Author Topic: Games with ISSUES: report here!  (Read 133957 times)
schmerzkaufen
  • Last login:October 03, 2023, 02:27:31 pm
Re: Games with ISSUES: report here!
« Reply #240 on: November 01, 2018, 06:51:02 am »
Seems they are taking rewards lately for "issues" submitted through Bounty Source:
https://www.bountysource.com/teams/mamedev
So if they need the motivation (and they obviously do -- the aforementioned Garou glitch, for instance, makes of MAME the only NG emulator which doesn't run this game properly after all these years), there's that now. Hopefully this gets at least as popular as Retro Arch's Patreon and we can see some progress on drivers which seem to be long forgotten because they're "good enough" (and the devs start getting some well-deserved money in return).
If money is what it takes to motivate them to work on games that actually matter to droves of players, instead of obscure whatever electronics most would only consider for the garbage dump, then I have no problem with that.
Off the top of my head, capcom and cave timings/waitstates, some much-needed improvements to the UI+options and related issues for useability, that sort of stuff.
edit: rewrite popular drivers to be line-accurate and therefore eligible for Calamity to implement frame_slice. :p
But I have to contribute to GM as a priority, after I'd done recovering from the end-o-year taxes that is.
« Last Edit: November 01, 2018, 07:24:43 am by schmerzkaufen »
Paradroid
  • Last login:May 12, 2024, 07:24:24 pm
    • SCART Hunter
« Reply #241 on: November 01, 2018, 05:34:08 pm »
Yes! Definitely! SF2 Hyper Fighting is such a classic but feels real wonky in MAME.
Do they need access to PCBs or just someone to implement what they already know? I have 5+ working SF2HF PCBs that came as part of a bulk PCB purchase.
Sorry, not up-to-speed on where it's all at...
schmerzkaufen
« Reply #242 on: November 01, 2018, 10:00:35 pm »
Just guessing but I think it's more like they don't know how to do it, or don't have the right person with the know-how to simulate in-game timings accurately, and they'll serve the ususal narrative that as long as the dump and driver code are right their job is done, even if the game doesn't play rigth.
By ourselves we can somehow tweak the game's behaviour using cpu underclocking, blitter delay, and adjust the framerate (well with Groovy tthe latter is not our concern), but they've specifically made it so some of these tweaks don't save and are a pain to set again every time, the excuse being that it's hack~ish and not true emulation, plus hacks = bad bug reports.
Ultimately a build with modified drivers could make the tweaks default, but they'd have to be featured in a specific one the likes of ARCADE for instance. Such  project would require the cooperation of a number of people who own the pcb's to help compare, or an already good amount of trustable documentation (including enough good quality gameplay videos) and of course some with the ability to mod MAME where it applies.
Then unless it follows official MAME's evolution for the concerned drivers, and re-adjust the values every time there's a change, that hacked build might remain a one-time only thing.
And still this would be only hacks, which means somehow, more or less close to the real thing but not exactly the same, not like completely R&Ding and rewriting the drivers adding the missing stuff. It's not completely worthless though, some games like a number of the later Cave ones are only playble this way.
I wasn't serious regarding the bounties, chances mamedevs would consider taking paid jobs like that are probably extremely low, for the PITA development reasons, but also because in the event that would actually happen, they'd expect way more money than we're ready to pay.
Some things will just never be, or like it's sometimes the case with MAME; maybe they will but many years or decades in the future.
Alternative scenario: people writing arcade emulators that go the extra mile beyond MAME and focus on achieving playability accuracy for a select number of the most popular systems. Welp.
« Last Edit: November 01, 2018, 10:02:10 pm by schmerzkaufen »
  • Last login:May 02, 2024, 04:59:06 am
« Reply #243 on: November 02, 2018, 04:28:25 am »
I believe I read that implementing wait states involves a non-trivial overhaul of MAME's architecture. It's not a matter of improving a couple of drivers. Based on that I guess that fixing those games without hacks means emulating the hardware at a much lower level, which also translates into more cpu intensive emulation. We can bet it'll be done at some point.
schmerzkaufen
« Reply #244 on: November 02, 2018, 05:41:30 am »
I suspected it was something heavy in any case yeah. An important overhaul probably won't happen just for better timings emulation anyway.
