Author Topic: Xbox 360 and Mame Cabinet...Possible?  (Read 8835 times)
fibreoptix
  • Last login:October 26, 2011, 12:40:08 pm
« on: September 09, 2011, 10:30:25 pm »
Okay first post. Just discovered all this "Build your own Arcade" stuff 2 weeks ago. Ipac, KVM switches and all these arcade supply stores... so exciting!!!!
I'm gonna do it... in the spring. But! until then over the winter I'd like to get a game plan down. The design/Wood working part I got down. No problems there.
So this is what would be awesome.
1 Arcade Cabinet that houses a Mame system (pinball buttons, trackball all that jazz) and an Xbox 360 controlled by one Control panel for both systems (trackball mame only). Is this possible? What I have been reading is no... Microsoft will not allow xb360 pads to be used on a PC.
But what if I hook up an Ipac as you normally would, hack a 360 pad with the wires going directly to the buttons. Could that work?
Well Fed Games
  • Delicious!
Re: Xbox 360 and Mame Cabinet...Possible?
« Reply #1 on: September 09, 2011, 10:54:59 pm »
There are folks here who know all about what you want to do, and have done it themselves, but I can can confirm that wired Xbox pads (or in my case, I have a couple 360 arcade sticks I want to use for projects, one Hori EX2 and one HRAP) are great for PC.
fibreoptix
« Reply #2 on: September 09, 2011, 11:21:41 pm »
When you say "wired Xbox pads" do you mean the XBox 360 or Xbox 1?
So your saying just get a Hori and convert it into a full control panel?
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #3 on: September 09, 2011, 11:34:39 pm »
It is possible, that is what I did on my cab
fibreoptix
« Reply #4 on: September 09, 2011, 11:46:39 pm »
So let me get this straight... Im right?
Just to be clear.
1. Hook up PC controls using an Ipac4 or Ipac2 (whatever)
2. Then hack 2 or 4 Xbox controllers bypassing the Ipac straight to the buttons.
That's it? Do they need to share a common ground?
« Last Edit: September 09, 2011, 11:48:46 pm by fibreoptix »
Donkbaca
« Reply #5 on: September 10, 2011, 12:24:51 am »
Easiest way to do it is to hack 2 xb 360 pads
fibreoptix
« Reply #6 on: September 10, 2011, 12:26:48 am »
Okay then how do I connect the controls to the PC?
amendonz
« Reply #7 on: September 10, 2011, 12:31:28 am »
usb, the controls are recognised by windows, if the particular emulator doesn't support it you can use xpadder
« Last Edit: September 10, 2011, 12:41:52 am by amendonz »
fibreoptix
« Reply #8 on: September 10, 2011, 12:35:03 am »
usb, the controls are recognised by windows, if the particular emulator doesn't support it you can you xpadder
Oh.... that is awesome. Thanks guys.  :applaud:
fibreoptix
« Reply #9 on: September 10, 2011, 12:56:36 am »
In Light of Xmapper which answers 80% of my questions (thanks again). I got 2 more.
1. I really like Pinball games on the xbox360 (Williams collection mainly). I assume this is doable but just to be sure. The trigger buttons. Can I duplicate their function? Meaning have the 2 triggers as buttons on top of the CP and run another wire from the xb360 pad to the sides as well? Just checking.
2. If I wanted LED buttons can I use LEDWiz or will that screw up the XBox 360 controls? or is there a better way?
notroubleclubber
  • Last login:October 07, 2023, 04:26:25 pm
« Reply #10 on: September 10, 2011, 05:28:36 am »
Not sure bout question 1. I believe the trigger buttons are fine as those hori pads are digital not analog?
