My Good Doctor,
I was going to dribble this out a little slower, but for you . . . .
On to the expansion mechanism: My two main hobbies are woodworking and messing around with computers, so woodworking informs anything I happen to be working on in the shop.  I purchased a 4 aluminum sliding t slot pair.  The inner and outer pieces mate together and slide, with a very tight tolerance.  They are used for woodworking jigs, router tables, miter gauges, etc.  These guide the wings and hold everything together.
Case with T Tracks mocked up:
  I decided I wanted to index the two wings together, to keep the center panel, well, centered.  It also makes it easier to put a limit stop on the expansion.  I did a lot of shopping for gear racks.  I was originally looking for nylon, but its not available in A) small quantities or B) large sizes.  Once I got the steel pieces I ended up with I realized the stiffness of the steel is very helpful to my system.
I ended up ordering Boston gear parts sourced through McMaster Carr (
mcmaster.com).  A four foot long ½ wide rack and a matching ½ wide by 1 Ό diameter gear with a ½ bore.  There are a lot of considerations and options when specing out a gear and rack  tooth pitch, pressure angle, etc.  I had to give myself an education.  I couldnt get the ½ width gear I needed to match the rack I wanted, so I ordered a wider one and cut it to size. The gear racks have to be drilled for their mounting holes.  Its mild steel but having a drill press is basically a requirement for doing this stuff.  The sliding gear added about $65 to the cost of the project and probably 3 days of extra work since everythings impacted, more painting, wiring concerns, etc.
Gear racks:  view from underneath, the racks are on the wings and the gear will be mounted to the bottom of the case.
  The gear and the piece cut off to get the correct width
  I didnt order bearings to interface between the gear and its attachment to the case.  It would have been $35 to get two of the right size, shipped.  Since this is not a real machine or high speed application, I made my own bearing out of a stack of flat washers on a 1/4-20 bolt.
Bearing before final sizing
 Filing the bearing to size on my "vertical lathe", aka the drill press.
 the mechanism closed
 Wings extended, installing some rollers to keep the racks tight to the gear.  Here I drilled a hole in the wrong place so Im gluing in a dowel in preparation to re-drill the hole.  The holes would have overlapped otherwise.
Next up, painting.