Personally I'm ok with hacks as temporary imperfect solutions, because better that than no change for 10, 20 years and beyond, you know I'm not exaggerating the lenghts. MAME never take that as a vital factor but alternative builds and heretic frontends featuring hacks and mods exist because people's lives aren't stretchable so that they'll have this much patience.
Ok just pushing sliders and turning knobs doesn't work with every game that has timing issues, of course.
For those games that can use adjustments with benefits though, just reanabling settings that fell under the cheats category to save would do, in fact it would be better than editing the drivers since we could readjust the values manually when for instance a change in a driver version that impacts perfomance occurs.
I've seen that savestates can be a workaround but it's kind of messy (the state 'remembers' your cheats settings, but only after you go and tickle them by a value of 1 and back)
In any case as long as it's away from the official MAME, and people provide logs where the active cheats settings appear, there shouldn't be any problems with reporting in this thread (right? or...)
In fact I wonder why this hasn't been a thing in ARCADE ? something like that could then land in GM by haynor's vector.
Recapnation
  • Last login:December 01, 2023, 07:39:55 pm
    • Eiusdemmodi
« Reply #245 on: November 02, 2018, 02:26:47 pm »
I recall someone looking into CP-S speed issues recently, though? Don't know how it ended or if it did.
You should check Retro Arch's Patreon to get an idea on the numbers. But it's just a matter of they asking for once. There's interest. Garou (be it wait states or whatever the cause), Hyper Fighting, Progear no Arashi, CV-1000... Too many significant (and popular) games now not to get many people aboard, even if it' just for historical reasons. But they need to explain it properly. A hidden webpage in a site called "MAME Testers" where the subjects aren't properly addressed, reports are kept open when they shouldn't, the search system is nuts for non-testers, language gets too technical to explain elementary bits related to performance... isn't obviously the best place to make this stuff visible.
CP-S issue, for instance:
https://mametesters.org/view.php?id=408
Not to mention the uncountable places where these subjects are discussed by the people involved -- impossible to keep track.
The discussion belongs elsewhere (places where it sadly wouldn't be that welcome, on the other hand, I'm afraid), but there's an even bigger argument laying down there within Schmerzkaufen's diatribe -- by offering an imperfect-though-palatable emulation for so many years despite having the tools to get a much better approximation (call them "hacks" if you will) the people are endorsing it as if it were the original behaviour, so it goes against the "telling the history as it was" argument MAME Dev claim once and again. Especially when most of the timesthe issues aren't documented when you run the emulation or even in the emulator's texts. The "flag" system of course doesn't suffice, but there's isn't one for the CP-S issue, for one. So it's fair enough that they advice against using hacks and offer a "pure" version of MAME so that proper emulation gets done some day (despite they admitting it won't happen for reasons) but persisting on feeding this unnatural dichotomy between devs and users isn't helping the project. MAME may well be the very first cause of the Retro Arch phenomenon.
schmerzkaufen
« Reply #246 on: November 02, 2018, 03:19:34 pm »
Personally I'm fighting that dichotomy but I doubt anyone's getting my positioning. Specifically I disagree with the careless hacking camp on the one side and the too-final radical no-no-no mamedev's on the other.
In short I'm in favor of seeking compromises, like more warning messages, indeed flags wehre possible, but I'm thinking more of a an in-game OSD feature that displays how the gam's running and what's active along with it during gameplay.
Like we press F11 but we only have that poor refresh speed % meter, my idea is that it could show more information, like if lag reduction is used, cpu or refresh sliders, other 'cheats' like autofire or savestates, etc.
Imagine you press F11 and this appears, just to illustrate;
[SPEED100%, FD 8, CPU 74%, AF]
translated: game running at its normal refresh speed, frame_delay on set to 8, CPU underclocked @74%, AutoFire ON
Of course ideally the band would be moveable around the gameplay screen area maybe with smaller fonts too, in order to not get in the way.
