Author Topic: Flipping orientation of a vertical layout - how?  (Read 2055 times)
TopJimmyCooks
« on: June 13, 2011, 09:51:26 pm »
in prototyping my auto rotating monitor, I was rotating to the right.  for a better viewing angle while vertical I have decided to rotate to the left.  I have mame rotating fine and of course the horizontal layout is fine.  However the vertical layout is upside down.  I can't find where to flip it permanently, just momentarily in the main context menu.  I must have looked at every tab in setup and everything in layout 3 times, and I'm just not seeing it.
can someone tell me where so I can say "DERP!"  Thanks.
  • Last login:August 23, 2025, 09:14:19 pm
Re: Flipping orientation of a vertical layout - how?
« Reply #1 on: June 13, 2011, 10:40:14 pm »
Check startcom config in options/plugins.
« Last Edit: June 13, 2011, 10:48:29 pm by DaOld Man »
TopJimmyCooks
« Reply #2 on: June 13, 2011, 10:59:21 pm »
Thanks! didn't think to check the plugin.  At this rate I'm going to have to name my firstborn cocktail cab after you.
« Reply #3 on: June 14, 2011, 07:25:27 am »
