Author Topic: Control Panel and latches/magnets  (Read 2880 times)
frotter
  • Last login:January 04, 2012, 11:28:29 pm
« on: August 08, 2011, 09:52:07 pm »
Hi,
I am nearing the end of my first ever build of an arcade cabinet (cocktail) and am hoping someone might be able to help me with one last problem.
I have made my CP's on a hinge so that I can access the internals at anytime if I need to (you can see from the photo). I hadn't really given much thought to what method I will use to keep them closed while playing until now and it is starting to be a bit of an issue. I have thought of using a latch of some kind, but figuring where to place it is another problem. I also thought of using magnetic catches and placing them on the inside edges, but will the magnets have an effect on the workings of the CP?
This is a picture of the cabinet with the CP's closed.
This shows the Player 1 CP open (all control panels open the same).
 Has anyone got some good ideas on the best way to be able to keep it shut. I still want access to open them without having to undo screws, etc.
Thanks again for everyone's help.
HanoiBoi
Re: Control Panel and latches/magnets
« Reply #1 on: August 08, 2011, 10:50:01 pm »
Besides magnets, you could consider velcro.  The hard interlocking 3M stuff that they use for EZ Pass and such.
DashRendar
« Reply #2 on: August 09, 2011, 09:51:43 am »
+1
This is what I used to anchor my CP in place.  Home Depot sells an industrial velcro which won't detach from the adhesive.  Super easy to put in there.
RandyT
  • Last login:June 20, 2025, 02:19:52 pm
    • GroovyGameGear.com
« Reply #3 on: August 09, 2011, 11:53:42 am »
I didn't see what type of monitor you plan to use.  If using a CRT, you will likely not want to use magnets.  They will screw up the screen if they are too close.  If using an LCD panel, magnets are fine.