This would also be a new and ideal way to confirm the validity of some videos, if for instance a wolf~ish variant of it would make that on-screen ingame info always-on
A build like that, unless it's stolen by RA again, would be a sort of permissive and restrictive one at the same time, useful for tweaking and cheating via hack~ish solutions, but also able to show that you're not using any - or specifically which one - during your run recording.
I'm convinced that permitting anything tweak/cheat/hack without care nor warning is damaging of course, goes without saying, but forbidding all this stuff absolutely and not pay attention to the fact that it makes people lose patience and interest then opt for the worse solutions is a huge mistake too, no doubt about it we're seeing the results today.
A tentative name for an hypotetical build: compromame? diplomame? middlemame? ;D
EDIT another illustration for fun, with another more complete info band;
[diplowolfmame 0.203 : SPD 101%, FD 7, CPU 60%, AF B1:3Hz, REC 1]
« Last Edit: November 02, 2018, 03:26:47 pm by schmerzkaufen »
« Reply #247 on: November 02, 2018, 03:35:31 pm »
If MAME had better emulation of 16-bit consoles already, RA wouldn't be so relevant. I buy that part of the argument.
schmerzkaufen
« Reply #248 on: November 02, 2018, 04:27:11 pm »
AND lag reduction, AND more complete saveable settings including those of the all-important shaders. People don't go to RA only because it's a mashup of many systems, but also a lot because it's got these features the official MAME don't, or only partially, or with longstanding issues.
I'm only interested in arcades and dislike several aspects of RA so for me the natural choice is GM, which you make reach significant milestones the one after the other in the right direction.
I would never consider the official MAME for playing, for me now it's almost like it's MAME that's just a necessary component of GM, and the latter is the real deal.
See what I'm getting at ?
Of course I know we owe a pharaonic amount of progress to mamedev's work since I'm following there too, but after I've had a taste of smooth scrollings, correct speeds, and low lag, it's impossible to play without those.
It's the same for many RA users, they've just made the wrong "emulator" choice where arcades are concerned, or they associate MAME to that unwelcoming rigid, spartan thing it tries so hard to be for sometimes good, but also sometimes really poor or not really honest reasons.
Also these users may have not heard of GM or they associate it to baseline MAME which they have already walked away from, which probably doesn't help.
Darn I'm at it again, I'm like Haze now, spamming the same story all over the nets. Anyway yes right, anything that improves the official MAME in the future in these particular areas, as well as consoles emuation of course, will make RA technically less relevant. Yet I can't help but think it's too late (crap I've already said that too, three or four times)
cools
  • Last login:March 11, 2024, 02:59:06 pm
  • Arcade Otaku Sysadmin
    • Arcade Otaku
« Reply #249 on: November 02, 2018, 04:47:44 pm »
Anything like this can be patched out and simply not displayed, if one really wanted to cheat in recordings.
If someone were to put up a bounty for fixing CV1000 properly, I would personally stump up decent cash and I'm fairly sure there would be others that would do the same.
schmerzkaufen
« Reply #250 on: November 02, 2018, 05:03:35 pm »
The idea is that it would become a tool required to show for shared run videos or streams to be valid.
Anyway anything can be patched, edited and faked, but if we go by that philosophy and make paranoia the default then we might as well question everything and see fake news/plots everywhere, then stop sharing at all.
There's always been scoreboards where people just post in whatever fashion required, but they've also always been more or less vulnerable to lies and forgery...
It's better to offer the actual possibility to do it a bit more right, offering reasonable solutions, than do everything to limit, fordib and stop.
Yup, I would. Though I might have to sell a pcb for that since I'm broke.  :lol
cools
    • Arcade Otaku
« Reply #251 on: November 02, 2018, 05:34:42 pm »
If MAMEDEV wanted to mainline the WolfMAME patches and have it as a switchable option (with your aforementioned indicators), i'd not be against it. But I don't think it should be defaulted on for everyone. Waste of CPU cycles.
