Author Topic: Arkanoid spinner help  (Read 3083 times)
telengard
  • Last login:October 21, 2025, 02:12:46 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
« on: June 14, 2011, 10:38:16 pm »
I'm trying to get an arkanoid spinner working, using it with an Opti-PAC.  Originally posted this in restorations but it is probably more appropriate in here.    :angel:
As received from eBay it did not work.  Found this site:
http://www.zumbrovalley.net/readpost.php?artid=1
and following the advise there I ordered some replacement optical encoders which were mentioned were most likely drop in replacements:
http://www.optekinc.com/datasheets/OPB859.pdf
I've pinned out everything to make sure I have it right and I'm pretty sure that part is OK.  What I'm seeing is the output at the receivers (pins 1 and 4) is always @ 5V.  When moving the wheel I never see it dip to 0v.
Any tips on things to check or ideas?  As I mentioned I've pinned everything out following the schematics at the above page and also verified (out of circuit) that the 2 resistors are 150ohm (in circuit the resistance goes way up which surprised me, I would have thought they'd stay fixed and current/voltage drop would change).  I also only have the 2 150 ohm resistors on my board and from what I've read, the other 2 aren't needed.
~telengard
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
D_Harris
  • Last login:September 25, 2024, 10:06:48 pm
Re: Arkanoid spinner help
« Reply #1 on: June 19, 2011, 04:17:46 pm »
From what I know the original Arkanoid spinner should have worked without having to use new encoders.
Did you re-flow all the solder joints first? (I think cold solder joints are a common problem).
Darren Harris
Staten Island, New York.
My collection:Asteroids, Joust, Millipede, Ms. Pac-man, Pole Position, Robotron 2084, Star Trek, Star Wars, and 100+ PCBs. Trading/Selling:Arkanoid: R.O.D. Cocktail, Tornado spinner, Hewlett Packard 16500A Logic Analysis System with Accessories. Wanted:Mach 3 joystick. Millipede Trackball. 100° or WG4600 monitor Tube.
telengard
    • S T U R C A D E
« Reply #2 on: June 19, 2011, 04:21:08 pm »
Darren Harris
Hi there,
Thanks for the suggestion!  I only replaced the encoders because the spinner wasn't working.  Figured the encoders were not working.  Seems that is not the case.    :banghead:
I'll try re-flowing the solder joints tonight.
~telengard
D_Harris
« Reply #3 on: September 01, 2011, 03:26:09 pm »
Darren Harris
Hi there,
~telengard
Well, did that correct your problem?
Darren Harris
« Reply #4 on: September 05, 2011, 07:43:59 am »
~telengard
According to the pdf you linked to, You should see a steady 5 volts between pins 1 and 4 of the sensor.
(Between pins 1 and 2 you should see around 2 volts.)
Connect your meter to pins 1 and 3, then turn the spinner very slow. If you are using a digital volt meter and turn the spinner fast, the DVM may not see the fast pulse and register a steady on, due to DVM update times.
At least this is how it looks to me.
