Author Topic: Make your own super silent switches, with video  (Read 2503 times)
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
« on: September 17, 2011, 03:59:34 am »
I decided to make my own "versa micro switches" with existing "E-switches" i had (they are quite loud)  Use a 9/64 drill bit and drill through the side like the picture shows.  Grab some 5/64 hex socket screws (got mine from local hobby store) and screw down to desired "loudness"
EDIT:  Found some smaller hex set screws (3/16) and then used a 1/8 drill bit.  These are a bit less intrusive
« Last Edit: September 18, 2011, 12:58:36 am by equlizer »
MajorHavoc
  • Last login:December 04, 2015, 09:08:40 am
Re: Make your own super silent switches, with video
« Reply #1 on: September 17, 2011, 10:17:05 pm »
Nice work.  :applaud: I'm impressed by the difference.  Does the mod affect the performance of the switches?
« Last Edit: September 17, 2011, 10:20:01 pm by MajorHavoc »
equlizer
« Reply #2 on: September 18, 2011, 12:41:44 am »
They respond much quicker.  I also have some of the micro leaf switches and the modded ones are almost comparable cept you cant put micro leaf in a joystick  :timebomb:
« Last Edit: September 18, 2011, 12:59:14 am by equlizer »
« Reply #3 on: September 18, 2011, 05:51:15 am »
Yes you can, see my mod for how to do that here....... http://forum.arcadecontrols.com/index.php?PHPSESSID=6dc8a2747fafb0ad2b1f0a686e1b9da6&topic=95361.0
equlizer
« Reply #4 on: September 18, 2011, 06:10:44 am »
umm i dont see anywhere in that thread you using micro leaf switches in a joystick.
This is the micro leaf: http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=73&products_id=309
« Reply #5 on: September 18, 2011, 06:35:48 am »
Yeah, sorry I just re-read this, your mod made me think you were comparing to Versa Micro switches not the leaf switches.  In fact I have both of those switch types too.   :cheers:
equlizer
« Reply #6 on: September 18, 2011, 07:01:27 am »
Have any of your versa or micro leaf switches broke or whatever in the last few years?  Had to made adjustments later on?
« Reply #7 on: September 18, 2011, 07:57:45 am »
None have broken, although I haven't had them more than about a year.  I've found that the Versa Micro Switches should only be adjusted to the point where they are almost silent for the most reliable performance.