[/quote]
schmerzkaufen
« Reply #252 on: November 02, 2018, 05:50:43 pm »
Yes something like a switchable 'wolf mode' is another good idea, the flexibility of choice is key IMO, so that means outside of it anything else should be useable, and in any case anything running and influencing the emulation should be displayable in a corner.
I doubt the official MAME would accept the latter in any circumstances considering their overkill inflexibility, but it doesn't have to be the offcial MAME either anyway.
« Last Edit: November 02, 2018, 05:52:17 pm by schmerzkaufen »
Recapnation
    • Eiusdemmodi
« Reply #253 on: November 03, 2018, 10:30:18 am »
And the logic behind that would be...?
There's much more to Retro Arch than better emulation of the 16-bit consoles, of course -- FC/NES, PS, PCFX, even SS and N64 have all decent-enough emulation for many people under RA whereas they don't under MAME. The average user is finding less and less reasons to keep using discrete emulators especially when RA's engine and tweaks allows for better perceived emulation and it offers more options and usability as well. Were it not for Groovy MAME we all would be using Final Burn Alpha and MAME through RA (were it not for GM, RA would be today as bad as MAME for our purpose, we all know that, but that's another matter altogether).
schmerzkaufen
« Reply #254 on: November 03, 2018, 11:49:18 am »
Just that personally I'm only discussing the arcades-MAME emulation side of things here, the multi-emulators topic when invoking RA is not my focus now. Further than that I was always against the MAME-MESS merge anyway.
Indeed if it wasn't for GM I'd probably look elsewhere, but there's also the ARCADE variant that haynor666 makes from time to time and I really appreciate (esp because to this day I still can't manage to organize and browse my games how I want in the vanilla mame ui/mewui and that's as irritating as ever. ARCADE is a breath of fresh air in that aspect)
But yes for the people who are interested in the entire topic that includes consoles and more, your opinion is certainly right.
Heian_Shodan
« Reply #255 on: November 28, 2018, 04:49:55 am »
Does anyone have any idea if there's a workaround to the Apocalypse/Onslaught Sprite problem on Xmen vs SF, Marvel vs SF, and Marvel vs Capcom? It started on Mame 145 and never got fixed. I dont know what they did to the Cps2 code that caused the issue. It was perfect before that version.
Here's a gif:
https://mametesters.org/file_download.php?file_id=3524&type=bug
Torkyo
  • Last login:November 29, 2023, 07:12:04 pm
« Reply #256 on: December 14, 2018, 05:33:21 am »
Hello,
I read the procedure to report a game issue but sadly I’m not in front of my cab, just texting on mobile.
Hope to not be ignored though...
The game I’m experimenting issue is moon cresta.
The problem is that strangely intended to be as a 768x224 @60.606061 while as far as I know the resolution should be 384x288 @60.606061
I got a monitor wit horizontal orientation and I rotate the vertical games without any problem keeping their right resolution and timing (I got a polo star 28” modeline 1) but with 768 lines of course my monitor goes to interlace giving the timing problem as the game runs at 25hz probably due to the windows interlacing bug.
Is there any way to let GM to handle moon cresta as the right resolution should be so 384x288?
As far as I concern. The problem should be present in Galaxian too as they share the same resolutions and refresh.
Torkyo
« Reply #257 on: December 15, 2018, 08:34:02 pm »
hello,
to fix the interlace problem I disabled interlace in mame.ini
anyway the problem remain as the switcher works handling a wrong resolution of 768 lines (rotated) instead of 384.
I'm wondering if is there a way to force the correct 384x288 resolution.
attachment follow with required details.
           - mooncrst
           - ATI RADEON HD 4350
           - Hantarex polo star 28" tri-sync
           - CRT Emudriver 2.0 (12.6) Windows 7 64bit
thanks
« Reply #258 on: December 22, 2018, 07:20:48 am »
Hi Torkyo,
384x288 is not the correct resolution at all.
That game has indeed a resolution of 768x224. But because it's a vertical game, and you want to play it on a horizontal monitor, 768 becomes the height in lines, and that's not achievable for a 15 kHz monitor.
