Author Topic: [Tutorial] Create automatically Gamelist *.MLG to for MALA (by gender)  (Read 2498 times)
milor
  • Last login:June 28, 2011, 11:40:37 am
I do not speak English, excuse!
1: Have MaLa configured and running the All games.mlg must exist and should be configured the catver.ini and. NET Framework 3.5
2: Download: MameGameListAutoforMaLa 1.3
3: Unzip into the folder where you have poor or one that you remember.
4: Run: MameGameListAutoforMaLa.exe
5a: If you have the. Ini:
If you already have the. INI press the Open. Ini seek All games.ini and open it.
5b: If you do not have the. Ini:
Click Open. Mlg seek All games.mlg and open it.
Click Create. Ini if we activate the Show will see the console working, wait until the end will close the console or put you on the status bar Added INI, this takes a lot and the program may just stay stuck patience.
6: Press Auto mlg waiting out in the Created state will INIS.
In the directory where you had or you have the INI is created a new directory called AutoMLG the *. ini and *. mlg, the *. mlg are what you will carry in Mala
You just have to put that interest you *. MLG in the root directory bad. Now I have to look at me the MaLaTree. Well whatever, I'll answer here!
Adults * Added Mode and you select the most convincing. No one tried it?
P.D.1º open crash, reopen!
« Last Edit: June 28, 2011, 11:02:28 am by milor »
