Author Topic: Elo glass touchscreen mounting info  (Read 21351 times)
BobA
  • What Me Worry?
« on: April 19, 2011, 04:11:39 pm »
There are always questions about the Elo touchscreen mounting (glass to CRT or LCD) so when I found this document I figured it should be posted here.(intelli.pdf)  Also Elo 1545L manual (008521_f.pdf)
« Last Edit: April 21, 2011, 09:20:30 am by BobA »
BobA
  • What Me Worry?
Re: Elo glass touchscreen mounting info
« Reply #1 on: May 02, 2011, 06:18:48 pm »
I got the 3M very high strength tape at Home Depot.  It is labeled for outdoor usage.  The only problem I had was it is very wide so I used it on the LCD then cut the remaining off.  The straight side of the tape was used on the other side of the LCD and then the remainder cut off again.   This is the tape used to stick the touchscreen to the LCD not the bezel tape.
NIVO
  • Last login:August 08, 2022, 12:32:13 pm
« Reply #2 on: May 13, 2011, 11:03:03 pm »
good info Bob, stickied.
ed12
« Reply #3 on: July 02, 2012, 06:35:52 pm »
thks boba
ed