Older GM versions had a patch for those specific games that divided the 768 resolution value by 3, to 256, so they could be played on a horizontal monitor, using a resolution of e.g. 400x256 pixels. This hack was removed because it degraded the backgrounds' resolution for users that intended to play them on their original, legit orientation.
So since you're using super resolutions, the workaround could be forcing them to run on 2560x256 (create a fine named mooncrst.ini and put "resolution 2560x256" in it). However GM is not designed to downscale cleanly and you'll probably notice ugly artifacts when doing that.
Torkyo
« Reply #259 on: December 22, 2018, 10:25:21 am »
Thank you very much for your kind reply,  Calamity.
my information about mooncresta resolution was wrong then!
luckily I got a monitor that accepts 15 25 and 31 kHz and the switcher changes resolution to 2560 x 496P 60.606Hz   31.515 kHz
the problem is that I notice a little glitch in the vertical scrolling, I think it is because of downscaling from 768 to 496.
Probably with such hi resolution (768 lines) it is the best possible way to display it in vertical over an horizontal monitor. I hoped to have the perfection like in all other vertical games I tested so far but probably such 768 resolution is too far.
If you have any other idea to improve the mooncresta picture I'll be glad to listen about that!
thanks again.
folken
  • Last login:February 24, 2019, 08:28:37 am
« Reply #260 on: January 18, 2019, 01:53:27 am »
Hello! ^_^
I don't speak english very well so I hope you'll understand everything I say... :-P
Here is my gear:
Groovymame 0.158 with MaLa
ATI X300
CRT_Emudriver 1.4b
Windows XP Pro 64
Sony crt (3431D)
I have 2 problems:
1-Yesterday I played Irem schmup "GALLOP" and I noticed bottom of the screen is cut off (I don't see life bar, score etc...) So I thought I need to change Vfront porch. Basically it's 0.064 so I changed to 0.128 (same result)
At 0.256 (same result)
At 0.512 (I see the life bar and the score but scanlines disapeared...)
After many many tries I found the limit: 0.549. At 0.549 I have scalines but I don't see the bottom of the screen and at 0.550 I see it but I don't have scanlines.
2-NEOGEO and CPS games, and maybe others, don't run with the good resolution (320X224 and 384X224). Switchres runs them at 640X224 and 768X224...
What must I do?
Thank you in advance
« Last Edit: January 18, 2019, 01:46:13 pm by folken »
haynor666
  • Last login:Yesterday at 05:01:23 am
  • retro maniac
« Reply #261 on: January 19, 2019, 02:09:35 pm »
Small grave digging - loosing upper and lower part of picture is Sony Trinitrons fault - look again here -> http://forum.arcadecontrols.com/index.php/topic,148828.msg1638016.html#msg1638016
You have to use option v slope in Sony Trinitron service menu to move up botton of picture in 256p modes in 55 Hz. You will have smaller gap in scanlines but that's natural process in shrinking picture.
Each TV I had had two defined service modes parameters one for PAL (50 Hz and close) and NTSC (60 Hz and close). 55 Hz mode is naturally not PAL and not NTSC so when You are changing some parameters TV might just from PAL mode to NTSC and vice versa. I've found to use NTSC mode because it's works better for me - I'm using only v slope to move bottom of picture higher. 55 Hz (and close) modes are used mostly by Midway, Irem, Toaplan hardware, hardly by other manufacturers. Below 55 Hz are some Seibu and Jaleco games. Games close to 50 Hz are rare.
« Last Edit: January 19, 2019, 02:45:40 pm by haynor666 »
schmerzkaufen
« Reply #262 on: January 19, 2019, 03:11:19 pm »
Every time I see the FD Trinintron geometry menu I have a PTSD episode. :scared
Paradroid
    • SCART Hunter
« Reply #263 on: January 19, 2019, 11:15:02 pm »
Haha! You're missing all the fun with your sanitary and predictable LCDs. ;)
Sent from my SM-G955F using Tapatalk
schmerzkaufen
« Reply #264 on: January 20, 2019, 04:28:21 am »
Nah I seriously got fed up with it, fantastic looking 27" but only under the condition geometry's perfect, which can be extremely hard to achieve (the smaller FD trinitrons are ok tho)
Years of battling geometry was one of my main motivations for considering flat panels alternatives. You know it varies greatly of course but some CRTs while often considered the 'best' can also be a MASSIVE PITA, I got cheapo/simplistic low-cost curved sets giving me considerably less trouble and more statisfaction than the usual 'stars' of the CRT world, I don't care if the picture ain't as sharp and all.
