, 2014, 02:36:02 pm »
Hello again and a happy new year to all
Meanwhile regarding this project I am very unlucky
As you may know I have created my custom controller/interface for a while and 2 or more months ago, I finally put the final "touches" to the code.
Just before the first test, my computer died and I had to replace it. Thank God, I had another one lying around. I also found a better way to attach it in the machine. So, no harm no foul.
I connected the controller/interface and the wires for the buttons and joystics (as you see in the pictures).
And just when I was ready for the first (complete) test, my television died!!! :( :(
Now, It's really hard to fix, because it's imposible to move the machine to my lab. On the other hand, my workload has increased (and it will increase more) and is difficult to find time for the machine or the other projects I am working on...
The thing is that these problems are holding me back and I really want to start my (light) - gun project...   :angry:
And I have a couple of other projects to start (nothing to do with the machine)  :banghead:
« Last Edit: January 09, 2014, 02:44:14 pm by arximidis »
arximidis
« Reply #173 on: May 07, 2014, 09:29:37 am »
TEST DRIVE
This is probably the last post on this thread.
Any update I'll post it in a new thread
You don't see it in the video, but I have also tested the "shock " sensors. They are working just fine!!!
