Author Topic: Mala Launcher and remote connection  (Read 2280 times)
PaTrYcK
  • Last login:May 02, 2020, 05:22:19 am
« on: June 04, 2011, 10:41:51 am »
Hi TheShanMan, your Mala Launcher is great!
Time ago i use Mala.exe  in my windows shell, but i have removed it and replace explorer shell because with mala-shell not is possible use remote connection with my cab...you think is possible do it with your plugin?
empardopo
  • Last login:November 17, 2025, 01:32:25 am
    • My personal forum
Re: Mala Launcher and remote connection
« Reply #1 on: June 04, 2011, 07:22:10 pm »
Perhaps, you can put an option in MALA to access to your Windows OS!
It's only an idea! I've never checked it!
Greetings!
TheShanMan
    • My Arcade (updated 1/30/13)
« Reply #2 on: June 09, 2011, 08:13:45 pm »
Not sure exactly what you mean. I have mala as my shell and I use remote desktop to log into my cabinet. You may need to do a ctrl-alt-delete (I think with remote desktop you do ctrl-alt-end IIRC) to start explorer if you want to get a start menu for working on it. I actually use 2 separate logins though - one for arcade use and "administrator" for remotely logging in. That way I don't have to worry about getting an explorer shell going.
The launcher plugin should work regardless of what the shell is, although I'm not sure how much value it adds with explorer as the shell since you can just put stuff in your Startup folder.
PaTrYcK
« Reply #3 on: June 10, 2011, 10:24:25 am »
Thanks for your information, now i try to use remote connection with mala shell and your plugin!