But that's off-topic.  :P
NinjaZero
  • Last login:April 23, 2024, 04:19:35 pm
    • RetroGameInStyle
« Reply #265 on: February 01, 2019, 02:20:41 am »
Sega Outrunners runs at about 50% speed on build v.206.  Test against Mame v.206 mainline and have no issues.  I removed Frame delay but that had no effect.  Also tested v.204 and same issue, not sure how long this has been a problem.
Average speed: 59.74% (10 seconds)
Sound: overflows=1 underflows=408
System Info:
Windows 7SP1
Nvidia 1050Ti
LCD Monitor
Groovymame LCD HLSL Settings
Check out the link on my profile (to the left)
anchounio
  • Last login:April 30, 2024, 09:25:47 am
« Reply #266 on: November 12, 2019, 07:54:06 am »
In BREAKOUT the screen goes black when the left side of the screen is hit by the ball or the ship
sickness
  • Last login:September 10, 2021, 09:33:09 am
  • contrarian mind ;)
    • sickness
diehard white screen in game problem
« Reply #267 on: September 06, 2020, 01:00:36 pm »
I've discovered that in groovyarcade 2020.04.08 (groovymame 0.220) and groovyarcade 2020.06 (groovymame 0.221) diehard starts ok with the presentation, but then after inserting coins and pushing p1 start, the screen turns white (and also the mame tab menu is mangled and unreadable).
If I put "changeres 0" in mame.ini instead it works fine (but of course at desktop resolution).
I've tried with many different videocards ati hd3450, ati x1650pro, nvidia 7300gs, nvidia 6100, with vga crt monitor, with 15khz tv, and with lcd monitor, it always makes the same white screen when in game.
Last test just to try to change everything I did on integrated radeon hd6250 on lcd screen, I attach diehard.txt log of this one (it expresses same behaviour anyway).
« Reply #268 on: September 07, 2020, 12:51:11 pm »
@sickness,
Dynamic mode change may fail on the Linux build. Force a super resolution on that game (create a specific empty ini and add resolution 2560x240).
sickness
    • sickness
« Reply #269 on: September 07, 2020, 05:28:10 pm »
@sickness,
Tnx for the hint!
(yesterday I've even updated to the last groovymame, but it was making still the same thing)
With this ini file mod there seems to be a little improvement because I see less "crazy switching" of graphic modes in the game, but still after the presentation starts fine (oddily with the same res as the game!) after I add coins and press p1 start the game becomes white and if I press TAB to see mame menu that's also mangled.
This time I took logfile diehard.txt and took two pictures with my phone to better show the problem they are called diehard1.jpg and diehard2.jpg I try to attach them here.
This time hardware is opteron cpu + hd3450 + groovyarcade updated with pacman from this server:
Server = https://github.com/substring/packages/releases/download/stable
Substring
  • Last login:Today at 02:18:54 am
  • Forking GroovyArcade
    • GroovyArcade active fork
« Reply #270 on: September 07, 2020, 05:46:29 pm »
That repo used doozer build , so it's like downloading from calamity's repo ;)
sickness
    • sickness
« Reply #271 on: September 07, 2020, 06:13:59 pm »
ah, didn't know this =_)
I just wanted to upgrade groovymame from 0.220 to 0.223 to check if it was behaving the same with that diehard game :)
sickness
    • sickness
« Reply #272 on: September 15, 2020, 03:40:40 am »
@sickness,
so now I've tried a diehard.ini file with only these two lines:
resolution 704x224
switchres 0
and it works!!! :)))
tnx for the hint!!!
