Author Topic: 25 inch 4x3 monitor  (Read 31751 times)
sonnydaze
  • Last login:May 18, 2012, 07:49:17 pm
25 inch 4x3 monitor
« on: September 22, 2011, 12:29:38 am »
im looking to replace my wells gardner k7191 with a pc monitor , what monitor would be best ? does anyone make 25 4,3 monitor or do i need to put in a 22 ws monitor
if anyone has a 22 lcd ws in a 25 inch cab cab you post pics please
Blanka
Re: 25 inch 4x3 monitor
« Reply #1 on: September 22, 2011, 02:24:07 am »
The largest LCD 4:3 is 21.3 inch, but these are very expensive, but is has 55mm more vertical height than a 21.5 inch FullHD display!
The largest 4:3 image can be had with a 27 inch 16:10 LCD, which has a 24 inch 4:3 image (probably rougly the same as CRT's were not always measured to true image size). I have a 27 inch 1920x1200 in my cab.
wxman13
  • Last login:January 24, 2024, 10:12:02 pm
« Reply #2 on: September 22, 2011, 04:38:57 pm »
What brand/model LCD 27 inch?
sonnydaze
« Reply #3 on: September 22, 2011, 05:46:42 pm »
now im more confused , how can a 4:3 be 16 :10 and a 27 inch be 24 inch
StriderDSO
  • Last login:May 11, 2019, 10:15:34 am
« Reply #4 on: September 22, 2011, 05:53:21 pm »
A 27" 16:10 monitor works out to:
y = 14.31"
x = 22.896"
x (usable) = 19.08"
waste = 3.8"
A 24" 4:3 monitor works out to:
y = 14.4"
x = 19.2"
x (usable) = 19.2"
waste = N/A
So what he is saying is by using a 16:10 27" monitor, you achieve the same image you would get with a 4:3 24" monitor.
(Note, the 'waste' is just the part of the screen that is not being used when running a 4:3 window)
(\__/)
(='.'=) This is Bunny. Copy and paste him into your
(")_(") signature and help him on his quest for world domination.
sonnydaze
« Reply #5 on: September 22, 2011, 10:22:34 pm »
y = 14.31"
x = 22.896"
x (usable) = 19.08"
waste = 3.8"
y = 14.4"
x = 19.2"
x (usable) = 19.2"
waste = N/A
dont think a 27 inch monitor will fit
Dartful Dodger
  • Newer isn't always better.
« Reply #6 on: September 23, 2011, 03:49:57 pm »
Why is it referred to as 16:10 instead of 8:5?
For all the other aspect ratios they use the lowest numbers.
newmanfamilyvlogs
    • Newman Family Vlogs
« Reply #7 on: September 23, 2011, 04:45:50 pm »
To contrast it more clearly against a 16:9 as being slightly wider.
Dartful Dodger
« Reply #8 on: September 23, 2011, 05:14:53 pm »
I see, they had to dumb down the aspect ratios so the ignorant masses could understand them.
I suppose 4x3 is more or less obsolete so we don't have to worry about them being renamed 16x12.
mrclean
    • Guscade
« Reply #9 on: September 23, 2011, 06:57:39 pm »
2,370,650 Gun.Smoke
sonnydaze
« Reply #10 on: September 24, 2011, 12:33:59 am »
think im getting this on it 20 inches across 15.7 high 5 wide and ways 10 lbs aspect 16:10 . what does everyone think ? looks like it will fit very nice
  http://www.walmart.com/ip/Acer-V223WEJBD/14575828?findingMethod=rr#BVSecondaryCustomerRatings
sonnydaze
« Reply #11 on: September 24, 2011, 01:10:37 am »
Brian B
  • Last login:April 28, 2015, 07:32:02 pm
« Reply #12 on: October 05, 2011, 05:20:35 pm »
Well, every ratio should be referenced to 1 and then it would be easy to understand which is wider, i.e. 1.33:1 (4x3), 1.6:1 (16x10), 1.78:1 (16x9), etc.
B.
Lilwolf
« Reply #13 on: October 06, 2011, 07:08:26 am »
for 3:4 monitors... it can be easier to find them on ebay then stores.  Not to many being made now... but lots of old ones around.  But it will be used and stuck pixel chances increase.
davidgilmour
  • Last login:April 11, 2025, 09:01:44 pm
« Reply #14 on: December 24, 2020, 10:31:08 am »
There are 40 inch Pioneer plasma monitors out there, they are awesome for wall mounted cabinets.
formula409
  • Last login:January 03, 2021, 02:13:17 pm
« Reply #15 on: December 31, 2020, 06:03:11 am »
Honestly your best bet for a flat screen at this point is to get the LG 48" OLED and mount it vertically. It'll fit in some of the bigger 25" monitor cabinets.
lettuce
  • Make It So!
« Reply #16 on: December 31, 2020, 10:59:20 am »
I mean you could get a 32"-40" LCD TV and mount it vertically in the cab?
formula409
« Reply #17 on: January 01, 2021, 01:14:36 am »
The LG OLED 48" is the best option. It's the only one in that size class that has variable refresh.
