Author Topic: Trying to find 1/8" LEXAN  (Read 3549 times)
Indyplumber
  • Last login:November 19, 2012, 09:46:03 pm
« on: May 29, 2011, 10:36:14 am »
I'm having no luck finding a local store that carries 1/8" LEXAN.
Lowes, Menards and Home Depot = no luck.
All I can find is .080" and .093" in 36x48 or 36x24 sizes.
I bought a small piece of .080" LEXAN to practice drilling and cutting.  When I place it on my 5/8" control panel wood it is SOOOO close to 3/4"
but not quite enough.   ???
Any suggestions for finding 1/8" ?
JODY
  • Last login:June 08, 2025, 11:26:01 pm
  • After a long delay...the arcade is underway!
Re: Trying to find 1/8" LEXAN
« Reply #1 on: May 29, 2011, 12:14:52 pm »
The .093 would be closer to 1/8" than the .08.
nox771
  • Last login:December 14, 2011, 08:50:12 am
    • rewiredgear
« Reply #2 on: May 29, 2011, 01:03:38 pm »
If you don't mind online versus local, there are many vendors:
eStreetPlastics
Tap Plastics
Interstate Plastics
Delvies Plastics
You also get more choices there for type (polycarbonate, acrylic), colors, tints, etc.  For local supplier you might try to locate a professional sign shop and ask if there are local suppliers or if they would sell you something directly.
milkit
  • Last login:June 28, 2014, 09:14:33 pm
« Reply #3 on: May 30, 2011, 09:24:07 am »
lowes here in tx have 36 x 72 sheets of 1/8 (.125 i think it is?) for $49.99. sucks yours doesnt! estreetplastics is good, used them many times for 1/4" stuff
UncleMame
  • Last login:June 10, 2011, 08:47:29 pm
« Reply #4 on: May 30, 2011, 10:20:48 am »
The Lowes here in MO also has 1/8'' lexan, so you may want to check with customer service and see if they can get it in.  Sometimes it just means they need to contact their main warehouse/distributor to get it in, especially if other stores carry it.
Good luck.
Indyplumber
« Reply #5 on: May 30, 2011, 10:36:44 am »
JODY
« Reply #6 on: May 30, 2011, 06:30:56 pm »
That link came up well over $400 then dropped to $157 after I entered my zip code.  What a difference location makes.
mgb
  • North East, US
« Reply #7 on: May 30, 2011, 08:18:03 pm »
If Lowes in one area has it, you may very well be able to get at a Lowes local to you through special order. Or amybe you can order it on their website and have delivered to store.
Is it a problem using the .080 because the t-molding would stick out a bit, because you could trim it flush with a sharp chisel.
TNVols
  • Last login:June 16, 2011, 08:32:26 pm
« Reply #8 on: June 01, 2011, 09:44:32 pm »
what town is your local Lowe's store in?  I may have a contact there that can make a call to the vendor that sells them Lexan.
