Author Topic: Best way to dispense/ store tokens?  (Read 5928 times)
Donkbaca
    • Slim built MAME/Xbox cab
« on: July 08, 2011, 02:13:03 pm »
So, I have my coin door lit up, and modified it to take .984 tokens and got a bunch of tokens.  The question to those of you that use tokens in your arcade, how do you store your tokens?  Right now I have them in a box, I would like to get some sort of mechanical dispenser, anyone know where i can get one?
DCsegaDH
Re: Best way to dispense/ store tokens?
« Reply #1 on: July 08, 2011, 02:18:21 pm »
I don't do this, but I seen others use an ashtray to hold the coins.
« Reply #2 on: July 08, 2011, 02:24:55 pm »
If you really want an "authentic" arcade experience you could get a change machine like this one.
I've seen them go for around $150 on CL and ebay around the Denver area.
Or you could modify a coin sorter to have a hopper full of tokens and dispense them when a button is pushed or a lever is pulled. I have one from the early 90s that I think would work better than this, but here's an example.
Or get a belt coin dispenser (that one's not for tokens, but I know they're around) like the arcade ops used to where...
« Last Edit: July 08, 2011, 02:36:34 pm by Nephasth »
ark_ader
  • I glow in the dark.
« Reply #3 on: July 08, 2011, 03:02:20 pm »
Back pockets work well and you could win something nice at the post office or the liquor store.
Donkbaca
« Reply #4 on: July 08, 2011, 03:07:39 pm »
Don't want authentic at all.  Want something maybe vintage, like an old coin changer or something.  Want something mechanical versus electronic.   Might just make on myself?
ark_ader
« Reply #5 on: July 08, 2011, 03:24:39 pm »
Get a candy grabber.
How much do your tokens weigh?
Donkbaca
« Reply #6 on: July 08, 2011, 03:32:10 pm »
don't want something bigger than my cab to dispense tokens for my cab
TheShanMan
    • My Arcade (updated 1/30/13)
« Reply #7 on: July 08, 2011, 03:35:01 pm »
Here's what I have for my tokens ;D: Unfortunately they don't seem to appear every day.
DCsegaDH
« Reply #8 on: July 08, 2011, 03:37:02 pm »
Yeah, I don't think most people have the room to spare to have something just to hold coins, I would rather have another cabinet instead.
eds1275
  • Rock and Roll!
« Reply #9 on: July 08, 2011, 03:52:53 pm »
Here's the video. Although there's no nudity, it's probably not safe for work.
http://www.blingcheese.com/video-63/boob+show.htm
« Reply #10 on: July 08, 2011, 05:13:39 pm »
If you want to get creative, fill "prize eggs" with tokens then put them in a toy capsule machine  ;D
BobA
  • What Me Worry?
« Reply #11 on: July 08, 2011, 05:26:30 pm »
Donkbaca
« Reply #12 on: July 08, 2011, 05:41:19 pm »
Thanks for the suggestions, but not what I am looking for.  My cab is wood and its in my office, so I want something more grown up looking...
spoot
  • Destroyer of electronics
« Reply #13 on: July 08, 2011, 05:51:26 pm »
Small wooden "gumball" type machine to dispense them one at a time via a handle?   Hmmm, have to think about the mechanics on that one first.....   8)
« Last Edit: July 08, 2011, 05:56:25 pm by spoot »
HanoiBoi
« Reply #14 on: July 08, 2011, 06:03:41 pm »
How about mounting a belt/hip coin changer to the side of your cab?
http://shop.mobileweb.ebay.com/searchresults?cmd=SKW&kw=coin+changer
Hoopz
  • Last login:January 04, 2026, 08:51:00 am
  • Intellivision Rocks!
« Reply #15 on: July 08, 2011, 06:08:57 pm »
Have X come do it for you.  He was the change boy in an arcade for awhile.  Just make sure to help him count out the tokens.    :P
Donkbaca
« Reply #16 on: July 08, 2011, 06:34:04 pm »
I thought about the hip change thing, but I only need quarter size...
Thinking about making one.  You can get quarter sized forstner bits,  thinking about making a base with a drawer 4 tokens thick, then mounting a copper or brass pipe with the internal diameter about the size of the tokens to the top of it....
« Reply #17 on: July 08, 2011, 06:58:34 pm »
The copper pipe and tray idea was what I was going to suggest. Put a lid on the tray that covers the back half so when you pull it forward, the tokens are blocked from falling, and you'll always get a set number (maybe, I could still see things jamming).
I wonder if an antique gumball machine could work, you may have to drill out or otherwise enlarge the ball opening on the inside, and you'll likely get more than 4 tokens at a time, but there may be a way to avoid that even...
« Reply #18 on: July 08, 2011, 09:09:46 pm »
Maybe this sort of dispenser would work. You could fit it with your own sign, or use no sign at all.
dfmaverick
« Reply #19 on: July 09, 2011, 07:00:26 am »
Some of the Kwik Koin old fashion coin dispensers show up on ebay from time to time for cheap. As you can see from the photo, they come in a couple denominations. The quarter one may work if you can find one...or build something similar. I believe they dispense a set number per pull so the thickness of the token may screw it up.
« Reply #20 on: July 11, 2011, 10:08:43 am »
One up on ebay.