« Reply #273 on: September 15, 2020, 03:45:38 am »
@sickness,
resolution 704x224
switchres 0
tnx for the hint!!!
switchres 0 disables switchres so no, that doesn't work, it just seems to work.
sickness
    • sickness
« Reply #274 on: September 16, 2020, 02:55:53 am »
Well ok, but my point is that before I had a totally white screen and was unable to play (maybe because this particular game is a bit crazy switching modes between 352x224 and 704x224 like there's no tomorrow...).
Now with this .ini the game visualizes and plays fine (I've tried also to force 352 but then the game had wrong proportions, 704 made it better).
The very strange thing is why it doesn't do this for all the ST-V games in mame, for example Soukyugurentai/TerraDiver works fine, go figure =_)
Now I've even bought a real ST-V with the cartridge of diehardarcde to better understand what this "thing" is doing in real life, I've connected it to a normal scart tv with a supergun, but I don't see it switching modes at least not noticeably by naked eye, it seems always low res :|
Recapnation
    • Eiusdemmodi
« Reply #275 on: September 16, 2020, 09:26:35 am »
Die Hard Arcade's main video mode is indeed of 704 x 240 but likely it switches to something else at some point, maybe even interlaced. Soukyuu Gurentai uses a fixed 352 x 224 in its arcade version, if I recall. You can't expect all the ST-V games behaving in the same way regarding this, at all.
« Last Edit: September 16, 2020, 09:32:21 am by Recapnation »
Swainy
  • Last login:December 09, 2023, 12:05:24 pm
« Reply #276 on: October 10, 2020, 01:08:18 pm »
Guys, Im having sound stuttering issues with Astro Blaster. Any ideas?
Max_FS
  • Last login:November 09, 2023, 03:45:06 pm
« Reply #277 on: February 20, 2021, 04:25:12 pm »
Dear all,
I encounter problems with psychic5 when switchres is activated. While deactivated or when using normal MAME all runs fine but with switchres activated the whole screen is vetically scrolling. I attached a gif-file to illustrate it. When bezels are activated, also the bezel is moving and same applies for menus in GM. All happens on my first screen (CRT) but would also happen on my second screen (LCD) when I swap both screens. I had this issue already some versions of mame before so it is not caused by the newest version of switchres. I attached two log files, one with switchres acitivated and one with switchres deactivated.
One interesting detail: Before coins are inserted and while being in the games attract mode, it is normal that the game screen is vertically scrolling. But of course, bezels and mame menues should never scroll and the game screen should stop when the game is started.
« Last Edit: February 21, 2021, 01:49:37 am by Max_FS »
« Reply #278 on: February 21, 2021, 10:32:49 am »
You probably need to adjust v-freq (or v-hold) potentiometer on the chassis (provided it's an arcade monitor).
Max_FS
« Reply #279 on: February 21, 2021, 12:17:04 pm »
Hi Calamity,
maybe you are right. It is not an arcade monitor but it is a consumer TV probably having such potentiometers on it's chassis (Sony Trinitron).
I did some more testing. I have to screens, one main screen and one marquee screen. Everything displayed on the LCD won't scroll and everything on the CRT will scroll when switchres is activated. So also the Marquee-Artwork would scroll on the CRT. So this may be some good indication that it has to do with the potentiometers on the chassis and is not software related.
But i still don't understand the whole thing. Why does it start scrolling in only one single game when switchres is activated? Switchres chooses resolution 2560x256p for psychic5. Would that resolution in connection with incorrect v-freq or v-hold cause it to scroll? This can't be, as I have other games with that resolution that are not scrolling. Next thing I recognized it that psychic5 would run at 54.002Hz/15.660kHz. The other games i tested have different values for that. All of them have higher Hz- and kHz-values. When including games with different resolutions all others still at least have higher kHz-Values than psychic5. May there be the relevant difference? Would switchres choose those Hz/khz-values for psychic5 while my CRT can't deal with them unless I would adjust v-freq or v-hold on the chassis? Unfortunately, testing that won't be so easy as those potentiometers are really hard to reach for me... Is it possible to manually set Hz/KHz-Values? If not, maybe i should just deactivate switchres for that game.