Getting a flat panel that doesn't have variable refresh is stupid in 2021.
dmckean
« Reply #18 on: January 01, 2021, 07:30:06 pm »
Putting a $1600 OLED TV that is too large in a cabinet is ridiculous advice.
fallacy
  • Last login:February 12, 2026, 09:38:46 pm
« Reply #19 on: January 01, 2021, 11:57:03 pm »
post a pic of your cab
« Last Edit: January 02, 2021, 12:01:03 am by fallacy »
Vocalitus
  • Last login:October 25, 2021, 06:16:58 pm
« Reply #20 on: January 02, 2021, 05:54:58 am »
Go to Goodwill.
I picked up 2 20" 4:3 monitors (ViewSonic) for $5 each (senior discount).  They work great.  Heavy though and no stuck pixels.
You can get away with 17" too.
formula409
« Reply #21 on: January 02, 2021, 08:49:32 am »
Nickel and diming something that's supposed to be an impressive amusement machine is ridiculous advice.
Arcade games SUCK without variable refresh on a flat panel. A real CRT or a variable refresh monitor are the only quality options.
  • Last login:February 11, 2026, 07:46:44 pm
« Reply #22 on: January 02, 2021, 04:17:53 pm »
No silly.... his point is for $1600 you can just buy a fully restored cabinet with the monitor you want in most cases.  Cost absolutely matters.
formula409
« Reply #23 on: January 02, 2021, 06:56:19 pm »
It really doesn't. Two grand is chump change. If you can't afford that you've got bigger problems than buying an arcade cabinet.
Not everyone wants an original cabinet. Some people want to be able to run old games via emulation and new PC games as well.
Yenome
  • Last login:November 14, 2025, 04:36:28 am
  • Punch a fish. Make a wish
« Reply #24 on: January 02, 2021, 07:15:20 pm »
instead of 1600 dollars you can get the samsung q80t for around 900 at 50in its a qled with VRR. you could also get a monitor with freesync/gsync that has a range to support all the arcade games using at least double games original hrz.
SirPeale
  • Green Mountain Man
« Reply #25 on: January 02, 2021, 08:22:28 pm »
Unreal. You're abrasive enough to pull even me out of seclusion.
Your viewpoints are drawing rather negative attention. Just fair warning.
formula409
« Reply #26 on: January 03, 2021, 11:49:06 am »
Here's my warning to you: don't screw with me. You should be afraid of me--not the other way around.
JulesWallet
  • Last login:January 03, 2021, 01:23:24 pm
  • Is the Popeye still available
« Reply #27 on: January 03, 2021, 01:17:21 pm »
Ohhh, Internet tough guy. Watch out!
JulesWallet
« Reply #28 on: January 03, 2021, 01:23:24 pm »
Personally I feel arcade games should be played on CRT’s. But to each his own. But, spending 2k on a monitor for a mame machine is crazy.
« Reply #29 on: January 03, 2021, 02:14:56 pm »
Well there's a genius.  He threatens a global moderator, which can perma-ban him and then warns said moderator should be afraid when he can do exactly jack and squat to him.  Go ahead and perma-ban this guy please, we don't need anymore paper tigers throwing out unwarranted hostility.
  • Last login:February 12, 2026, 03:35:47 am
« Reply #30 on: January 03, 2021, 02:42:15 pm »
Agreed.
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:February 11, 2026, 06:56:49 am
« Reply #31 on: January 03, 2021, 03:44:57 pm »
Sorted.
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #32 on: January 04, 2021, 02:19:00 am »
Sorted.
That's how you end up wrecking a shoulder.  Just sayin'  :duckhunt
Ropi Jo
  • Last login:January 18, 2026, 05:05:12 pm
« Reply #33 on: January 05, 2021, 08:43:06 am »
Thanks for that. Funniest thing I've read this year.
With all the sh*t going on in the world I really needed a good laugh.
DaveMMR
« Reply #34 on: January 05, 2021, 10:07:55 am »
I never realized I had problems until I balked at the idea of throwing $2000 at a wooden box that plays video games.  :'( :'(
Hoopz
  • Intellivision Rocks!
« Reply #35 on: January 05, 2021, 10:19:33 am »
Anyone else amused that a necrobump to a nine year old thread has caused issues?   :dizzy:
bobbyb13
« Reply #36 on: January 14, 2021, 04:41:36 am »
The funnier part is that the guy from Pink Floyd was the one unintentionally stirring the pot
bsoder52
  • Last login:June 24, 2025, 11:29:40 pm
« Reply #37 on: April 05, 2021, 03:03:29 pm »
Ran across this post today while trying to find a monitor to fit an arcade cabinet with 21" wide X 16" opening. Is 24" the largest 4:3 monitor? I called Dell and they don't even make 4:3 anymore. Thanks for any help!
nitrogen_widget
« Reply #38 on: April 06, 2021, 05:59:25 pm »
25" crt TV has a screen size of roughly 20" inches by 15".
a 27" CRT TV screen is roughly 21.5" x 16".
I say roughly because i have multiple 20" CRT's and there are slight size differences between models and that's with the case still on.
some crt's I can tell there is more screen just waiting behind the bezel.
a 43" LCD TV flipped vertically will have a width of 21".
but you gotta do something with the other 22" of screen you don't need.
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
« Reply #39 on: April 16, 2021, 02:07:37 pm »
My favorite setup is a large screen rotated 90. If your lucky the top can display a marquee.
