Author Topic: MAME speedup for Jr Pacman resets to default after pwr off  (Read 2751 times)
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
« on: August 09, 2011, 04:36:37 pm »
I don't normally use any "cheats", but Jr Pacman needs the speedup on for me to even play it. Normal, its brutally hard. Problem is, it works fine when you set it to "on" via the tab menu, but I notice pwr'ing up the game the next day, its set back to default. I never had this problem with older versions. Is there something that needs to be done to get it to save the setting or is this a bug in .141?
boardjunkie
Re: MAME speedup for Jr Pacman resets to default after pwr off
« Reply #1 on: May 04, 2012, 10:02:57 am »
Bump.
Actually you just exit the game and the speedup cheat goes back to the default off setting. I tried enabling save state just for this game and it still doesn't help. Anyone???
boardjunkie
« Reply #2 on: July 08, 2012, 11:13:08 am »
Nevermind. I just did a "rom swap" for the 8D file. Works fine...won't have to worry about in now.
« Reply #3 on: August 25, 2012, 05:29:51 pm »
Any suggestions on what to search for in google for the 8d version?  Can you elaborate more on how you did the swap?  Is it the same filename?
Thanks in advance!
D
Gray_Area
  • -Banned-
  • -Banned-
« Reply #4 on: August 27, 2012, 04:17:09 am »
Just learn to play the game. It seems hard, and then you find how you can fool the ghosts. Then it gets fun.
-Banned-
nitz
  • Last login:November 24, 2015, 07:57:29 pm
« Reply #5 on: August 28, 2012, 08:13:56 pm »
Thanks in advance!
D
It's in MisfitMame, the romset is named jrfast. That might help you search. ;)
Not sure about swapping files, but if the same filename is in the mame set, it might work - though mame will complain about it. ;)
« Reply #6 on: September 14, 2012, 08:35:21 pm »
Wow. Jrfast.zip is hard to find.
Before I continue on my search... Has anyone tried renaming stuff and doing the swap?
What are the contents of the file? I'd like to see if they match up with the normal version.
Slippyblade
« Reply #7 on: September 14, 2012, 08:53:09 pm »
How does MAME do Jr. Pac?  Didn't that one have a weird setup that was half video game and half pinball??
  • Last login:Today at 04:52:49 am
« Reply #8 on: September 14, 2012, 09:28:38 pm »
Slippy - You're thinking about the Baby Pacman Visual Pinball table using VPinMAME here.
Slippyblade
« Reply #9 on: September 14, 2012, 09:42:49 pm »
D'oh!  Sorry - got em mixed up in my head.  Thanks for the link.
« Reply #10 on: September 20, 2012, 05:05:01 pm »
Hi guys,
I managed to obtain a copy of the needed file, but I'm having trouble running it.  I wrote more about what I'm experiencing with it here (with screenshots):
http://forum.arcadecontrols.com/index.php/topic,93556.msg1303558.html#msg1303558
Any ideas on how to solve it?
D