question 2 is easy - you can use ledwiz or pacdrive to light the buttons as the wiring for the leds are seperate to the buttons microswitches so wont interfere with xbox
Donkbaca
« Reply #11 on: September 10, 2011, 12:22:27 pm »
Get the street fighter iv pads and hack them. The triggers ate digital, no need to convert them from analog
fibreoptix
« Reply #12 on: September 10, 2011, 03:01:12 pm »
Like this one http://www.videogamesnewyork.com/index.php?main_page=product_info&products_id=547
Donkbaca
« Reply #13 on: September 10, 2011, 03:39:06 pm »
Yup, those are the ones
SNAAKE
  • Trade Count: (+29)
« Reply #14 on: September 10, 2011, 03:49:59 pm »
you can get these if you cant solder. and you have ps3 support.
http://etokki.com/Xbox360/Joytron-Paewang-Revolution-PCB-Only
fibreoptix
« Reply #15 on: September 10, 2011, 10:23:01 pm »
Wow cool. Thanks. In mame is it possible to remap the buttons....... I guess it is... sorry stupid question.
fibreoptix
« Reply #16 on: September 10, 2011, 10:30:22 pm »
If I got the Xbox control route can I still use a trackball?
Donkbaca
« Reply #17 on: September 11, 2011, 01:09:01 am »
I'm confused, looks like you have to solder to that PCB, plus its expensive, I got my pads for like 25 a piece.
Anyhow, yes, you can remap buttons in MAME.  If you want a trackball, just get a USB one.  I personally don't think they are worth it.
ark_ader
  • I glow in the dark.
« Reply #18 on: September 11, 2011, 07:15:16 am »
Has anyone experienced any issues with the latest Xbox 360 update and the Hori interface?
Donkbaca
« Reply #19 on: September 11, 2011, 01:20:53 pm »
No
fibreoptix
« Reply #20 on: September 12, 2011, 10:06:31 pm »
Seems like you had success hacking these. Ive been reading up on them and apparently they are a arcade hackers dream. 2 questions.
1. Where is the LT and the RT?
2. What are those buttons on the beside the start and back?
Martijn
  • Akira!
    • ModMyBox
« Reply #21 on: September 13, 2011, 07:08:05 am »
i use them aswell, but was hard to find new in my country, i had to search 2ndhand market websites for them
lt and rt are on the shoulders of the pad
in the middle is a turbo function and on the back a analog stick to 4way pad switch
  • Last login:February 22, 2026, 06:49:16 pm
« Reply #22 on: September 13, 2011, 10:00:30 am »
Yeah, all the wired hacks I do for people now are done using the MadCatz FightPad.  Best bang for the buck...
@Donkbaca, the pads are no longer $25 at vpgames.  They're back up to ~$40.
fibreoptix
« Reply #23 on: September 13, 2011, 10:06:32 am »
Fantastic.. thanks I think I'm going to go with these.
There is a four way and 8 way switch on the back. Should I leave it switched on 8? Or does it matter?
fibreoptix
« Reply #24 on: September 13, 2011, 10:09:53 am »
There is no Street Fighter at my local EBGames only a wwe-all-stars-brawl-pad, however I think I can safely assume it's the same thing right?
http://www.gamestop.ca/xbox-360/xbox-360-wwe-all-stars-brawl-pad/309281
« Reply #25 on: September 13, 2011, 10:10:31 am »
On the back of that controller?  It's a D-Pad / L stick / R stick switch...  Just leave it on D-Pad (center position)
« Reply #26 on: September 13, 2011, 10:11:13 am »
Most likely.  It looks like the same exact controller, just different printing on the shell.  Has all the same functions.
Donkbaca
« Reply #27 on: September 13, 2011, 11:18:17 am »
Bummer.  VP games is a good place to get stuff cheap though, keep an eye out on them.
THe madcatz fightpads are by far the best way to connect to a xbox 360 and a PC, seeing as how you can find them cheap on occassion.
Mrephunk
  • Last login:July 17, 2012, 12:56:47 am
« Reply #28 on: September 13, 2011, 10:46:13 pm »
I was just able to find a couple used ones on Amazon for about 25 each
